Question about Hasbro I-DOG AMP'D
Motion Won't Turn Off
So the manual says I can turn off all the noisy motion and barking and just use the dog as a speaker (with lights) this is what I bought it for... but I follow the instructions to turn off motion and I have to do it like 20 times before it works. It says (while it's playing music) to press down on the tail and press the noise while holding the tail down. It's supposed to display a spinning light pattern when you've done it successfully. I've tried pressing down the tail and pressing IN the tail. I've tried quick taps to the nose and holding the nose down longer. There seems to be no rhyme or reason to why it sometimes works and sometimes it doesn't. Anyone have any tips for getting this to work?
  • 1 more comment
  • kiwited Jan 02, 2009
    I follow the operator manual instructions and it keeps on dancing! How do I stop the bugger dancing?
  • Anonymous Feb 20, 2009
    I keep pressing the tail in. but nothing seems to happen. While the music is playing if you nudge the tail up or down it's to raise or lower the volume.
  • Anonymous Mar 27, 2009
    Omg!!!! I just got an idog amp'd and i have the same problem.......how annoying......It just never stops......it stops dancing for about 3 min then goes again!!!!!
The trick to this is to catch the dog while just playing the music and not while dancing. What this means is that his foot must be down and not moving. Very often he will pause dancing with his foot up, however this is considered "mid-cycle" and he will ignore his stop command. When his foot is down waggle the tail towards his rear. This will produce all but one light turning red and a little beep to indicate him ready for a command. While holding the tail push the nose button for about a second, not long enough to turn him off but more than a quick tap. If his foot is down and music is playing he should respond.
Posted on Jan 15, 2009
How do I free motion on my excel 18w
Free motion is similar on most machines.
Install a brand new sharp needle (embroidery, top stitch, microtex, or universal) of the size that is compatible with the thread weight and fabric.
Drop the feed dogs. If you machine doesn't have the capability, there should be a feed dog cover in your accessory kit that needs to be covered,. This prevents the feed dogs from interfering with your manual maneuvering of the fabric.
Install a darning foot or free motion foot.
Test your stitch and adjust the tension so the threads meet in the middle of the fabric.
Then, it is a matter of practice, practice, practice...
Learn How to Free Motion Quilt Stippling
Free Motion Quilting Tutorial for Beginners Suzy Quilts
https://wpt.org/SewingWithNancy/Video/free-motion-quilting-beginners-part-1
How to Free Motion Quilt on Regular Sewing Machine
lots more web sites available...
Jan 03, 2018 | Sewing Machines
I want my motion securtiy light to acturally stay on all night. more after animals than people, can this be done?
Usually with mains power motion lights if you switch them on and off two or three times and then back to on, the light will stay on all the time. To put it back to motion, switch off, wait a minute and then switch to on.
This is borne out by this article
Search Results Most motion detectors have a built-in override:
  1. Normally the switch is kept on all the time. ...
  2. If you turn the switch off and on within a second or so, the light will stay on, and this overrides motion detection.
  3. To go back to normal operation, turn the switch off and wait ~10 seconds, then turn back on.
More items...
lighting - How can I override a motion detector light? - Home ...
https://diy.stackexchange.com/questions/.../how-can-i-override-a-motion-detector-light
make motion security light stay on Google Search
Sep 04, 2017 | Home Security
How do you set up a brother XL-5700 for free motion quilting
Be sure to have a darning foot or free motion quilting foot (this presser foot is shorter in height so when you lower it, it will not press the fabric to the feed dogs). The foot must allow space under it so the fabric can be manually moved.
The last step is to lower the feed dogs so they are not interfering with your manual manipulation of the fabric.
Lots of web sites about free motion quilting.
May 05, 2017 | Brother Sewing Machines
Memory craft 3000 feed dog will not come back up after putting it down need help
To turn free motion on their is a switch that does this. If the switch is turned on the feed dog will go under the plate and stay their. It will begin to operate again if you turn the free motion switch off.
Apr 02, 2017 | Sewing Machines
Do you have a wiring diagram to wire a security motion detection light between 2 3-way switches so switches can be turned: (on-Motion)/(on- Completely) from 2 differemt locations?
One of the switches needs to be a 4-way then the PIR will act as any other switch. The downfall is if the lights are on and motion is sensed they will turn off.
My preference is to connect the contacts of the security device across the travelers of the three way circuit. The travelers are probably the red and black in the three conductor cable. When motion is detected the lights will turn on regardless of the settings of the three way switches then after timeout they will turn off. If they are turned on with one of the three way switches nothing will happen when the motion detector turns on except you cannot turn the lights off until the security device has turned off.
I hope this helps. The motion contacts need to be isolated from the motion detector power.
Feb 20, 2014 | Electrical Supplies
Motion sensor outdoor light won't go off
How long has this been going on? Has this light fixture been updated recently? Has the lite switch been changed that operates this fixture?
Feb 23, 2013 | Cooper Lighting regent light BRZ Motion...
I installed the motion sensor on a 3way switch. Connected the red lead to the common and the yellow w/red strip lead to a traveler and the black lead to the other traveler. No matter how i switch the...
Leviton manuals:
http://www.leviton.com/OA_HTML/ibeCCtpSctDspRte.jsp?section=17219&minisite=10022
A quick peek inside a sample Leviton manual confirms that your wires are connect correct - BUT...
http://waterheatertimer.org/pdf/Leviton-motion-Instructions.pdf
The remaining 3-way switch needs a jumper wire.
See if your instruction manual shows the same thing as image below.
Let's go through this.
The yellow wire connects to a traveler ... and that traveler connects to one of the brass screws on 3-way switch.
The black wire from Motion sensor also connects to a traveler wire ... BUT you have to identify which traveler wire and which brass screw that traveler wire connects to. And then, put a jumper wire (a short piece of wire) from that brass screw to the dark-colored screw.
I think that will do it.
Add a comment if your device is different.
Some of these electronic devices are reversed when two of their wires are connected together.
That's what the jumper wire is doing. So the 3-way switch is just connecting and disconnecting the black and yellow wires, and that action reverses the circuit in the motion device.
Nov 23, 2010 | Leviton R01-PR180-1LI Decora 180 Degree...
We have an audi a4 and the alarm keeps going off for no reason- what should we do- please help
On an Audi with the simple alarm system (no motion sensor and no disarm button on door centerpost) the fuse cannot be pulled without also disabling the power door locks. You may also have problems with your license plate, back up or fog lights. I tracked my car alarm and light problem to the wiring to the trunk lid on the driver side. The wiring is enclosed in a sleeve and attached to the two parts of the hinge with a free section in the middle to bend as the trunk opens and closes. Inside this bending section I found the separate wires either broken completely or the insulation cracked, creating intermittent shorts and activating the alarm. I reconnected and taped the insulation and the problem was solved.
Oct 25, 2009 | 2000 Audi A4
Hasbro I-DOG AMP'D Logo
808 people viewed this question
Top Hasbro Toys Experts
thegtw
Antony
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
