Question about Sharp EL-1197PII Calculator
Sharp adding machine settings
How do you set the dollar decimals 1.00
What should the settings be set at??
Posted on Sep 01, 2010
How do I set the decimal to automatically enter for dollars and cents on my Sharp EL-1197PIII?
Set the Mode selector to "A"
Set the Decimal selector to "2"
In addition & subtraction you will automatically get 2 decimal places without entering the "." just enter 1250 and it will print 12.50
In multiplication/division, you must enter the "." (decimal point).
ie: 12.50 x 2 = 25.00
Sep 08, 2017 | Sharp Office Equipment & Supplies
4 decmal points while adding dollars
Well your problem is in the wrong category, but if you are using a calculator, most can be set somehow to display 2 decimals.
If it is not within your control, just ignore the unwanted decimals in the final result.
Jun 02, 2012 | Cars & Trucks
I just bought a Sharp Compet CS-2187 at a garage sale, but I don't understand all the switches at the top (e.g., DU CF/P.D, etc. I also am not sure how to set it so the decimal is always in place for...
Pam: I also have that calc. I also need instn manual for same reason(s). Works fine for 30 yrs old.
Did U get the User Manua?
Don deBruyn
daphrogue@bellsouth.net
May 31, 2011 | Sharp Office Equipment & Supplies
What is the default setting for the f cut 5/4 and the 4320 add 2 I don't know what to have these options set at thanks EW Seattle
The selector you are asking about is the "decimal selector". The result displayed/printed, will be in a format according to the position that you have selected as follows:
f = floating (the result will be in the number of decimal places that were entered on the keyboard
4= fixed 4 decimal places (x.0000)
3= fixed 3 decimal places (x.000)
2= fixed 2 decimal places (x.00)
0= fixed 0 decimal places (x)
add 2= (add mode*,fixed 2 places) ($.00)
Note* "ad mode" automatically enters the decimal place when entering the number on the keyboard. If you enter "123", the displayed ammount will be "1.23". If you enter "1", the display will read ".01". This is a useful setting when adding a list of numbers in a dollars/cents format, however, be careful, if entering a whole dollar ammount "three dollars" be sure to enter the decimal point, or enter the number as "300". If you don't, the result will be ".03", instead of the 3 dollars you intended.
May 20, 2011 | Royal 29307U Calculator
Odd change added to an even dollar calculation
If you look in the options you will find a setting that says "precision as shown" turn that on and it should cure your problem
Jul 24, 2009 | Microsoft Excel for PC
SETTINGS
Check the Decimal / Add Selector. It shoul be set to "A" (Add mode), to permit addition and subtraction of numbers without entry of the decimal point.
You may also want to download the SHARP
EL-1801P Operation Manual
Jun 22, 2009 | Sharp EL-1801P Calculator
Not printing decimals
Depending on the model there is often a switch that you can set the decimal on, often 1-6 places at the top.
Jun 16, 2009 | Sharp Office Equipment & Supplies
How do I avoid using the decimal when typing a number with no 0s
If I am not mistaken you are trying to set your decimal in dollars and cents correct? Well, if I am understanding your question correctly; you move tab that has F 6 3 2 1 0 set that to the 2 and then there is a tab that says "K * A make sure that is set to the A as well. Hope that helps.
Nov 19, 2008 | Sharp EL-2196BL Calculator
I cant change my decimal place Sharp Calculator model EL-531WH
Set up > TAB > then select how many numbers you want after the decimal place.
Nov 11, 2008 | Sharp EL-531VB Calculator
SETTING UP THE DECIMAL ON NEW 210 TM
Set the +43210F switch to + (or 2).
On some models it is A43210F, then use A (or 2).
+ mode will let you enter numbers (monetary) without the decimal point and assumes cents; 2 mode will just round to 2 decimals, but you must enter the decimal.
May 05, 2008 | Office Equipment & Supplies
Sharp EL-1197PII Calculator Logo
2,856 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
