Question about GE 25.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black-on-Black
Tray at back of our Liebherr Fridge is full of gunge and stinks -
Liebherr SBS 6301 - tray at back on outside is full of gunge and stinks How do we remove to clean - there are pipes etc.
  • dwillink Mar 25, 2009
    Same problem here - and 'take it outside and blast with a hose' just isn't an option.
    Sergeant:
  • 311 Answers
Cant remove its all one assemblie.if you can take refer out side you could blast with hose and cleaner.ive done it a 100 times just let dry out before starting and if you think an area is sensitive cover it .other wise shop vac and the best you can
Posted on Dec 31, 2008
Liebherr ice maker not making ice. Switched on but nothing happening
Hello Irene Booth,
There are several things you can do to check the suitability of your freezer settings ... (eg: if you put a small container of water in the freezer...
Is it mostly frozen in about 45 minutes??
Things that would aid in trouble shooting...
Liebherr nomenclature: model number...???
New... or new to you?
Had previously worked... Never worked.
General observations... Frost forming in back of freezer area
Doors square and fitting properly...
Gasket in full contact (visibly) all the way around the freezer door/drawer... and is in good condition
- (can physically check by pulling a dollar around the gasket).
If the Ice Maker has EVER worked ... We can skip the basics of checking the water supply is hooked up and TURNED ON.
If you can fit your fingers in the ice tray to feel for water or ice in
the tray ... that would also be helpful.
Finally... for new models... check that all packing tape & materials around the ice-maker have been remove.
Although your model appears to be a TWIST TRAY type of ice-maker... there is still a sweep or fill bar that is supposed to check the fill level of your ice bin.
A single chip of ice can hold that from moving freely... your ice maker will not work ... !!
Hope this helps
Carnac the Magnificent
Jan 04, 2017 | Liebherr Refrigerators
How do i get to and remove the drip tray on my liebherr KIU 1640 fridge?
Should be in the back at very bottom of refrigerator, remove back panel to access the tray....
Feb 27, 2015 | Liebherr KIU 1640 Premium Compact...
Evaporation tray at back of stand alone refridgerator is full of .....? and smells. How do I clean it as it is fixed to the back of the fridge?
syringe out drain hole/pipe with clorine bleach(clorine will gas off and leave no smell after an hour or so)clean out tray with bleach,as it will kill the bacteria that causes the smell,the higher the himidity the more often you will need to clean drain/tray.(any clean water in tray ,use to feed your house plants,
Aug 04, 2010 | Zanussi Refrigerators
My frig is leaking water & bottom tray is full
you need to change the filter on the bottom of the refrigerator, take off the outside cover on bottom of fridge and on the left hand side right above the tray that keeps filling up there is a round filter that unscrews. unscrew it and replace the filter. You can get the filters at Lowes or Home Depot for about 20 bucks, hope this helps.
Jul 12, 2009 | Refrigerators
I have a BOSCH Duo System fridge, seems to always have water collecting up at the bottom, as in a large puddle, dont know what to do, the manual has no explanation
Make sure the fridge is sitting level.
Check the cooling panel/ coils on the inside at the back. There should be a collecting channel at the base with a small hole. This is a drain that leads to a pipe - that ends up in a tray on the compressor.
Very often this gets blocked with grey gunge (pleasant I know)
Mop it up, and use a squirt of cleaner to clear it. (use a baster of water to unblock it if needed.) Try to use as little water as you can. The evaporator tray only holds about a cupful.
Jun 11, 2008 | Refrigerators
Remove drip tray from bosch KTR1670GB
YOU MIGHT TRY TO UNCLIP THE COMPRESSOR AND MOVE IT OUT SLOWLY AS HOT TO KINK THE COPPER TUBING,ALSO MAKE SURE YOU USE CLAUK UNDER THE DRAIN PAN SO IT DOES NOT LEAK,HOPE THIS HELP,THANKS-MIKE
May 30, 2008 | Refrigerators
Gunge in detergant tray
You should scrub it off with sanitizer. It is recommended to use gloves for it. Good luck !!
Jun 10, 2006 | Hotpoint WMA74 Front Load Washer
GE 25.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black-on-Black Logo
214 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
