Question about HP PSC 1610 All-In-One InkJet Printer
My computer wont read my memory card from my hp all in one?? i think i need to install something but i cant find my original disk...what can i do?
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 27, 2009
You need to format the disk ....
The drives can be read by another computer, so the problem is most likely with OS/drivers on the HP giving the error. The specific drivers required to read each drive format could be missing/corrupt. Formatting shouldn't be performed on a drive that contains data unless backed up (redundantly). It may be possible to recover any lost data using free recovery software. Often a format preserves data, erases only the file directory.
I would try a system restore on the HP. If that fails to correct it install or upgrade format specific drivers (e.g. SD/SDXC drivers). Contact Magellan about the GPS: you may have formatted the device's system partition. It is unlikely your computer had the correct drivers to format that device, and it is likely formatted in an incompatible format (such as NTFS). Does Magellan provide a utility to read the device's memory? The SD card should be salvageable by formatting on another computer using the appropriate formatting utility. (Go to https://www.sdcard.org and navigate to their formatting utility.)
From that site: "If an SDXC memory card is used through the direct SD slot of a computer without SDXC driver installation, the card may not be recognized correctly and a message to prompt formatting may appear. In this case, do not format the SDXC memory card. It may erase the data on the SDXC memory card and format the card for a different file system, making it incompatible with SDXC devices."
Aug 24, 2013 | HP G60-235DX Notebook
My mobile doenst read memory card
your gonna have to install drivers its not reading cuz its not had factory drivers installed go to apple.com and download drivers for sd card
Jan 12, 2013 | Apple iPhone Cell Phones
How to format my corrupted memory card (scan disk 4GB sd)? i insert my mmc to card reader and connect to pc to format it but error " no memory card insert ". i think the computer cant read my card at...
If you a using a card reader that plugs into your PC and it STILL doesn't read from the card, this means that the card itself is defective and needs to replaced. You CAN try using another card reader to see if that helps.
Hope this helps. :)
Oct 02, 2010 | SanDisk 4GB microSD High Capacity Memory...
My hp photosmart r707 keeps saying the card is unreadable, buti just used it yesterday. i cant reset it either. it wont let me and the computer wont read it
Sounds like you're connecting things like your camera or your card in a card reader and just yanking them out of your computer without using the "safely remove hardware" icon at the bottom right of your computer screen.
Feb 06, 2010 | HP Photosmart R707 Digital Camera
I have got a 2gb scan disk memory card i cant access it or format
Hello Friend,
Here is a method to try:
  1. Backup all data from your hard drive to another hard drive or CDs or DVDs.
  2. Turn off your computer.
  3. Insert the USB drive to a USB port.
  4. Turn on your computer.
  5. Hit the F8 key when prompted to get to your system bios. Some computers required the Delete key or F2 instead of F8. There should be a note on the screen that specifies the key.
  6. Navigate your bios (usually using your cursor keys) to boot from CD drive first. Save and exit.
  7. Insert your operating system disc aka Operating System Restore disc. Your computer should restart. If not, restart it yourself.
  8. Follow the instructions for installing your operating system. When the option to select which drives to format comes, you should be able to see your USB disk in the list.
  9. Format the disk with FAT32 for Win98 or previous. Format with NTFS for anything after e.g. NT, 2000, XP etc.
  10. Depending on your options, you may be able to opt out of the operating system install at this point. If it was running well beforehand and you can, leave your other drives alone and quit the re-installation.
  11. Reset the computer to boot from the disc drive the operating system is on instead of the CD drive as before. You should have your working flash drive detecting and usable now in windows.
  12. If you didn't get the option to opt out of the re-installation, continue to follow the instructions onscreen and complete the re-installation, formatting whatever drives are required. Note: Do not try to install your operating system onto your USB disk drive. Also be cautious when formatting to keep in mind all data could be lost.
Best Regards,
Oct 29, 2009 | Electronics - Others
How do you transfer photos from memory card inserted in HP C5280 printer to my computer?
You cannot read that memory card inserted in HP printer to your Computer because that HP Card Reader port is only for direct access printing from memory card.
All you have to do is use a Multi-memory card reader into the PC where connected to USB port.
I'm sure 100 works!
Oct 09, 2009 | HP Photosmart C5280 InkJet Printer
We have an Hp computer. The memory reader in the
Hi Larry,
There are a few likely scenarios that would cause your card reader not to work.
1. The cable inside the computer that connects the front-panel card reader to the motherboard has come loose. You can check inside the case to make sure the cable is tight and connected. You should do this with the computer turned off, and turn it on when you're done.
2. The card reader itself has gone bad and stopped working. If this is the case, you'll need to either contact the manufacturer for repair, or you can go out and get yourself an external USB card reader for cheap.
3. The card reader is functional, but there's something wrong in the operating system that prevents the cards from being read, because the operating system doesn't know how to address the card reader. This can usually be fixed by re-installing drivers and software for the card reader.
May 18, 2009 | HP Pavilion a705w PC Desktop
Cant instal micro sd card to samsung E250
Hey! samsung SGH-E250 doesn't support 4GB memory card. Try a 2GB or 1GB memory card.
Jan 04, 2009 | O2 Samsung SGH-E250 Cellular Phone
Ps2 stuck on memory card screen
If its not an original disc, meaning if it was copied or burnt, then this will happen. However if it is in fact an original PS2 disc, then I'd suggest taking it out, cleaning and trying again.
Mar 21, 2008 | Sony PlayStation 2 (PS2) Console
Digigr8 dv-182f
First go to my computer,then add and remove, and remove comcorder.
Now re-install and try again.
Good luck
Nov 28, 2007 | Cameras
HP PSC 1610 All-In-One InkJet Printer Logo
32 people viewed this question
Seeker5211
Seeker5211
