Question about Acer AL1914 19" LCD Monitor
Speaker trouble I just got this moniter for Christmas and just got it all hooked up and running and I can't figure out how to work the speakers. under the volume menu it says that the speakers are working and the volume on the computer is hooked up, but I just don't hear anything. Is there supposed to be a seperate cord for the speakers? what can I do?
  • 21 Answers
There has to be separate cord for the speakers. Look for an Audio port on the back of the monitor. It looks like a small hole and should be marked "Audio". Connect this to the Audio out on the PC using a cable with two Audio jacks at both ends.
Posted on Dec 31, 2008
How do i hookup logitech speakers #z313 to my emachine e202hl
The manual for your speakers can be found at http://www.logitech.com/repository/1411/pdf/27251.1.0.pdf. The Speakers should be conected to your computer as opposed to the moniter. Disconect the small wire from the moniter to the computer and insert the plug from the speakers where it came from.
Nov 14, 2012 | E-Machines Computers & Internet
Can i hook up speakers to an lg e2340v moniter to watch netflix? i have it hooked up through hdmi. I have no sound though.
The monitor does not have sound passthru feature so the speakers would not be able to work that way. You can connect the speakers to the Roku box in the audio out jacks. You will need to get a cable from radio shack to make the connection.
Jul 13, 2012 | LG Computers & Internet
My moniter has a knob for volume control with a green light to indicate that it's on, but I moved it in order to grab something behind it and now there is no sound at all. The moniter came with the Dell...
Try plugging in headphones into your computer. If they work then your audio circuit is working. You can also try running the diagnostics from the the Resource CD, It will have"Diagnostics and utilities" listed under the "Contents". You will have to bootfrom that CD disk. To do this, power on your computer and tap the keyto bring you to the "One time boot menu". Insert the CD and then select CD/DVDdrive and hit key. Selectthe "Run the 32 Bit Dell Diagnostics". Select "Custom Tests" and run the audiotest. If the audio tests fail you might have a problem with your speakers. The easiest and sure fire way to determine if your speakers are the problem is to try another set of speakers.
Feb 22, 2011 | Dell Dimension 4600 PC Desktop
Logitech x-540 speakers wont work??
unplugg your hdmi cable and use a regular monitor cable then plug your speakers in to your sound card
Feb 27, 2009 | Logitech X-540 Computer Speakers
No audio hookup on acer v173 moniter
their is no out put for speakers on this model you need to use your computers output
Feb 14, 2009 | Acer V173 b Monitor
UC-280 speakers volume control not working
I purchased my new PC at Walmart. They did not know that the moniter had builtin speakers. My problem is solved. Thank you
Jan 26, 2009 | Creative Labs SoundWorks SW320 Computer...
No speaker hook up on new moniter
If your old monitor was a Compaq, it had slots for the speakers to hang on and provided the power for the speakers. The speakers still got their input from a cable that plugged into the computer sound output jack. If those speakers are the style Compaq supplied when I worked at a Compaq service shop, they originally came with metal stands that fit into slots on the back so you could stand them up on their own, and a 12-volt power adapter so you could use them without the monitor. If you don't have those pieces, you can buy a suitable power adapter (12 volts DC at 1 amp) at Radio Shack but the speaker stands are hard to find. You could try eBay, or just make a holder of some kind. (A friend of mine used those little wooden stands you can buy to display plates to hold her speakers when she got a new monitor. They worked out pretty well.)
Or you can replace the speakers. A new set would have everything you need. But those Compaq speakers sounded pretty good, so if they're still working you might want to keep them.
Dec 22, 2008 | HP Compaq Computer Speakers
Moniter speaker
on my dell one male pin goes into the monitor and the other male pin goes intop the computer where the speakers normally hook up hope this helps ok please keep me posted on this ok best regards mike
Aug 24, 2008 | Dell C521 DimensionTM PC Desktop
New moniter old computer
does monitor have speakers if yes it will have a speaker connection with the video lead connect it to speaker output on computer.
If monitor does not have speakers you will need to buy or use external ones
Jul 15, 2008 | Computers & Internet
Get Moniter Speakers Working
Hello First of all you need a sound card on your computer with a Spk. (Speaker) or Phones (headphones) Out Jack it might be a symbol of a small speaker or headphones. You have to be sure you are getting a actual sound output signal from this sound card too. If the sound card is not working your moniter speakers would not have a signal to drive it. You also need a 1/8" Stereo 2 male stereo plugs on both ends, one end plugs in back of moniter other plugs in back of computer like I mentiond above. Make sure your Mute button is not selected on your computers volume button usally at bottom right of screen. Make sure the volume buttons are up to aprox 3/4 up also. Then for last on the moniter look in the menu i think you might have to keep pressing the menu button but i kind of forget now but its a Spk setting and volume setting in this speaker setup within the moniter as well make sure this is turned on and set at a higher volume level as well. Thats about all I can say without taking the moniter apart and checking the jack and wires and speakers. I would suggest you take it to a electronics or a tv repair or computer repair person to go any further then this. Hope you take time to read all of this I tried to put every step in here to help anyone out with this problem. Thanks for reading. Ken T
Nov 08, 2006 | Liquid Video A170E101 Monitor
Acer AL1914 19" LCD Monitor Logo
178 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
