Question about RCA RP5008 Handheld Digital Voice Recorder
Recording issue I cannot get to record i push and push and nothing until i fiddle with it and it will finally start recording but only for a shoet few 10 seconds or so
4 Suggested Answers
  • 189 Answers
SOURCE: voice recording to computer
The RCA5030 comes with a USB cable. You'll need to connect the voice recorder using that that cable to your computer and you should see the recorder appear as another drive on the computer from which you can copy files to and from. The files will be in mp3 format.
Posted on Jan 04, 2008
SOURCE: RP5022 digital recorder - file corrupted message
i have a deffical time trying to burn to cd
Posted on Jun 21, 2008
  • 31 Answers
SOURCE: not playing full recording
Maybe it's the preview play option of the player that you are using. It only plays a part of the recording for you to identify if it is the right recording that you are trying to find because the recorded allows you to record more than one file.
Posted on Oct 25, 2008
  • 1218 Answers
SOURCE: Can you tell me what to push on my digital voice
Sounds like you've lost the user manual...go to ...manuals and downloads are in the Audio/Video link.
Posted on Feb 14, 2011
0 characters
1 Points
Terrible sound when recording music in XQ
Hiya marco1ca...The recording qualities and characteristics of your Digital Voice Recorder is designed and optimally calibrated for Audible (voice) recording. Essentially, recording of sounds with peak levels that exceed a conference room of 20 or so people speaking at moderate levels will completely overun the sensitivity and be over-modulated both during recording, and during playback, as in your experience, producing unrecognizable audio. Although it supports and plays Audio files such as mp3 and WAV with ample quality, while doing so, it is only functioning as a player and not a recorder. If you would like to continue to use your Digital Voice Recorder to record live music, execution of the following Setting changes will provide you with the "best" you can get, albeit, you will still not be pleased with the recording. Our objective is to cancel as much sensitivity of your recorder, both aurally and electronically by removing and retarding all features that promote sensitivity. 1) Remove the Stereo Microphone Unit, and record using the built-in Monoraul Microphone. As you can obviously see, the individual Stereo Microphones are very close together. The method that your DvR uses to achieve stereo separation is by increasing the directional sensitivity of these microphones individually. 2) Change your recording mode from your present setting of ST XQ, to SP by; a)pressing and holding the Menu Button for 2 seconds, or until "Rec Mode" is displayed. b)press OK to enter setup. c)press either + or - until SP is displayed. d)press ok to save your change from ST XQ to SP. "SP" mode does not incur any electronic enhancement or proccessing from your recorder. 3) If applicable, change your Microphone Sensitivity Setting to "DICT" by sliding the Mic Sense Switch located on the left side of your recorder. "DICT" is the lowest sensitivity setting that your recorder can achieve. Finally, if in a secure environment, place your recorder MUCH further away. Sound is the movement of air. You are attempting to record a PERCUSSION band, which truly is the epitome of air movement creating sound. What you have been recording and hearing was not sound, but air which was digitally captured simply because there was not enough time for sound to materialize. If you would like to try an experiment to physically understand the process of sound, have someone stand in front of you and whistle a note, and ask the person to sustain the whistle while approaching you until their lips are as close to, without touching your ear. When that physical point is reached, you won't hear whistling, you will only hear air/wind. The closer you are to the source of the sound the more condensed, and electronic signal proccessing becomes overwhelmed, again, causing overmodulation and distortion. These steps are "all the resources that is available" for your specific recorder. Remember, it is a digital !VOICE! recorder, and there is no voice that is as loud, or that produces the dynamic wavelengths as a band playing. If you would still like more information regarding your Olympus DvR, their Technical Hotline Number is 1-888-553-4448. You can also email them at Please update your post on your progress and/or if you have any further questions.....good luck my friend...chris
Aug 19, 2007 | Olympus DS-50 Digital Voice Recorder
SD Card Write Speed Too Slow
Hey Jack! Certainly you've found a solution by now but maybe some poor soul is seeking the solution like I was.I had my Pockettrax CX saying "Memory Full" although I'd deleted everything. What helped finally: I formatted the SD. Now I've got all the memory back. Don't know if that would help the recording speed. but maybe. IMPORTANT: SAVE ANY FILES on your LAPTOP before formatting the SD.Here's how to format the SD:Go to Menu.Click on "Common Menu"Scroll down until you get to "Format"Press "Yes""Formatting SD" comes up and, Voila,You've got more space.
Jan 26, 2012 | Yamaha POCKETRAK CX Voice Recorder
It is stating that the memory is full when it is not.. I go to each folder and nothing is there
I had my Pockettrax CX saying "Memory Full" although I'd deleted everything. What helped finally: I formatted the SD. Now I've got all the memory back. Don't know if that would help the recording speed. but maybe. IMPORTANT: SAVE ANY FILES on your LAPTOP before formatting the SD.Here's how to format the SD:Go to Menu.Click on "Common Menu"Scroll down until you get to "Format"Press "Yes""Formatting SD" comes up and, VoilaYou've got more space.
Sep 10, 2010 | Yamaha POCKETRAK 2G Pocket Stereo Recorder
How can I digitize cassette tapes using the Marantz PMD670?
Take a set of RCA Jack cords (4 jacks) and on the tape recorders "out" jacks attach one pair and on the PMD 670's "In" Jacks attach the other pair. Set the tape a few seconds before where you want to record , set your levels to where you want them, start the recorder then start recording with the PMD.
You may need to test record a few seconds to make sure the recording is at the level you want it to be. Plug in a set of headphones to the PMD and listen in from time to time to make sure it's recording OK.
There you go.
Jul 01, 2010 | Marantz PMD670 Desktop Digital Voice...
Telephone recording won't work
You need to have a telephone record adapter plugged into the back of the 3750. Then you press and hold the Tel Rec button until it begins recording.
Also check to see if the 'Vox' or 'VA' switch is on (voice activation). This will cause the machine to pause if the volume is too low.
Jan 15, 2009 | Dictaphone 3750 Desktop Cassette...
Cannot operate svr-925 digital recorder, need manual
How to Record:
1. Make sure HOLD switch (on side of unit with pocket clip) is set to off position (slide to right is off - to left would be hold)
2. For best results set unit with mic(rophone) which is on top of unit toward sound source and press REC/STOP button (Top button on front of unit just below LCD display). Recording will begin and will be indicated on LCD display.
> Red Record LED will be on and the message number, recording time will be displayed on the LCD.
3. To stop recording, press REC/STOP button one time.
* If no other buttons are pressed within 1 minute at stop position, it will power off automatically.
4. Pause during recording by simply pressing MODE/PAUSE button- press button again to resume.
There is a Voice Operated System (VOS) Recording button on left side also. You can record with voice activation to conserve recording space but I have found that you lose a portion of the recorded sound as it activates and if there is no sound for a very few minutes the unit powers off and you will get nothing further recorded. I recomend just keeping VOS in off position.
5. To erase a recording: Select the message number you want to erase and while it is stopped (the message number will appear in LCD with the length of recording showing also)
Press and hold the ERASE button until the LCD begins blinking "ERASE" then, while it's blinking simply press the erase button again and the recording will be erased.
6. To play back a recorded message find your message by "toggling" the switch on the right side of the unit that says INDEX. That switch is the fast forward/reverse play etc. To Play simply push the switch in. This button/switch takes a little practice to use but the Play portion is straight forward. Use the front buttons to pause and stop during playback.
Hope this helps.
Jan 04, 2009 | Sims SVR-S825 Handheld Digital Voice...
The speed of the recorder
Difference between 4cm and 1.2 cm speed is just like SP and LP speed in VCR etc. 1.2 cm speed selection will give you more recording time on same cassette.
VOR stand for Voice Operated Recording, if you enable this vor option, tape starts recording only at that time when sense any voice and will remain Pause if there is silence.
This option will also give you more recording time at same cassette by skipping empty space.
Sep 17, 2008 | Sony M-675V Handheld Cassette Voice...
Not recording
At first set the recording lenght on your phone(example 5 min) and then start recording, after the recording length is completed it automatically saves your recording file
Jan 31, 2008 | Panasonic RR-US360 Digital Voice Recorder
How do you delete old recordings?
find the recording you want
press the erase button (front of the recorder(top left))
after pressing it let it go
then press it again
that recording is then gone
Jan 22, 2008 | RCA RP5010 Digital Voice Recorder
Voice Recorders Logo
18 people viewed this question
Top RCA Voice Recorders Experts
Are you a RCA Voice Recorder Expert? Answer questions, earn points and help others
