Question about DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder
Hard drive erased
Thank you for your assistance in dealing wiht my erased hard drive. You asked about my values0-9, all are 0 except 7:4 & 8:2. I notcied from someone you helped earlier that 7 should be 4. Anything else I can check?
You also mentioned my dvr being stuck off. It's not normal operation. In the morning, the dvr will be stuck at stage 1 of 5 restarting, then if I turn it off & back on, it returns to normal tv imediately (hard to explain, but it's happened 5-10 x's). Now that I know I can/should reboot every once in a while, that may go away. I may be wong, but I scoured the manual several times & never found that it says to unplug or hold power button for 10 sec.s to restart/reset periodically just like a computer. Why the big secret? It is a computer & just like one it should get restarted when it gets updates, so why isn't that in the 1st chapter of the manual? I know you didn't write it, but if I had been shutting the dvr down sometimes, my hard drive may not have been erased (& with it 100 hrs most of which we never saw & can't get back).
You seem very knowledgeable, were there any updates done on 12/26 or 27/08? Or, where might I find that out? I also noticed you're a plumber, I deal with a ton of plumbing as a remodeler, hope your winter is going all right (worst freezing here in Oregon in decades), or are you out of the plumbing biz & done crawling under houses?
Thanks again for your time & Happy New Year, Jeff
  • 374 Answers
Happy New Year Jeff,
All the values you reported indicate that there is nothing wrong - according to internal self diagnostics- with the hard drive. I live in the South Eastern US near Jacksonville Florida and down here the heat sometimes can cause a system to behave oddly. With that being said I have never had a system that is healthy behave in the manner you describe. I checked for the last update and that was on November 6, 2008 and should have been the L531 version. The hard drive erasure should have only occured if you had the full 100hrs of record time available when you did the reset and therefore would have deleted all timers. Therefore if you did not notice the recordings being available prior to the reset and then missing immediately thereafter the deletion of the timer itself could lead one to the conclusion that it had actually deleted some anticipated recordings which did not take place at all since the timer was erased. One can never predict with perfection exactly how all will behave as there are bound to be some anomalies falling below the radar.
The other issue with the 1 of 5 when you first wake the system up could be a number of things so we will start with the most obvious. If you press menu 6-1-3 at the system info screen you will notice the section are labelled alpabetically. In box B should be two numbers which indicate signal loss on each of the tuners. The upper number is for tuner 1 and the lower for tuner two. The numbers here should be in the single digits. If they are not you may have a faulty piece of hardware such a a seperator or diplexer. Have you experienced colder temperatures when the problem appeared? Either way it could be so many things it is better to have a technician troubleshoot it at your convenience before it goes totally out. Poor workmanship, hardware, and/or cabling can cause this issue.
I no longer plumb professionally on a daily basis. I have been working for Dish since I came back from Iraq and am currently serving in the capacity of Field Service Manger which oversees installations and technicians. Thanks for using Fix Ya.
Posted on Jan 04, 2009
Acer Aspire one 722 windows 7 netbook. "Check cable connection" and "no bootable device--insert boot disk and press any key" are two common things appearing. The computer recognized hardrive, hardr
Hello, it looks like somehow the master boot record was erased from the hard drive, maybe viral? You mentioned the hard drive was recognized in the bios correct? If you need data from the hard drive the easiest way would be to pull the hard drive out and use an external hard drive enclosure to remove the data before you erase everything from the hard drive. If you dont need anything thing you can proceed to do a new install of Windows 7. Turn the computer on then hold alt and the f10 key to perform a factory recovery. This will erase everything and reinstall Windows 7. If this doesnt work then you will need a new hard drive and a bootable usb drive with Windows 7 on it. Hope this helps.
Feb 22, 2013 | Computers & Internet
Tip
Sony PS3 Hard Drive Corrupted or Asking for Restore
A Hard Drive error can be a common problem on the PS3 and this tip will outline how you can troubleshoot and hopefully resolve a hard drive problem. If your PS3 is showing signs that the hard drive is corrupted or is displaying a message asking you to restore the hard drive follow these steps carefully and you may well avoid an expensive repair or having to consign your hard drive to the bin.
Please note: Steps 8 and 9 involve erasing data from your Hard Drive. Therefore if at all possible please try to back up your data before commencing this procedure. You can do this through 'System Settings - Backup Utility' Follow the instructions given in this menu to back up information to an external storage device such as a USB Pen.
To begin the process of troubleshooting and resolving your Hard Drive error you must first put the unit into Safe Mode. Follow these steps carefully;
1) Turn off the PS3 by holding the power button on the front of the unit till it turns red.
2) Hold the power button until you hear the unit beep three times. This will take 15 to 20 seconds.
3) The unit will power off on the third beep and power light will turn red again.
4) Touch and hold the power button again as in step 2. The unit will beep three times except this time the third beep will sound like a quick double beep. As soon as you hear this release the power button.
5) You will see a message onscreen telling you to "Connect a controller using USB and then press the PS button".
6) Do as the message says i.e. connect the controller and press the PS button - you are now in Safe Mode.
7) Restore File System. From this point select "Restore File System" on the menu. The PS3 will attempt to repair damaged files on the hard drive. If this does not work move to step 8.
8) Rebuild Database. Enter Safe mode again as outlined and this time select "Rebuild Database". Be aware this mode will erase certain information from your hard drive which is not recoverable such as photo and message information. If this fails move to step 9.
9) Restore PS3 System. Again enter Safe Mode and select "Restore PS3 System". This will restore all defaults and completely formats the drive. Be aware this mode will erase all information from the hard drive.
If everyone of these steps fail and the PS3 is still showing symptoms of hard drive error you can be certain that the hard drive has failed and it will need to be replaced. However in a majority of cases these steps will resolve the issue.
on Mar 04, 2010 | Video Game Consoles & Games
Tip
Sony PS3 Playstation Hard Drive Corrupted or Asking for Restore
Many thanks for viewing this Tip and I hope it has been helpful to you.
on Dec 04, 2009 | Video Game Consoles & Games
Wanto erase all data from firelite backup drive
You could try data rewriting software to erase your data, like AOMEI Partition Assistant Erase hard drive feature: http://www.extend-partition.com/help/wipe-data.html first you need to connect this disk on your computer and then download the free version of Partition Assistant to use.
Sep 25, 2012 | FireLite (USBFLB80) Hard Drive
Hello! I have a new hard drive WD1600BEVS, problem is that, when I`ll try to install windows 7, all stop at stage where I have to choose place where to install this program...and there ask for drivers for...
had same/similiar problem
if your computer is asking for a driver when you insert the windows 7 disc your motherboard might not support windows 7 if its older than 5 yrs also you need a minimum of 2 GB of ram to support windows 7
hope this helps
Sep 01, 2011 | Western Digital Scorpio WD1600BEVS 160 GB...
Show a step by step procedure to how to reformat a hard disc
- if the hard disk is inside the system use your operating system disk
- boot to the disk by pressing F12
- if you see "press any key to boot to disk" hit the spacebar right away
- if your usinf windows XP delete or partion by highlighting the partition and hit "d" to delete
- it will ask you confirmation, hit "L"
- your system will ask you to reformat hard drive
- for win 7 same process
- first delete partition
- click drive advance option to see the delete option
- delete all partition
- click reformat
hope I answer your question step by step
Jun 07, 2011 | Computers & Internet
Reformatting toshiba portable hard drive for mac, since the one i have says for windows pc
Note: I'm assuming you have a working mac; if you don't, then post back to this solution with that information.
1. Connect the external hard drive to your mac.
2. Open the system drive, usually titled "Macintosh HD." Open Applications, then Utilities and double click the "Disk Utility" program to open it. A window will open giving a list of all the drives currently mounted on the computer.
3. Select the external hard drive that needs to be formatted on the left.
4. Click on the "Erase" tab to the right of the list of drives. The window will now display the options for erasing the hard drive and formatting it to work on the Macintosh computer.
5. Select the Volume Format from the pop-up list. In most cases it's best to leave it at "Mac OS Extended (Journaled)" as this is the default. This setting is the best option for running Mac OS X.
6. Name the hard drive. Type a name for the disk in the field where it asks for the name. This name will always appear when the disk is mounted on a Macintosh computer.
7. Click the erase button. A window will open asking to verify the erase procedure. Click the erase button in this window to start the process of erasing the disk. Once the process is complete, the drive will appear with the name it was given on the left side of the window with the list of drives and on the desktop of the Macintosh computer.
Good luck, please post back to this solution if you have any difficulties, and thanks for using FixYa.
Apr 28, 2011 | Computers & Internet
How can I delete the contents from my Toshiba external hard drive so I can use it for a new Toshiba laptop? Thank you in advance!
Hello jeannietx, to "Delete the {Data / Files} go to the "Disk Management."
  • Next, {Right} click on the Computer 'shortcut,' select "Manage."
  • In the next 'window that opens, 'open the "Disk Management" in the [Left area] of the 'window.' paul7of9_98.jpg
  • Now, look 'under' the "Volume" tab, paul7of9_99.jpg and find the 'External' [HDD] 'letter' ie: (F:).
  • Next, you can "choose to Format the Hard Drive.
  • This will "Erase 'all' Data on the HDD.
  • "You can select to "Delete the HDD, instructions [below]!
  • Click on the "Volume" to open, and select to "Delete Volume..."
!Attention: "Another 'way' to "Delete the 'contents of the HDD {Data) is to do a Disk Clean-up."
  • All {areas} are accessible, by "right clicking on "Volumes."
  • Restart the Computer when finished!
"Please let me know if you 'need' further assistance, or the 'solution' helped?
"By posting a 'Comment" or 'Rating' the solution.
Thank you; your 'response' is important to me!" paul7of9
Feb 28, 2011 | Toshiba 120GB USB 2.0 Portable External...
Trying to install windows 7. said I needed
Are you installing within Windows? If so reboot your system with the Windows 7 system disc inside your cd rom, you should see message that says Press Any Key To Boot From CD at this point press any key. The system will load the installation files the it will ask you if you want to install or perform recovery you will select install, then it will ask you if you want to format your hard drive. Formatting your hard drive will erase the entire drive so back up any desired files. This will successfully install windows 7.
Jan 30, 2010 | Microsoft Windows? Vista Home Basic...
Backup question
Once you save the data on the external drive it will stay there until you delete it from the external drive. I personally run (2) 1 terabyte external drives and I save My data on 2 separate drives. I have had them fail in the past. This is the only way to ensure you will always have a good copy no matter what. At the time I had only 1 500gb external hard drive and it was nearly full. I bumped it when it was running and lost every thing I had! With the low cost of external drives I recommend buying two of what ever capacity you require and making redundant backups, this will assure you your data will be safe. If you have any other questions feel fre to contact me at geokohler@gmail.com Send me your number and I will call you for free. I do this for a hobby just to help people. Please take the time to rate this fixya for me and I will assist you with any problem you have. Thank You,
George
Aug 20, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder Logo
145 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
