Question about KitchenAid KHWS01PWH Global Horizontal Axis Washer
Easiest way to replace engine coupling on kitchen aid washer
MODEL # KAWE570BWH1 needs a new engine coupling. What is the easiest way to replace it. I have the part already. I need a manual to see how best to replace it.
    Welcome Back:
    Visited the website for 2 consecutive days.
I found the answer to this myself on
It's really easy actually
Posted on Jan 18, 2009
Does it has an internal fuse
I am not sure, often there is an internal thermal protector but easiest would be to contact the manufacturer or a serfvice center and ask the question.
Oct 04, 2014 | KitchenAid KITCHEN AID 5 Quart Artisan...
Kitchen Air Mixer will not come on
The easiest thing to check is the brushes. Unscrew each black (sometimes white) round cover on either side of the motor housing and see that there is enough carbon brush remaining.
Since the brushes were most likely ok, then I would suspect the solid-state control phase board. These are pretty easy to replace. You can find the service manual for your model on line.
Jul 22, 2014 | KitchenAid Kitchen Aid K45SSWH Classic...
Kitchenaid Heavy Duty 325 stand mixer. Making cookies and now the motor runs but it doesn't turn to mix. PLease help/.
Feb 06, 2010 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Replace coupler on kenmore top loader would like diagram
Go to You will have to put in the model number to do a search. The search will produce an exploded view along with the parts list and prices. If you're wanting to replace the coupling; the easiest approach is to lay the washer face down. Remove the motor mounts and replace the coupling. The couplings are plastic and fit tightly to both shafts. Pry coupling loose from motor and washer with a screwdriver. Install one of the coupling halves on each shaft. Sit the rubber center section on to the motor half of the coupling and install motor and motor mounts.
May 21, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Washing machine sounds like it is spinning but isn't. 70 series model #82870120
Your washer more than likely has a broken motor coupling. This is a common fail item with this model washer thorugh normal wear and tear. Newer versions of the coupler are more resilient and resists breaking. The following link explains how to replace one:
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupling can be purchased on line at for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria. Let me know if you have any questions. I hope you find this information helpful. NOTE: There are other problems that can cause the washer symptoms as you describe. The motor coupling is the least expensive and easiest solution to try first. If the motor coupling is still intact, please let me know.
May 14, 2009 | Kenmore Washing Machines
Broken washer belt
This machine has no belt. It does have a motor coupling. Easiest way to replace it is to lay the machine on its back. Remove the pump cilps and slide the pump out of the way. Remove the motor clips (they may each have a 5/16 screw), and slidt the motor out. Replace the coupling and assemble in reverse order. Coupling # 285753 available at for 9.99 or from sears. Hope this helps!
Feb 02, 2009 | Kenmore 24902 Top Load Washer
Sink plumbing
There are many different pipes available from most DIY shops or plumbers merchants to solve this problem, probably the easiest is a flexible coupling. This looks like a 'concertina' type pipe with waste couplings on each end. If you are in the UK both B&Q and IKEA stock this part. Hope this helps
Oct 28, 2008 | Plumbing
Washing Machines Logo
635 people viewed this question
Top KitchenAid Washing Machines Experts
kj henriksen
kj henriksen
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
