Question about Canon PIXMA iP4300 InkJet Photo Printer
My magenta ink cartridge isn't being recognized.
I have full ink cartridges, but my magenta one keeps popping out of place, so I am unable to print what do I do, must I buy a new cart.?
    Problem Solver:
  • 16 Answers
Check for trash in the way and reseat. Try reseating the magents firs, listen for the click that tells you that contact has been made
Posted on Dec 31, 2008
Printer doesn't recognize magenta cartridge.
You need a new printer head, point blank- this is for the average person not cost effective because of the price of print head if the particular one is even available, No way to pin point what cause it-maybe the company that made it can- so if you repair it may happen again since we don't know what caused it in the first place- People dont repair printers they replace them, my 200$ printer was now 50$ and hard to find and the print head was 80$ online only...guess what i did. You cant sell it because no one wants is--best bet is trash and buy a new one--Good Luck.
Jan 28, 2013 | Canon Pixma Mg8120b Wireless Inkjet Photo...
Tip
How to change an ink cartridge on the Brother MFC-240C
The Brother MFC-240C uses an individual cartridge for each color (black, yellow, cyan, and magenta). When one of the colors is out of ink, the printer will tell you to replace the ink cartridge. To replace a cartridge, follow the steps below.
All four cartridges are located on the right front side of the printer, behind a cover. Pull the cover forward from the side, where there is a slight cutout for you to grab. When the cover falls forward, you'll see the ink cartridge holders.
For whichever ink cartridge you are replacing, push down on the purple handle for that color. The ink cartridge holder will open and fall forward, revealing the ink cartridge itself. Push down on the cartridge holder and the cartridge should pop toward you a little bit. Grasp the cartridge and remove it.
Open the new cartridge and remove it from its wrapper. Discard the yellow cover, unless you plan to use it for the old cartridge.
Insert the new cartridge into the correct slot (from left to right: black, yellow, cyan, magenta) so that the word "brother" is right-side up and located toward the top of the cartridge. Once it is most of the way in, push the ink cartridge holder up by the purple handle until it snaps into place. Then close the ink cartridge cover.
If you were out of ink, the machine should recognize the new cartridge and perform its calibration. If it doesn't automatically recognize it, it will ask if you have changed one or more of the cartridges. Press "1" for Yes.
Once you have printed a test page with all four colors to verify that everything is working, either discard the old cartridge in the trash or save it to recycle. But don't get rid of it until you are sure the new cartridge is recognized and working.
on Jun 01, 2010 | Brother MFC 240C All-In-One InkJet Printer
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
HP CM1015 - stil works; Magenta does not print even though full
The magenta might have been freezed, change the magenta.
Thanks.
Jun 19, 2012 | HP LaserJet CM1017 MFP All-In-One Color...
How to refill hp deskjet 1560 black cartidge
Hi
check here
Pls vote us to keep us alive
Nov 09, 2010 | Office Equipment & Supplies
The lt magenta and magenta just quit printing between pages
1. Check if the cartriges are correctly installed:
Installing the Ink Cartridges
2. Print a diagnostic page and clean print heads, using the printer cleaning utility:
Color Mix or Missing Colors on the Diagnostic Page
Repeat if needed.
3. If this still doesn´t solve you problem, try resetting the printer and manually cleaning the cartrigdes as advised in this FAQ:
Ink Cartridge is Missing, Incorrectly Installed, or Not Intended for Your Device' Error Message is Displayed on the Printer
Sep 06, 2009 | HP Photosmart C6180 All-In-One InkJet...
Epson Workforce 600 "ink cartridge cannot be recognized" error
My printer quit printing blue after I cleaned the print heads. What can I do? I tried recharging the cyan cartridge and cleaning the print heads again. it's still not working! GRR!!
Aug 22, 2009 | Office Equipment & Supplies
HP C6280 Error: Ink Cartridges Empty
I want to print in black only and have changed the properties to grayscale, but it still won't let me print in black only. The magenta is out and it says I must replace, but i don't want color! help!
Aug 20, 2009 | HP Photosmart C6280 Printer
Printer won't recognize the new ink cartridge
Each cartridge has a electronic chip pre-porogrammed at the factory.
If it is a reputable store they will exchange for the right color as they can return the PM to Canon as defective,
Mar 27, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Epson R1800 printer won't recognize new ink cartridge
You can remove magenta & double check that some tape was not left behind on the contacts. Take a clean ragg & dampen it with alcohol. Clean the ink cartridge's (copper contacts & inside the the ink carrige). Re-install the magenta, (tight fit). Power off the printer. Wait a few seconds & power it back up. If it fails a second time with no other errors. Like the above. Than the magenta may be defective. Have a recipt? Return it for a replacment.
Feb 07, 2008 | Epson Stylus Photo R1800 InkJet Printer
Canon PIXMA  iP4300 InkJet Photo Printer Logo
81 people viewed this question
old marine
old marine
Corne Viljoen
