Question about Kenmore 24 in. 16309 Built-in Dishwasher
What is the air gap on a dishwasher?
I am trying to solve my own dishwasher problem by reading solutions to similar problems with having sand like particles left in the glasses on the top rack.
  • 8,197 Answers
The air gap is the chrom or white thing on your sink. It is where the dishwasher drain hose conects to the house drain/disposal.
Posted on Dec 31, 2008
Tip
Solve cross-draining problems with your Doule-Dishdrawer permanently!
Are you experiencing cross-draining problems with your older Fisher Paykel double dish drawer? Have you had a succession of technicians and service companies try to solve this problem, only to have it return again?
There is a reason this is happening to you and there is a way to fix it FOREVER.
In most cases, this problem can be traced to an improper installation. Fisher Paykel double-dishdrawers are in effect TWO dishwashers with two seperate drain hoses. Often times they are installed with an "air gap" which is required by many municipalities for code compliance. Installers who are used to installing "single" dishwashers often install a "single air gap" with a Y-adapter that connects both drawers to a single air gap, and to be fair, this is shown in the install instructions for the product. However it will usually not work for very long. The reason being, there is a small neoprene "check valve" in the base of the pump on both drawers. It is designed to keep the water from the last drain cycle from running back into the machine once the cycle stops. It was never designed to prevent the cross-drain condition. Over time the pressure from the water that wants to come from the other drawer will weaken that flap, causing it to "leak" and the result is when one drawer is run, the dirty water from one drawer drains partly into the other drawer. (YUCK!) Most techs will replace the flap, thinking they have solved the problem, and for awhile, yes, it will.
But this can get kind of expensive having to call for repairs every year or so.
The proper and permanent fix for this situation if to install a DUAL AIR GAP which can be purchased from Fisher Paykel parts: http://fisherpaykelparts.net/index.php?categoryid=1&productid=7
This device is totally "co-axial" in design and will not allow water from one drawer to get into the other. It also is "kosher" in that some Jewish families have a "meat" and "dairy" dishwasher and the two can never be mixed. If there is cross-draining going on, that is "not Kosher!" (pun yes, reality also!) This part will insure no cross-contamination.
These dual air gaps come with everything you need to replace a single air gap, and fit in the same hole. You can even transfer most decorative style covers that the customer may have on the single air gap (such as Bisque/Brushed Aluminum/Brass etc.) The feedback we have gotten from our own customers after instaling one of these is extremely positive, some going so far as to say it is like they have a new appliance, as it is now cleaning better than ever and there is no longer an objectionable odor coming from the drawer.
This is an excellent and PERMANENT code-compliant solution for cross-draining on older Fisher Paykel Dishdrawers. Try it. You'll like it!
on Dec 14, 2008 | Fisher DD603B / DD603W / DD603H Dishwasher
Drain/intake light is on
A re-post from John. I am reposting because I read this post this afternoon and it fixed my Miele incognito Dishwasher.
Hi All,
Thx for all the tips. Combining your thoughts provided a solution for me.
I had the same problem (with a ***** of thanksgiving dishes to do). Turn on,
tries to drain, then that RED blinking "INTAKE/DRAIN" light, like you described.
Spent hours, checking/clearing the (grey) drain hose (The other white hose is the water input to the dishwasher). Also took out metal filter, impeller cover, poked a coat hanger in both ways to/from the drain hose connection. All seemed clear. But still the same.
But when I unhooked the grey drain hose from the air gap unit (that part going to the 4th hole in the sink surface), the dishwasher worked fine. So the air gap unit seemed plugged. The black hose from the garbage disposal to the air gap unit is free flowing (blew through it - yuch!). But the drain connection through the air gap unit was NOT as free flowing.
Replaced it with a new air gap unit ($5.00 at Home depot).
All works fine now. I feel I got lucky.
Well this worked for me. Sorry for all of you who spent big bucks with no solution on those service guys that tried but did not help. I hope this helps some of you.
John
Jul 08, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
Water is coming out of air flow gap. I installed a new air-flow gap and all new lines from air flow gap to sink (except the line from dishwasher to air flow gap) and i still have water coming out the air...
The leak in an air gap is usually caused by a clogged sink discharge line. Most of the time this is connected to the garbage disposal and there is food particulate in the drain hole where the dishwasher drain from the air gap to the garbage disposal connects.
Pull the sink connection hose off and clean the hole thoroughly. You can try testing the dishwasher/ air gap by placing the disconnected hose into a bucket during the pump out period. It should not leak. After this test...reconnect the hose to the sink connection.
If it is NOT connected to the garbage disposal then remove the hose and clean out the hole where the connection is made. This is a common problem and easily resolved by the user.
Thanks for using FixYa.
Kelly .
May 18, 2010 | GE Nautilus 24" Built-in Dishwasher
I have a 2006 tall tub kitchenaid dishwasher which over the last 6 months has been leaving residue on the dishes, esp. glasses. We have had it serviced twice. Last Wed was the last time and he found food...
Try changing the type and brand of detergent. We had similar problems with a Maytag dishwasher which was solved by the above. The glasses in particular seemed to have a sand-like texture in the debris, yet drinking water showed no such problem. Hope this helps!
Apr 13, 2010 | KitchenAid 24 in. KUDP02CR Built-in...
Dishwasher doesn't drain completely after full cycle
If there is any blockage in your diposal, water will comes up to the sink, since it happened to me. As soon I installed the air gap then it fixed the problem. No air gap, water flowing is slowing down conflicting with timed draining causing this problem. Let's think of this, if you fill up water in a 1/2 galon milk container, and you try to emty it. If you pull down straightly , it will be slow compared to pull it at an agle to let air going into the opening. The air vent helps water flow better meeting the timed draining.
Sep 13, 2009 | KitchenAid 24 in. KUDP01IL - Multiple...
Similar problem -Error message Remove Lens Cap and press button.
After reading di_nick34 solution about removing sand, I removed the lens hood adaptor, and blew air between the gap, re-screw adaptor on. Heard a few clicks - must have broken some minute dust/dirt. Remove hood again, and further blowing. Must have removed the dirt stuck in the gap. Camera now works fine. Hope others with similar problem waill have same success.
Sep 12, 2009 | Panasonic Lumix DMC-FZ8 Digital Camera
Maytag DWU7400BAX dishwasher cycles but no water is being sprayed
There are owners manuals on Maytags website but their pretty much useless. there is a water valve switch underneath your washer that is controlled by a float switch and the timer. With the breaker off you can test the micro switch with an ohms meter to see if it is working correctly and with the power on you can test to see if the water valve is getting voltage. there are parts break downs on Partselect website that are pretty detailed and will help you with the locations of all your parts.
Apr 28, 2009 | Dishwashers
Standing water in dishwasher
Check your "air gap". This is the device that sticks above the countertop and prevents any water backup from getting into your dishwasher. The problem may well be a partially clogged air gap.
Remove the decorative cover and there should be a plastic dome that can be removed. Firmly grip the plastic dome and move from side to side while pulling up. Once you get the dome off you will be able to see if it is clogged. This can be done without removing the drain hose from the bottom of the air gap. This solved my problem which was the dishwasher not completely pumping all the water out. After cleaning the air gap it drains properly.
Mar 12, 2009 | Bosch SHV4803 Dishwasher
Kenmore 24 in. 16309 Built-in Dishwasher Logo
139 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
