Can you please explain how to install the lamp light for my Mitsubishi WD-62530 TV?
Http://www.youtube.com/results?search_type=&search_query=915P043010&aq=f
Hope this helps like it helped me.
Posted on Apr 19, 2009
I replaced the lamp on 62530 worked fine for a few days, now the picture won't come on and the lamp light does come on.
unplug the unit wait 30-60 seconds & plug back in. Try unplugging your source at TV input & then plug it back in
Jan 03, 2015 | Mitsubishi Cooling Fan Set for WD-62530
Installed a mitsubishi 62530 lamp and the orange light is still on
DO YOU HEAR THE BALLEST POWER UP AT ALL IT MAYBE BAD OR DI YOU PUT THE DOOR BACK ON THE LAMP ?
Mar 05, 2013 | Mitsubishi WD-52525 52" Rear Projection...
My 62 inch mitsubishi projection tv comes for about a minute then goes out with the lamp light on what is the problem
I would suspect if when it comes on it is a bit dark it may be the lamp itself---when was last time set was serviced or lamp replaced---by service I mean these sets need to be cleaned out inside from dust or dirt building up in the air channels---this will also shut the set down.
Lamp failure is much more common than the ballast.
Nov 05, 2012 | Mitsubishi 935D8840 Interface Board for...
I have a mitsubishi wd 62530 08' model had blue showing through left side of tv working towords the middle, screen looks greenish yellow what is the problem
This is a known issue with these sets.
They use an OPTICAL LIGHT ENGINE which the lamp shines directly into: the blue section (it has blue,red and green sections with lens and baffles) is the first to get hit by the light and its heat.
Commonly it burns that area (blue) first.
This is permanent damage and either the display chip has to be replaced (over 200 part and not a do it yourself replacement) or the entire engine has to be replaced.
Sony and similar brands have the same problem--Sony is fixing a lot of them even if out of warranty for free (class action lawsuit!).
This is a 98% certainty in your case.
You may want to contact Mitsubishi to see what if anything they will do.
You might not get a straight answer from them so GOOGLE the model number and research this on the internet-------
Apr 01, 2012 | Televison & Video
Hi...I replace the lamp in my WD-62530 and is work fine until I turn off , try next day and the tv don't turn on, you can see the led green light in front the tv is on for about 10 sec and is off, remove...
U recheck all the connections u take out,when u change the projection lamp and put it all back in all the connections back in properly seated and tightly?Yes,than the board call the Ballast board have problems.This Ballast board job it help to ignite the projection lamp.Change the Ballast board,might solved this problems.
Oct 23, 2010 | Mitsubishi Televison & Video
I HAVE A MISUBSHI TV MODEL #WD57734. THE TV WENT OUT AND THE LAMP LIGHT CAME ON. i REPLACED THE LAMP AND KNOW THE LAMP LIGHT AND POWER LIGHT ARE BLINKING AND IT WONT TURN ON.
Try resetting the set, there is a reset on the front of the tv where the power button is located, just stick the point of an ink pen it it and it will reset itself, if this does not work make sure the lamp door is secure.
Dec 04, 2009 | Televison & Video
I have a Mitsubishi Tv wd 62530 and the lamp light is read Tv will not work
YOU NEED TO REPLACE THE LAMP THE OWNERS MANUAL GIVES YOU DIRECTIONS ON HOW TO DO THIS.
Sep 14, 2009 | Televison & Video
Televison & Video Logo
208 people viewed this question
Top Televison & Video Experts
Electro Med Services...
