Question about LG DLE5977 Stainless Steel Electric Dryer
Clothes are super creased and not fluffy,especially jeans
Just wondering if there is somethingmore I can do to prevent the wrinkled creases, I use fabric softener but it doesn't seem to help.
  • 140 Answers
You can use a hotter setting or put fewer clothes in. It also helps to shake out the clothes before you put them in and remove them as soon as it's finished drying. Good luck and remember to rate me. Thanks.
Posted on Dec 31, 2008
We have an Ultima washing machine and creases the cloths very badly any suggestions please
The amount of creasing you will get is directly related to the speed you select for the final spin dry cycle and the spin after the first wash cycle which occurs prior to the rinse cycle. The higher the speed and the longer it goes for the more the clothes will crease.
Experiment with different spin speeds on your machine for clothing that is subject to the creasing problem. Also do not put too many items in the machine for a wash as many people do as this will contribute to creasing. Always under load your machine for every wash cycle.
Spin drying is a compromise between creasing and maximum water removal. If you want less creasing you will need to select a more gentle spin dry speed but you will also have the clothes coming out of the machine with a higher water content and they will take a bit longer to dry. The spin time on the program may also be shorter.
In my own machines I use a gentle wash and spin cycle for all clothing that I don't want heavily creased. Running it on a wash cycle with a high and longer spin speed when the machine is spinning the clothes after the initial wash, and then again after the final rinse, will thoroughly crease the clothes every time.
Also bear in mind that different fabrics that are suitable for machine washing will perform differently and some are just too subject to creasing even if you use the most gentle wash, rinse and spin cycle. Hence you can take 2 different 100% cotton fabrics out of a machine and hang them to dry and one will be almost crease free and the other will be thoroughly creased. With these fabrics that are just very subject to wash creasing, it is better to hand wash and rinse them. Then after rinsing drip dry them or put them in the machine and spin them for 1 -2 minutes maximum just to get some of the water out and hang dry them.
Dec 28, 2015 | Hotpoint Washing Machines
How do I prevent envelopes from getting creased on a Ricoh MP c3500?
Hopefully you are using the bypass when printing them. Creasing is only caused by two things. Moisture in the paper and uneven fusing. Make sure when you are printing them you select thick 2 in the printer properties pull down menu. If the problem continues switch the feed direction and possibly the brand of envelopes. The same thing applies to printing labels (the thick 2 setting will provide the necessary heat to properly fuse the toner). But when copying, push the # key and select thick paper from the menu there.
Nov 21, 2014 | Ricoh Aficio MP C3501 Multifunction Color...
How to remove wrinkles from polyester table cloth?
After unfolding a new tablecloth, you'll quickly notice those pesky creases. Even after washing and drying the tablecloth, they may still be there and with wrinkles too. Before you iron a polyester tablecloth -- which if done incorrectly may burn, melt, stain or shrink the fabric -- try rewashing and drying it in a manner that reduces wrinkles and helps get rid of creases. Then, iron only if necessary.
Read more :
Jun 23, 2014 | Furniture
Crease in page when printing cannon image runner 1310
A crease is usually caused by two issues. 1 ) paper is hitting something on the way to the fuser causing a skew. This type of problem would be repeatable every page as well as causing the image to be off centre. The 2) reason is the more likely cause. A bearing on the lower (pressure roller) is beginning to seize. Causing paper not to feed straight through the fuser. This cause a wrinkle from from to back on the sheet of paper. This wrinkle although repeatable generally the wrinkle position up or down on the sheet. This gives the impression of something that is getting in the way of the sheet. If you can change your lower pressure bearings you should be ok again.
May 03, 2013 | Cannon Office Equipment & Supplies
The dryer is showing anti crease on the LCD. What can i do to reset or fix the problem.
have you tried disconnecting the power for about 15 minutes to see if it clears
anti crease refers to the dryer continuing to tublme for about 10-15 seconds every 5-10 minutes so when cycle is complete the clothing doesnt just set there where wrinkles can set in ,it tumbles after end of cycle to prevent wrinkling
Jul 22, 2011 | Miele Novotronic T1515A Electric Dryer
Wrinkled copies
Fuser unit is about the only thing in this model of printer that WILL cause wrinkling/creasing of the paper. So most likely, yes you are going to need to replace the fusing assembly.
Part# LU0214001K
About a $179.00
The vendor I use is
Good Luck
Mar 04, 2010 | Brother Multi-Function Center MFC-8870DW...
Crease reduction facility won't work
Crease reduction facility is just a slower spin cycle if you coose a delicate wash there will be no apparent difference
Mar 07, 2009 | Washing Machines
LG DLE5977 Stainless Steel Electric Dryer Logo
73 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Dryer Expert? Answer questions, earn points and help others
