Question about ASUS WIRELESS ROUTER |WL-520G - RT (WL520G)
I am trying to set up a wireless connection to our LAN at home. I need help.
  • 192 Answers
Well ther should be a wirless icon on the botom right corner of your screen when trying to acess it form a notbook computer. You will need to right click on it and say view wirless networks. Then find the one that is your and try to conect if it need a WEP password it is on the bottom of router.
Posted on Jan 04, 2009
Connecting my Home Hub to Netgear to have wireless setup
3ee198b3c15f6ca7320d6cda56a651c7.png Netgear DG834G 54 Mbps Wireless ADSL Firewall Router Set-up Guide _________________________________________________________________________________________________ _________________________________
Oct 05, 2008 | NetGear DG834G Router
Trying to fix router but when i put 192.168.0.1 in address bar !!!!! Unable to connect message always comes up So i cannot reset !!!! Having problem connecting to my wireless ipod blue ray @phone while at...
Are you using LAN? You can only access Administration if you reset the device through LAN (pressing reset button). You cannot access Admin config after reset through wireless... If your already using LAN, try turning your firewall off. And oh, your LAN should be plugged in to one of the LAN ports and not in the WAN port...
Jun 05, 2011 | D-Link DIR-615 Wireless Router
Get connection to internet
Connections to the internet can be tricky. It depends on how you connect- modem, lan,or wireless. If wireless, is it at home, or at a hot spot. If you are connecting at home, try shutting off your wireless switch on your laptop.(if you can), then shut off (unplug) your router, plug it back in, and then plug in the lan (ethernet) cord, and reboot. It should find your connection. You might also go to control panel, then to internet options, then to connections. See if there are any listings in the box. You might have to change things if there is one that says "use this connection first" or something like that, if you are trying to connect otherwise. Then go to lan settings, and uncheck "automatically detect settings". For a modem you need to make sure the modem is installed in devices (in control panel) and then make sure the software, from your internet provider, which will tell your laptop which number and how to connect, is installed. If you are using a wireless connection, do as instructed above and uncheck "automatically detect settings." and make sure your wireless switch is on. Occasionally there are conflicting connections, or possibly unsecure wireless connections "remembered" in your system that may have changed. Right click on your wireless icon on bottom right, then network and sharing center, then manage connections. You may want to delete the ones you don't recognize, or the ones you don't use anymore, as you can always connect again if you want to. If you are having trouble connecting to a particular connection, remove it from that list and then try connecting again. I know a lot of this sounds difficult, but like I said, connecting to theInternet can be tricky.
Nov 23, 2010 | Sylvania Computers & Internet
We transferred to a new home and a new dsl account. I've reset my netgear wgr614v5 to its default settings and reconfigured it to access but now it only works for pc's that are wired into the ports....
When you reset the router the default setting for encryption is probably off. Hopefully you had encryption on in the old home - but now the wireless computers are still trying to connect using the key/encryption.
Feb 05, 2010 | NetGear WGR614 Wireless Router
Toshiba NB 205 connects to router but not internet
The wireless configuration is set differently on routers, eg the SSID, and encryption. You need to configure the wireless LAN card in the laptop to connect/communicate with the different routers.
Some wireless LAN card allow you to setup different profiles/settings for different wireless routers. Eg one setting for the office and one for home, which allows easy connection to the Internet by selecting the appropriate profile/setting.
Aug 17, 2009 | Toshiba Computers & Internet
Notebook does not connect to LAN or wireless
The dlinks have a tendency to reset to factory settings when you do a firmware upgrade. Connect to the router using a wired connection or using another computer, confirm the settings are what you want, not the defaults. NEVER use the default wireless name (in this case: dlink), always change it to something nobody around you is using!
Jul 25, 2009 | Acer Aspire 3680 Laptop
Laptop won't detect wireless connection (but does detect others)
Dearest crystal 7, you prombally need to reset your windows
wireless. go to add and remove and remove the wireless
drivers the reboot your computer and the reinstall your wireless driver ,then go to the control panel go to internet options then to connetions then scrow down to lan settings the put a check in atuomatically detect settings the apply then ok . the reboot your computer then set up your wireless for connections for your house and it should work ...... lala linda
Jun 20, 2008 | Computers & Internet
Using wireless lan on nokia 9300i
u need a wireless signal provider such has router so only u r unable to connect it...
Feb 20, 2008 | Nokia 9300 Smartphone
Wireless set up
as long as your home wireless network is 802.11g (as opposed to a or b ). I see no reason why that should not work.
all you should need to do is install the software first, then plug in the usb wireless adapter,  once that is done you should then be able to "discover" the local wireless networks, select YOUR network from the list (you may need to enter security details if a WEP key is used), once that is done then all you need to do is change the connection settings in Internet Explorer to "Dial if LAN is not available" and change the LAN settings to "Auto detect settings"
I hope this helps :D
Oct 25, 2007 | Toshiba Satellite 1805-S204 Notebook
Computers & Internet Logo
115 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
