Question about Samsung SyncMaster 793DF (Silver, Black) (Black, Silver) 17 in.CRT Conventional Monitor
Can't Fix Pincushion
Good day sir... I just want to seek your help regarding my problem in fixing my monitor. It happens that my monitor is in pincushion. cannot adjust the curvature of the sides. problem is some button in panel of monitor doesn't work. one of these are H. size.. and trapezoid adjustment. I already fixing in at the back of my monitor and i tried to look some electronic parts but i dont know which one has a diffective.. Sir i need ur help. pls. Thank you. God Bless
  • 106 Answers
If the menu is appearing then it should be able to adjust the Monitor, provided you have replaced the micro switches. Check for continuity by pressing the buttons. I don't think that there is any prolem with other components.
Posted on May 06, 2007
Hi I am waiting for your help to fix my TV as I have explain to you. Are you there E-mail me regarding my problem. Thank you. Mohammed S. Faruqui 50 cottonfield Cir. Caledon, Canada
Good day!!!!!
Sir may I know again what is the problem of your Sharp LC60LE810UN 60 in LCD TV?..
Please send it to me so that i can help you to fix your TV...
Thank you and have a nice day!!!!!
Jan 05, 2012 | Sharp LC60LE810UN 60 in. LCD TV
I HAVE ABOUT 2 INCHES OF BLACK ON EITHER SIDE OF MY SCREEN. HOW DO I FIX IT. I'M A SENIOR AND DON'T KNOW MUCH ABOUT COMPUTERS.
good day sir. maybe the problem is with your monitor/screen setting. you can adjust it by the controls located mostly at the bottom of your monitor/screen setting. this site may help you
http://owlcroft.com/monfix.shtml
Apr 13, 2011 | Computers & Internet
Help me fix to the set up of my monitir AOC 7f 17''
Good morning! kindly try the following:
-mouse pointer on the screen, right click the mouse, then click the Properties, then click Settings tab, then click Troubleshoot or Advance which will guide you in setting your screen display. best regards.
May 04, 2009 | MPC Computers AOC 7F 17" CRT Monitor
Pincushion and Horital Size Problems
This is a hardware based issue, and sadly cannot be fixed without sending it to a service center. If you really want to, you can send this monitor to a service center, but it will be around 100 bucks to fix. I would say just replace it with a smaller LCD panel. They can be bought for around the same price, and they'll save power too.
Feb 05, 2009 | Samsung SyncMaster 753 DFX 17" CRT Monitor
Issue with my 17" Viewsonic VA1716w LCD monitor
If all the buttons on the front don't work I would beleive it was a cable that is not connected correctly. I've seen things like this happen on otherwise perfectly good equipment. It's probably an easy fix however, monitors have enough power to KILL YOU (dead not a little bit very dead) if your not sure what your doing find someone who is most things I encourage you to open up and play with but not monitors. (did I mention you could die)
Be careful
Rob
Dec 10, 2008 | Computers & Internet
Blurry tv monitor
try to adj picture settings.
Aug 02, 2008 | Televison & Video
Problem with monitor
Your post/description indicates a "pincushion" problem; the width problem is as you have stated.
There are two (2) possible reason for these problems:
1. component failure in the horizontal section of the monitor. These components could either be a diode, a capacitor or a resistor. In some cases there are trimpots in the PCB that can be adjusted to correct these problems;
2. component/connection failure in the controller section.
Of the two, I tend to suspect #1 as highly likely the case. Repairs such as this would require that you be familiar and comfortable working with electronic components and circuitry, the use of a DVM and a soldering iron. Should this be not to your liking, your next best bet would be to seek the services of a qualified professional.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 03, 2008 | HP Compaq FS7600 17" CRT Monitor
Monitor mechanical problem
What i belive is that the hinges of the screen are loose.I would suggest to cointact there tech support and get them replaced.
Dec 25, 2007 | Toshiba Satellite Satellite 5200 Series 15...
Problem with Studioworks 563 monitor
LG Studioworks 563N Monitor horizontal width is exceeding out of screen and not able to adjust it along with pincushion through menu. IRF S630A Transistor replaced, no effect. Pl. help.
Nov 18, 2007 | LG Studioworks 563N 15" CRT Monitor
Wide Screen Problem (Pincushion)
Some countries get themselves 'burned' to a spot because of lack of use. a slight twich one way or another will reset it . The control that you are referring to is it a direct acting one - that is does the work or is it of the switch variety- that is you activate the control but then have to move larger wheel to do the work?
May 28, 2007 | Samsung SyncMaster 793DF (Silver, Black)...
Samsung SyncMaster 793DF (Silver, Black) (Black, Silver) 17 in.CRT Conventional Monitor Logo
284 people viewed this question
Top Samsung Computers & Internet Experts
asber
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
