Question about Intel Celeron D 335, 2.8 GHz Processor
Connection between emachines case and motherboard
I took off the front cover of my emachines computer and the 3 wires came loose:black and white, red and white, and blue and white. i know the conection slot, but how do i reconnect them? i have an intel celeron d 335 processor 2.8 ghz. can you help me please?
    President:
  • 948 Answers
Most likely the wires are for power, reset, and hard disk light. Touch one pair together momentarily, if your compter comes on then connect those wires to the power button. After the computer is on, connect the other two pair to the hard disk light one pair at a time until you see the light activate when the hard disk is running. Then connect the remaining pair to your reset button.
Posted on Dec 31, 2008
I have an emachine t3104 and upgraded the memory the wires from the front of the case became un attached now I dont know where they connect on the motherboard they are black and whitebbgreen and white and...
That model has a MSI K8MM-V (MS-7142-010) motherboard. Mostly likely you knocked some of the computer case wire connectors off the motherboard. These connectors usually include things like the case speaker, indicator for your hard drive operating, etc.
You may want to do a websearch for the manual, which will show a detailed breakdown of these wire connections and how to reinstall them.
Aug 28, 2009 | Computers & Internet
My father in law opened the case to clean out the dust and now the computer won't turn on at all. there are three small wires that are loose they are labeled power sw hdd led and another led i can't...
they should be attached to the pins on the motherboard as they are normally marked on where they go
the pins are on the edge nearest the bottom front of the pc
they normally look like this
just a case of matching them up to the wiring
if your not sure then go to motherboard manufactures website and download the manual from there.
Aug 18, 2009 | eMachines W3506 PC Desktop
Emachine t1840 wiring diagram power switch wire to mother board ?
Because there are so many different case and motherboard combinations sometimes it can be difficult following the instructions for connecting the front panel, USB header and audio header.
Below is a few generic guide that should stop some of the confusion with the labels on the wires.
Front Panel Audio
***Please note this is a generic wiring guide and we can not guarantee it will work with every motherboard. Please check your motherboard manual first. Wiring the headers wrong can cause damage to the motherboard and case, this damage is not covered by the warranty***
another handy USB wiring guide can be found here http://www.directron.com/installusb.html
this maybe easier to follow
FRONT PANEL AUDIO
2________10
__
1________9
Pin Wire
1) Mic In
2) GND (ground) or if 2xGND available, it’s the GND for the headphones, NOT the Mic
3) Mic BIAS
4) n/c
5) Speaker Right Out
6) Speaker Right Return
7) n/c
8) no pin (n/c)
9) Speaker Left Out
10) Speaker Left Return
n/c = not connected
USB (F_USB1 and also F_USB2)
2________10
 x
1________9
Top row of pins
2 = USB port 2 : VCC/Power/+5V
4 = USB port 2 : Data -/D-
6 = USB port 2 : Data +/D+
8 = USB port 2 : Ground/GND
10 = USB port 2 : pin present, but not connected to anything.
Bottom row of pins
1 = USB port 1 : VCC/Power/+5V
3 = USB port 1 : Data -/D-
5 = USB port 1 : Data +/D+
7 = USB port 1 : Ground/GND
9 = USB port 1 : no pin present
Front Panel Connector (FP1)
1 2
x 
9 10
1 = no pin present
3 & 5 = Power Switch
7 & 9 = Power LED (light)
2 = pin present, but not connected to anything.
4 & 6 = Reset Switch
8 = 10 = Hard Drive LED (light)
Jul 30, 2009 | Computers & Internet
W3507motherboard front panel connections
The manual is Here:
http://dlcdnet.asus.com/pub/ASUS/mb/socka/nforce2/a7n8x-e/e1876_a7n8x-e_deluxe.pdf
However, wires to the case are specified by the case maker (you did not specify). Just about all of them mark the connectors on the wire ends with their functions. Just match with the manual's jumper description.
Apr 17, 2009 | ASUS A7N8X-E Deluxe : ATX Socket A FSB400...
No power to emachines t6522
The final set of connections are the front panel leads that attach to the motherboard. This includes the LEDs for hard drive activity and power status, the case speaker, and most importantly, the power switch.
eg:
You should consult your motherboard manual to find out where to plug these in. The power one is obviously the most important.
Hope this helps
Chris (ziraffa)
Jan 17, 2009 | E-Machines (308714) Motherboard
Emachines t6522
Hi birm,
I can tell you that most likely the white wire is the ground wire. The others are positive. The two manual found on eMachine's site does not provide enough of detail.
In this manual see;
Replacing the front I/O Panel (Pages 168, 170 see number 5).
http://downloads.emachines.com/userguides/8511279_eM_NG3_chassis_HW_ref_en.pdf
The information is not specific enough, my guess is the front panel connections is the cable to the far right. (Looking at the picture).
You can try by looking at the picture & hooking the cable as shown.
The white colored wire seems to face to the right. Than try the power on button. If system does not come on, turn the connector 180 & reconnect. Try the power on button on the case.
Listed at the bottom of the link below you can either chat with a tech or call tech. (Main site for the T6522)
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T6522
User guide T6522;
http://downloads.emachines.com/userguides/Desktop_UG_Nexgen2_3_en.pdf
Good luck birm!
I wish I could be more specific.
Mike
Jan 16, 2009 | E-Machines (308714) Motherboard
I installed a new wireless network card....when removing the outer cover of my pavilion xe734 a black and red wire came loose...it has 3 pins holes a white solid blank then 5 pin holes...i cannot figure...
if the wire is coming from the front bezel of the computer it sounds like your front panel connections. They connect to the motherboard and control your power button and lights. That would explain why it won't power on too! Unfortunately all motherboard connect to the front in different places, but it will always be on the outer edge of the board usually near the bottom of the tower. Try seeing which pins on the board match up. Hope this helps!
Jan 06, 2009 | Computers & Internet
Problem with power connections on emachine T2596
Take a peek at this link,
http://www.duxcw.com/faq/mb/frontpanel.htm
it may assist you in your problem
Dec 17, 2008 | eMachines Computers & Internet
Wiring info
Most Mobo's have printing next to the places that are jumpered or pluged into. The ones you need sould be close to the edge of the mobo, that is close to the front {power button} side.
May 30, 2008 | E-Machines (308714) Motherboard
E machine T2742
Well I can tell you that the white wires are negative. The colored wires are positive. Do you still have your manual? Never mind that. There is not a description reference to show you how & where the connectors connect to the board. I would say the two "Black & white", connect the case speaker, most Pc's the negative would face to your right looking in at the board. "Blue & white" would be the reset switch & red & white most likely is the "Power Led". Good luck.
Dec 17, 2007 | Computers & Internet
Intel Celeron D 335, 2.8 GHz Processor Logo
188 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
