Question about Sanyo DS31590 31" TV
Ds27510 tv sanyo
I need to change the input because I just hooked up a dvd player and i can not get it to play - help please - thanks I have called the cable company and it is all hooked up correctly but my remote does not have a input option nor does my menu on the tv
  • kimcolvin Dec 24, 2007
    kimmi, i have hooked up a dvd player and i cannot get it into video mode. i have used all the video connection cords and also tried connecting the s cable.....stil nothing.......CAN SOMEONE PLEASE! HELP
  • 50 Answers
Are you using the orginal remote that came with the tv? It should have a input button close to the power button
Posted on Nov 20, 2007
What channel does it need to be on to play a dvd player I have the converter box
Ur tv have a video input holes R,Y,W.?Use the RCA cable R,Y,W to hook up to play the DVD player.Use the tv video 1 input to watch dvd movie.
May 27, 2010 | Sanyo DS25390 TV
Namco yellow and white inputs to Sanyo DS27510 27 " TV
Yellow goes in the Video In ,White goes in the Audio in.If you don't have any imputs there are converters that will convert A/V inputs to RF (antenna).Good Luck
Sep 06, 2009 | Sanyo DS27510 27" TV
DVD player hooked up, no auxilliary channel
I also have this ******* problem and apparently there is not solution. So just remember, next time you wanna find the urge to buy a ******* sanyo...dont do it. Sanyo = Bigfoots ****!
May 15, 2009 | Sanyo DS19310 19" TV
Technically challenged...need DVD to show on TV screen
hey 1st of all you gotta make sure that your son made tha right connections with the av cable (this is the cable with three different coloured pins) from your DVD to your tv. if this doesnt solve your problem then make sure you are using the correct av channel on your tv set that will allow you 2 play your DVD player because sometimes you cant play your DVD on thhe same av cannel you watch normal tv
Jan 01, 2009 | Pioneer DVR-520H DVD Recorder
No audio when using VCR/DVD player
the first thing that you need to do is use the video cables and audio cables that are on the back of the unit. This makes sure that you have sound and video.
Dec 22, 2008 | Sanyo DS27510 27" TV
Dvd/tv hook up
plug in dvd player direct to tv yello red white for sound into a input ok vidieo one ect then change input on tv to that input ch2 hit ch down to go into inputs
Feb 10, 2008 | Sanyo DS31590 31" TV
Please help
You can find the manual here:
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=b7a9e24543cb9cdef7c4e094fb734a9a&q=Sanyo+DWM-400
They will make you enter your email address if you want to download the manual.
I'm not sure you'll need the manual if you have a newer TV and want to hook this up the way most people do.
Just about all new televisons have a variety of video inputs. Typically you use one for your Cable box, one for your DVD (or VCR). When you wish to watch cable you "tell" your TV you want to view that input and when you want to watch the DVD player you tell the TV that's the input to use. Most Cable Box remotes are set up to control the TV so you can change the input without having to use the original TV remote. You can also, generally, change the TV input from the front panel of the TV set. If you give me the make/model of your TV I may be able to help you figure out how to switch inputs.
But back to the DVD. I downloaded the manual and this DVD can generate output in a few different formats. The easiest will probably be the jacks numbered 2 which is the Audio There are two them, one is RED, and one is WHITE, and jack number 4. This is the Video and will be YELLOW in color. I'll be the DVD player came with a cable set that has three connectors on each end. They will be colored YELLOW, RED, and WHITE.
You should simply need to plug one end of this cable set into the jacks mentioned above on the DVD player and then plug them into one of the inputs on your TV. Pay attention to which TV input you use because you'll need to select that input to watch the DVD.
If you have an older TV we will need to use a different method to hook up the DVD player.
Now for the editorial section. I'm not paid for this. I know it's a strange hobby, but I like helping when I can. If you have more questions please ask before you rate this solution. If anything I've offered here has been helpful I hope you'll rate this solution positively. About half of the solutions I've offered have never been rated. Thanks and good luck.
Jan 09, 2008 | Sanyo DWM400 DVD Player
Sanyo TV
I too just bought an RCA remote for the same television. The button to access other video screens is the A/B button on mine (next to the last channel button).
Jan 08, 2008 | Televison & Video
TV (Model DS27510) is stuck on Video2 setting, unable to change!!
Ours is doing the same thing except on Video 1. I called Sanyo customer service and they said I need the original remote. They were willing to sell me one for $20. Here is what I did instead. I used a cable box and hooked the cable in to it. Then I took the type of cables that will hook into my video 1 slot and plugged them in there and plugged them into the back of the cable box in the "cable out" positions. It worked ! If you do not have a cable box you might try a DVD/VCR combo or a VCR. Good Luck
Sep 16, 2007 | Sanyo DS27510 27" TV
Hooking up external DVD player
if you tryed to hook up into another video input you also have to switch the inputs on the remote in the input menu from input 1 or 2 to the same.
May 27, 2006 | Toshiba MW20FM1 20 in. Combo
Sanyo DS31590 31" TV Logo
157 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
