Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Cabrio rotor position sensor
I noticed a reply you made some time ago offering to walk someone through the replacement of a Cabrio rotor position sensor. Would you be willing to help me? I am getting the "F" code in the middle of the wash cycle and have to cancel, etc.
Thank you,
Eric
  • elinn Jan 06, 2009
    I should have the part soon and will give this a shot. Thanks a lot for your help.
    Eric
  • 318 Answers
Ok lets try... first off you need to have the f51 code. then if you do, you do have a "rps"sensor that has failed.
get under the unit and you will see the large disc with an allen set screw holding it to the tub. remove the screw and it will pull off. then there will be 4 screws holding the rotor windings to the tub with a few wires on the sensor.
remove the screws and then the rotor will pull off and you will have the windings and sensor in your hands. when you get this all of it will be very confusing as the wires and sensor are just held into place by plastic tabs. if you have a new sensor that will help you to know that you are dealing with the right part. then unhook the wires from the sensor and next remove the sensor from the rotor windings
there is an arrow mark to show you where to put the sensor back into place, but its not easy.
thats why i get paid the big bucks!!!!!
anyway you can try this but dont get upset or mad, its just not easy for the first time you do it, but if you do it for a living then it gets easier the more times you do it.
of course i know you will only do it once but thats the best i can offer here.
Posted on Jan 06, 2009
Fisher and Paykel Smartdrive washing machine won't fill up
Your fault code is 131,RPS faulty.
130. (10000010) Phase 1 to 6 Single Rotor Position Sensor Error
The Motor Controller has found an error in the pattern received from the Rotor
Position Sensor. Likely causes of this fault are a bad connection on the harness
between the Rotor Position Sensor and the Motor Controller, or a faulty Rotor
Position Sensor.
Primary Source: Wiring.
Action:
1) Check for corrosion on the edge connector of the Rotor Position Sensor and
the Motor Controller module connector.
2) Check the contacts on the rotor positional sensor end of the hall harness to
see if any have been damaged. (Each set of contacts in the socket has two
wipers. If the distance between these wipers varies between different
contacts, replace the rotor positional sensor harness).
Secondary Source: Rotor Position Sensor.
Action:
Check the Rotor Position Sensor with an R.P.S. tester. Replace if faulty.
Tertiary Source: Motor Controller module.
Action:
Replace Motor Controller module.
131. (10000011) Phase 1 to 6 - Repetitive Rotor Position Sensor Error
This fault is similar to fault number 130 above but differs slightly in that it is a
continuous condition. See fault code 130 for service procedure
Mar 20, 2012 | Fisher and Paykel Washing Machines
I too have the same problem as lion heart, I have a fisher &pykel washing machine with model number GW612. It will stop n start while filling n two orange flashing lights will appear. The order of the...
This is a rotor position sensor Fault, below is the diagnostic procedure from the service manual.
130. (10000010) Phase 1 to 6 - Single Rotor Position
Sensor Error
The Motor Control Module has found an error in the pattern received
from the Rotor Position Sensor. Likely causes of this fault are a bad
connection on the harness between the Rotor Position Sensor and the
Motor Control Module, or a faulty Rotor Position Sensor.
Action: 1. Check for corrosion on the edge connector of
Control Module connector.
2. Check the contacts on the rotor positional
sensor end of the hall harness to see if any
the socket has two wipers. If the distance
different contacts, replace the rotor positional
sensor harness.)
Action: Check the Rotor Position Sensor with an R.P.S.
Tertiary Source: Motor Control Module.
Action: Replace Motor Control Module.
Mar 05, 2012 | Fisher and Paykel Washing Machines
Will not spin code 51
Hello there and thank you for choosing fixya
This is the Cabrio washer. F51 fault code is likely the Rotor Position switch failure, located on the motor. Even though it might run, the Hall sensor inside it has gone out. The Cabrio manual is in the Online Repair manuals Forum which you may jump to from any page at the bottom right if you want to test motor resistance from the convenience of the console. Many people mistakenly replace the main control board in hopes of correcting this issue but it is actually a communications error between the Hall sensor and the main board.
There is a Rotor Position switch kit which should correct the problem, and comes with a new harness and excellent instructions. picure below :
Jan 26, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing machine motor not turning when loaded but turning when empty, and it's getting hot.
Inspect the rotor position sensor for loose or frayed wires. The washer tub and motor are all suspended on 4 rods. See page 59
More about the rotor position sensor is on page 57 of your service manual.
Whirlpool Cabrio Washer with 6th Sense Technology.pdf
Google Docs. 16 megs. Printable version.
Was this helpful?
Sep 13, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
What is the F51 error code
its the rotor sensor and control bord that need replacing here is a link to help you understat the problem
http://cabriof51error.blogspot.com/
Jul 03, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer stops and F 51 flashs
Hello, It is a rotor position sensor code. The control is no longer receiving a signal from the motor. It can be a failed sensor or control, but usually it is a bad connection where the wires plug on to the sensor.
Thanks
Jun 11, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
IT SAYS F51 ON THE DISPLAY IT DOES NOT LET MY WASHING CYCLE FINISH
You have the F51 code. The reason could be due to an intermittent connection at the rotor position sensor (RPS). To correct this, remove and install the the connector at the rotor position sensor (plug and unplug) at least three times to clean off any corrosion build up on the connector or the rotor position sensor due to the intermittent connection.
Confirm that the connector is fully seated onto the rotor position sensor upon final connection and verify that there are no damaged wires. The electronic control unit may have to be replaced, since the upgraded version is less sensitive to intermittent RPS connections.
Sure hope this helps you and best wishes.
Aug 17, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio W10106470 has an F51 code. What
F51 error is a rotor position sensor error, two parts really need to be replaced. 1) the rotor sensor itself ($43) and 2) the control board ($197)
Jun 23, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
When thecycle starts it says F 50 code
F50 means that the motor stalled. An F then 50 flashes when the motor rotor position sensor (RPS) senses no rotation. You will need to verify that the basket can turn freely; If it does not and this machine is new, then make sure bottom shipping pack has been removed or determine what is the cause of friction. If the basket turns freely, you will need to perform test checks with the wiring to the motor and rotor position sensor; and the motor and rotor position sensor themselves. I can help you through this process, or if you are not comfortable doing it, you can hire a qualified technician.
If you need further help or clarification on this answer, please do not hesitate to reply to this post.Good luck with the machine.Please do rate my solution if it solves your problem.
Apr 08, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
F 51. I know its a fault.
It is a rotor position sensor code. The control is no longer recieving a signal from the motor. It can be a failed sensor or control, but usually it is a bad connection where the wires plug on to the sensor. If the machine is less than a year old, it will be repaired in warranty. If not, post back and I will try to walk you through the repair if you want to try it.
Oct 21, 2007 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
510 people viewed this question
Dan Webster
Dan Webster
Sal De
