Question about Intuit QuickBooks: Pro 2005 for PC
Problem on start up,
When I click on quick books, it says problem with startup, go to repair. I go to repair it tells me there is a problem with c:\config.Msi|P//t932.tmp. and to contact the patch vendor. I don't know what to do
  • dbeard76 Jan 11, 2009
    i have the same problem,i have quick books basic 2004,just got a new laptop,my computer tells me that i have to have an older version of quick books,i do but it is corrupt and i do not what to put it on my new laptop,what do i do,email dbeard76@yahoo.com,
    Champion:
  • Intuit Expert
  • 237 Answers
Advent roma 1000 will not start up.
Hard disk drive has failed. Replace it.
Mar 03, 2017 | Advent Computers & Internet
Why does this come up? There appears to be an error with your installation. Please reinstall the application. Always pop up everyone I
If this error appears every time you start the computer, then there is a program in your system start up that isn't properly installed. I can't tell you which program without more information. A quick search shows that this is a common problem with DriverCure and FileCure. Uninstall/reinstall them if you have one of these programs.
If you don't know which program it is, then you need to go through your startup programs one by one.
Press "windows key + R" to bring up the run dialog box.
Type in "msconfig" and click "OK."
If the UAC dialog box comes up, click "Continue."
Click on the "Startup" tab.
It will display a list of every program that runs when your computer boots. Uncheck the first box for the program that you think might be causing the problem and then click "OK."
A box asking if you'd like to restart your computer will appear. Click "Restart Now."
A dialog box will appear notifying you of changes to your startup, click "OK" and msconfig will reopen.
If the error reoccurs, then uncheck the next item on the startup tab and repeat until you find the one causing the error. Make note of the name of the last thing you unchecked and uninstall/reinstall that program.
To get rid of the startup notification box, simply check "Don't show this message..." before clicking "OK"
Oct 22, 2012 | Computers & Internet
Schedule record application starts automatically in background when system restats
Try this:
Disabling Startup Programs in Windows For some programs, it's smart to have them start with Windows, such as anti-virus and firewall software. However, for most programs, starting them at boot-up just wastes resources and extends startup time. There is a tool installed with Windows, called MSConfig, that allows you to quickly and easily see what's running at startup and disable the programs you prefer to run on our own after startup as needed. This tool is available and can be used to disable startup programs in Windows 7, Vista, and XP.
NOTE: MSConfig can be used to configure several things other than just startup programs, so be careful what you do with it. If you're not sure about using it, just follow the steps in this article and you should be fine.
To run MSConfig, open the Start menu and type "msconfig.exe" (without the quotes) in the Search box. As you type, results display. When you see "msconfig.exe," click on it or press Enter, if it is highlighted.
NOTE: If you are using Windows XP, open the Run dialog box from the Start menu, type "msconfig.exe" in the Open edit box, and click OK.
Click the Startup tab on the System Configuration main window. A list of all the startup programs displays with a check box next to each one. To prevent a program from starting up with Windows, select the check box next to the desired program so there is NO check mark in the box. Click OK once you have made your choices.
A dialog box displays telling you that you may need to restart your computer for the changes to take affect. Click Restart to restart your computer immediately. If are not ready to restart your computer, click Exit without restart.
Aug 26, 2012 | IBM Lenovo ThinkPad L412 Notebook
I can't get my note book to start up in safe mode with networking it just keeps going to the tech guys screan and won't start in safe mode.
Hello
When your Advent laptop isn't booting properly, you probably have a problem with your startup disk. When the startup disk is acting up you may take it to a repair shop, or you may save a lot of money and fix it yourself. Windows 7 computers come with built-in software that will allow you to repair your startup disk in just a couple of minutes.
Start your computer and press down on the "F8" key. Click on the "Repair your computer" option in the "Advanced Boot Options" menu that appears on the screen.
Press the "Enter" key.Choose your keyboard layout on the next screen and click the "Next" button.
Click on the "Startup Repair" tool in the "System Recovery Options" screen.
Wait for the computer to repair the start-up disk
Apr 12, 2011 | Advent Netbook
My netbook wont load up it says following file is missong or corrupy: \WINDOWS\STSYEM32\CONFIG\SYSTEM You can reapair by insecting disc. Thing is its a net book and dosent have a disc what can i do?
try to follow this prosedure if you have XP . i recomend you part 2.
http://support.microsoft.com/kb/307545.
If you have a Windows Vista installation disc:
  1. Insert the installation disc.
  2. Restart your computer.
    Click the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, click the arrow next to the Lock button eb058ccf-b21e-4dfe-9bb7-1ad6c83b705c.png, and then click Restart.
  3. If prompted, press any key to start Windows from the installation disc.
  4. Choose your language settings, and then click Next.
  5. Click Repair your computer.
  6. Select the operating system you want to repair, and then click Next.
  7. On the System Recovery Options menu, click Startup Repair. Startup Repair might prompt you to make choices as it tries to fix the problem, and if necessary, it might restart your computer as it makes repairs.
If Startup Repair is a preinstalled recovery option on your computer:
  1. Remove all floppy disks, CDs, and DVDs from your computer, and then restart your computer.
  2. Do one of the following:
    • If your computer has a single operating system installed, press and hold the F8 key as your computer restarts. You need to press F8 before the Windows logo appears. If the Windows logo appears, you will need to try again by waiting until the Windows logon prompt appears, and then shutting down and restarting your computer.
    • If your computer has more than one operating system, use the arrow keys to highlight the operating system you want to repair, and then press and hold F8.
  3. On the Advanced Boot Options screen, use the arrow keys to highlight Repair your computer, and then press ENTER. (If Repair your computer is not listed as an option, then your computer does not include Startup Repair as a preinstalled recovery option.)
  4. Select a keyboard layout, and then click Next.
  5. Select a user name and enter the password, and then click OK.
  6. On the System Recovery Options menu, click Startup Repair. Startup Repair might prompt you to make choices as it tries to fix the problem and, if necessary, it might restart your computer as it makes repairs.
hope this help
Dec 06, 2010 | Acer eMachines eM2501162 Netbook
Freezes after few minutes
It is also important to remove the suspicious applications and programs in the computer to avoid Windows freezing. In this type of infection not only your Windows registry gets corrupted and needs massive repair but also there is virus based penetration in the Windows set up. In this situation it is recommended to conduct a virus scan as well.However, if your Windows freezes up, the best solution is to repair the computer registry.use registry cleaner reg in out
Sep 11, 2010 | IBM ThinkPad T40 2373 Notebook
My startup page on my computer takes forever. How to speed it up
If you're running Vista that's normal.
Here’s a quick procedure that helps speed windows vista startup:
  • Click the Windows Start button
  • Right click Computer
  • Click Properties
  • Click Advanced System settings
  • In the Advanced Tab, Start and Recovery, click Settings
  • In the Time to display operating systems list setting, set a 5 second value instead of 30.
  • Click Apply
Now, Reboot your PC. You’ll notice a boost in the performance of the startup process.
Mar 08, 2009 | Dell Pentium 4, 2.26 GHz (1W391)
Enter password
To repair your computer using Startup Repair follow these steps:
  1. Boot into Vista installation DVD
  2. Choose your language settings and click Next
  3. Click Repair your computer
  4. Choose your operating system and click Next. This should bring up System Recovery Options.
  5. Click on Startup Repair
Startup Repair should now start diagnosing your system to identify the root cause of the failure. Once it has identified the root cause, it would automatically start repairing your computer. If you are curious to know what Startup Repair did, you can click on the details link and see which tests Startup Repair ran to diagnose the problem.
After Startup Repair has finished the repairs, click Finish to reboot your computer.
Your computer should now be able to boot normally into Vista!!
Note -- If your computer cannot boot into Vista even after repairs, then go back to System Recovery Options and run System Restore.
That's it! This is how you use Startup Repair for most unbootable situations.
Feb 22, 2009 | Acer Aspire 3680 Laptop
System error
check in the device manager, that all device drivers are correctly Installed.
Scan for viruses-Trojans.
Possible Bios problem or Change, check to see if Fast Boot Or Quick boot options are available in the Bios Menu. *** Refer To User Manual*** May also be options for optimized performance.
Mike @ compurepair.
Nov 05, 2008 | Maxdata M-Book 1000T Notebook
I tried rebooting my Phillips X57 laptop. However the battery died on me halfway through. Now when i turn it on, the windows boot manager comes up. It says: 'Windows failed to start. A recent hardware or...
You are going to need to reinstall the Operateing System. If you need I can walk you through it. I will tell you now that this will NOT harm your computer or any information on it.
All The Best,
RCF
May 28, 2008 | Computers & Internet
Intuit QuickBooks: Pro 2005 for PC Logo
148 people viewed this question
Top Intuit Computers & Internet Experts
Alun Cox
Chris Larocque
Dan Shibata
Dan Shibata
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
