Question about Foxconn P9657AA-8KS2H Motherboard
Help I erased my bios
I went to update my award bios and my power went out in my house while i was doing it now i get nothing i have a foxconn P9657AA-8KS2H
motherboard and i cant find anything to save my life
  • 120 Answers
1. You first need to make sure you have a boot-up floppy disk. Since most have WinXP I will explain how to do it in that O/S (if you have a different O/S I’m sure you already know how to do it). To make the boot disk you put in a 3½” floppy disk into your floppy drive. You then go to the A: drive, which you can access from My Computer and right click on the A: drive. Go to Format…, and when the format window pops up you'll see a few checkboxes that you can check. The one you want to check reads Create MS-Dos startup disk. Make sure you check that and nothing else, and click on Start. Once it is done formatting continue onto the next step.
2. Download the flash utility you will need to use (I use Awdflash.exe for my Abit board), and also download the bios you want to flash to (it should be a *.bin file). (You can check BIOS utilities and recommendations at your motherboard's official website). Put these two files also onto the MS-DOS startup disk that you had just created. The easiest way to flash is to get one of those go.bat files (For more information about go.bat files check the bottom of this post --Note B.). If you really don’t know how to flash then just do a Google search on Flashing BIOS or just search for it on your Motherboard Manufacturer’s website as I stated earlier. Once you have put the necessary files onto the MS-DOS startup disk you can take out the disk and put it into the computer you are going to HotFlash. **Note: There are also modded BIOSes that you may want instead of the Official ones offered by the Motherboard Manufacturer.
Posted on Dec 31, 2008
  • Aiswaria Sekar
    Aiswaria Sekar Dec 31, 2008
    3. Pull the power plug out of the computer
    you’re going to HotFlash and take out the motherboard battery for at
    least a few minutes. After taking out the battery make sure you clear
    the CMOS. I do this by moving the jumper to the Clear CMOS position and then back to the regular position.
    4. If you already haven’t bought a new one
    get a new BIOS chip out of another working board, making sure the power
    plug is out of that board. Verify that there is an existing BIOS on
    that chip or this will not work. If you need to buy a BIOS chip make
    sure you verify a BIOS exists on it. An empty one is no good.
    5. Take out the BIOS chip in your motherboard and replace it with the new (or working) one. Keep your old one handy. You're going to need it.
    6. Put battery back in (if you already haven't).
    7. Turn on the computer with the boot-up floppy disk that you created in Step #1. (If you cannot get the floppy to boot go into your BIOS and enable floppy as 1st Boot up device).
    8. Once you get into MS-DOS take out the
    new BIOS chip that you had put in (Yes, while the computer is on! That
    is why it's called a "HotFlash”), and put in
    your old BIOS chip. Be careful you put this in the correct way. Match
    the little corner in the correct spot, making sure that the sticker is
    facing up toward you. (There is a corner that doesn't come to a sharp
    point like the other three. Match that dull point with the BIOS
    socket’s dull point). Some people have a tool to remove the BIOS chip
    and some people don’t. If you do not have that tool handy (I didn’t
    have one with my first HotFlash), use a very pointy object, such as a
    pin or needle. You just need to slowly lift on the edges to get it out.
    Two of the four edges should have a very small opening to stick
    something into. BE VERY CAREFUL. I AM NOT RESPONSIBLE FOR ANY
    MALFUNCTIONS! THIS IS JUST A TUTORIAL.
  • Aiswaria Sekar
    9. You should still be in MS-DOS and should see A:\. Type in “awdflash” or whatever program you are actually using and hit ENTER. Follow the basic procedure on a normal flash. If you have a go.bat file just type in “go” and it’ll do it for you. (Just make sure that your go.bat file is edited correctly to the name of the BIOS you’re flashing to).
    10. When it says that it is done flashing
    power off your computer. (Make sure the power plug is out, or if you
    have a switch on your PSU that it is turned to the off position). Now
    clear your CMOS and then put it back to the regular position. (I
    explained how to do this before. If you do not know how to just consult
    your manual on the procedure). Turn on your computer and you should be
    set. Go back into BIOS and fix whatever it is you want. Go to Save Changes and Exit which should reset the computer. You’re original BIOS should be back in business with the new BIOS you just flashed it with.
    11. Put the other BIOS chip from the new
    board (or working board that you took it from) back into that board and
    it should be fine. Just make sure the spare board’s power plug was off
    the entire time.
    Scholar:
  • 40 Answers
There is one solution you can try, and if it doesn't work I'm afraid your BIOS is toast.
Your motherboard will have a pair of pins on the board that if shorted out will reset the BIOS to factory default. This is usually to reset the settings, not restore a corrupted BIOS, but it's worth a try given your situation. You should be able to locate the pins with the motherboard documentation or from the manufacturer's website. Different motherboards locate these pins in different locations. You could check the board to see if there is any text printed by a pair of jumper pins that would indicate that they are the BIOS reset pins. Be sure that you have located the correct pins before you start shorting things out.
If this doesn't restore your BIOS then it is corrupted and unlikely to be repairable. At that point I would contact the motherboard/computer manufacturer directly in case they have a solution, but its a longshot. There's a reason why there are so many warnings not to interrupt a firmware update until it has completed, on most all electronic devices and computers with firmware/BIOS. If it doesn't complete the update then the program is destroyed/broken, and you've lost the programming needed to do the updating necessary to restore the BIOS. Catch-22 I'm afraid.
Given the above, your next solution is to buy a motherboard that uses the same CPU, RAM and peripherals as you now have and swap it out. At least your other components should be still good and useable/rescuable in a new motherboard. A search on eBay/Craigslist/Google might get you one that someone is selling off cheap because he/she is upgrading.
Hope this helps.
Just got a brand new gigabyte motherboard,when i shutdown the pc it wont reboot. when the power switch is pressed nothing happens no fans,led, nothing. the board is a ga-990fxa-ud3,cpu- amd phenomII...
Hi Orville,
Your problem is all about your motherboard you need to updated to BIOS firmware to solve your problem.
Go to the gigabyte website then go to your motherboard page and download and updated to the latest firmware for your bios.
Steps in flashing BIOS
How to Reflash Motherboard BIOS About updating BIOS... The whole BIOS updating procedure should be treated with extreme caution. If you do not encounter any system instability or bugs with the current BIOS version, we suggest that you keep it. If you determine to flash BIOS, you are taking a personal risk of BIOS flash failure. Please contact your supplier or our distributors/resellers for further remedy in case system crashes unfortunately because of BIOS flash failure. Before you begin... 1. Please make sure the BIOS version you want to flash matches your motherboard model. 2. If your BIOS is flash protected, please do not enable BIOS Flash Protection under Advanced CMOS Setup (AMI BIOS) or Advanced BIOS Features (AWARD BIOS) in BIOS menu. 3. Never interrupt when you BIOS is being updated. 4. Because BIOS flashing is potentially risky, if you do not encounter problems using the current version of BIOS, it is recommended that you not flash the BIOS. To flash the BIOS, do it with caution. Inadequate BIOS flashing may result in system malfunction. Three BIOS Flash Utilities... We provide three BIOS flash utilities at our website. Below are the overviews. 1 : flashbios_qflash.gif A BIOS flash utility embedded in Flash ROM. Not all motherboards have the Q-Flash, please use @BIOS or DOS flash utility to update BIOS if your motherboard does not have Q-Flash. Features-- With this utility, you only have to stay in the BIOS menu when you want to update BIOS. No need to enter DOS or O.S. mode. Caution-- Make sure you have a functional floppy disk with the correct BIOS version for your motherboard. UEFI - Download PDF User Guide pdf.gif Download PDF User Guide pdf.gif 2 : flashbios_atbios.gif A Windows-based BIOS live update utility. Features-- @BIOS helps you search for, download, and then update the latest BIOS in Windows operating system. Caution-- Make sure your O.S. environment is stable. UEFI - Download PDF User Guide pdf.gif Download PDF User Guide pdf.gif 3 : DOS Flash utility Features-- The flash utility is a combination of AMI and AWARD BIOS flash utility. You can use it with both AMI and AWARD BIOS. Caution-- Make sure you have a functional DOS boot disk with the correct BIOS version for your motherboard.
I hope my solution may help you.
Thanks for using Fixya...;-)
Sep 18, 2013 | Gigabyte Computers & Internet
Sir,i just want to update my bios "phoenix-award bios v6.00pg,and motherboard is foxconn 865gv.pls tell me where to find the updated bios.
Hi, you can seach for software here:
http://www.foxconnchannel.com/product/motherboards/chipset_compare.aspx?socket_id=en-us0000002&chipset_id=en-us0000015&Socket=Socket+775&Chipset=Intel+865GV
You need the full mainboard number in search for the
right software.
Or here at intel:
http://downloadcenter.intel.com/Default.aspx?lang=eng
Or run the utility at the page.
Flashing the bios with a wrong one WILL destroy the mainboard.
You have to be 100% sure its the right one.
Aug 24, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
I forgot my bios supervisor password in my lenovo g560. Help me. Email id- mail2bimlesh@gmail.com
Are you the one who set up the BIOS password? If not, unfortunately, there's no way for us to retrieved the password. The only way you can reset the password to default settings is to reseat the CMOS battery on the motherboard, its a circular thing that looks like a battery of a watch,sometimes a pin hold it, just detached it then wait for at least 30 minutes then connect it back again,
Note: Before you reseat the CMOS battery,make sure that everything is unplugged on the computer, like AC adapter,battery and all external devices...
Hope this will help...Your response is very much appreciated...
Oct 03, 2010 | Lenovo 3000 C100 Notebook (S5374971) PC...
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER... i have a mother board K7S741MG-6L, bios version 426wp225, i have this problem BIOS CHECKSUM ERROR , KEYBOARD ERROR or NO KEYBOARD PRESENT (which is...
your hard disk is disconnecetedor loose . pls check the hard disk power cable & IDE or SATA cable. Then check BIOS hard disk detected or not if hard disk is not detected your hard disk is faulty.
Dec 11, 2009 | Foxconn WinFast K7S741MG Motherboard for...
Laptop evon610c with foxconn motherboard i cannot
Try one of the following "Backdoor" passwords
AMI Backdoor BIOS Passwords Reported AMI backdoor BIOS passwords include A.M.I., AAAMMMIII, AMI?SW , AMI_SW, BIOS, CONDO, HEWITT RAND, LKWPETER, MI, and PASSWORD.
Award Backdoor BIOS Passwords One reported Award backdoor BIOS password is eight spaces. Other reported Award backdoor BIOS passwords include 01322222, 589589, 589721, 595595, 598598 , ALFAROME, ALLY, ALLy, aLLY, aLLy, aPAf, award, AWARD PW, AWARD SW, AWARD?SW, AWARD_PW, AWARD_SW, AWKWARD, awkward, BIOSTAR, CONCAT, CONDO, Condo, condo, d8on, djonet, HLT, J256, J262, j262, j322, j332, J64, KDD, LKWPETER, Lkwpeter, PINT, pint, SER, SKY_FOX, SYXZ, syxz, TTPTHA, ZAAAADA, ZAAADA, ZBAAACA, and ZJAAADC.
Phoenix Backdoor BIOS Passwords Reported Phoenix BIOS backdoor passwords include BIOS, CMOS, phoenix, and PHOENIX
Id guess that your system has a phoenix bios , judging from the bios upgrades available from HP
If you found this helpful , pleaese rate my solution below
Kind Regards
1234s282
Jul 03, 2009 | Compaq Computers & Internet
Acer aspire 5315 wont boot up
for password, you need to reset your bios. check your bios and enter the password given below:
for AMI BIOS Passwords:
A.M.I.
AAAMMMIII
AMI?SW
AMI_SW
AMI
BIOS
CONDO
HEWITT RAND
LKWPETER
MI
Oder
PASSWORD
for AWARD BIOS
01322222
589589
589721
595595
598598
ALFAROME
ALLy
aLLy
aLLY
ALLY
aPAf
_award
award
AWARD_SW
AWARD?SW
AWARD SW
AWARD PW
AWKWARD
awkward
BIOSTAR
CONCAT
CONDO
Condo
d8on
djonet
HLT
for Phoenix
BIOS
CMOS
phoenix
PHOENIX
Other Manufacturer BIOS Password
Biostar - Biostar
Compaq - Compaq
Dell - Dell
Enox - xo11nE
Epox - central
Freetech - Posterie
IWill - iwill
Jetway - spooml
Packard Bell - bell9
QDI - QDI
Siemens - SKY_FOX
TMC - BIGO
Toshiba - Toshiba
VOBIS & IBM - merlin
hope this helps!
Nov 12, 2008 | Acer Aspire 5315 Notebook
Three beeps repeating at startup, Foxconn P43A
Foxconn uses the Award bios. 3 bios beeps / repeating means there's a memory issue.
http://www.computerhope.com/beep.htm
(Remove, clean & reseat).
Do not clean the DIMM's with an eraser. Use house hold alcohol.
Dripped onto a cotton swab & wipe the contacts off.
Clean the DIMM slot & reseat.
On the outside, if the 3 beeps repeat run a memory testing program. Click this link below, scroll down & under the three screen snapshots download you're flaviored software. One allows you to create a bootable floppy disk & one allows you ro create a bootable CD. Main site: http://www.memtest.org/
Download - Pre-Compiled package for Floppy (DOS - Win)
Download - Pre-Compiled Bootable ISO (.zip)
Main web site for Foxconn 755A01-6ELRS
http://www.foxconnchannel.com/EN-US/product/Motherboards/detail_overview.aspx?ID=en-gb0000154
Good luck Pbacatmac!
Mike
Aug 03, 2008 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Foxconn P9657AB motherboard installation problem
You're Foxconn board uses the Award bios.
The long beeps you are hearing are telling you there is a problem with you're memory.
You're pic does not look like the Foxconn P9657AB-8EKRS2H MB as shown in the user manual. Found on This link.
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000297
The pic on Foxconn's site does but not the manual listed.
The motherboard uses four 240-pin slots with 1.8V for DDR2 memory only.
(Question? Did you're ECS MB use DDR2 memory)?
If you have more than 1 DIMM installed remove all but 1.
Move the DIMM into the closest slot next to the CPU.
Boot the PC & check for beeps. If still presant move the DIMM to the next slot & try again. Continue this through all four slots. Than try another DIMM. If the mother board continues to beep as mentioned than call Foxconn. (There is a bios update mentioned below for memory).
The CPU may come into question. (It’s revision). You may have to call Foxconn for this information. (580-272-0035). They do not place this information in their user manual. Most users have to call. The rev of the CPU may conflick with the memory causing you to receive the bios beeps. (I have had to return 2 boards for this reason). I picked an Asus board over Foxconn.
I have come across this with Foxconn motherboards these past two years. Suggest you update you’re bios. Foxconn has a revision dated, 3-28-2008 for memory before you call. After bios update test the memory again for beeps. Still there? Return the board is my suggestion.
It’s a guess that the red led will go away after the memory issue has been addressed. Normally there is a green led on most motherboards. This means standby. The board has power connected. I could not find any reference in the user manual * .pdf, for R450.
Good Luck ninjo61!
Mike
Jun 20, 2008 | Foxconn P9657AA-8KS2H Motherboard
BIOS in BAD Shape
First thing the problem only with O.S(as per your statement - proper shutdown and restart). Your O S afftected by virus. you must format the full harddisk(all partions) and reinstall your O S. BIOS File always having the .ROM extention file, not BIN file. Pls reset the BIOS using the clear cmos jumper or removing the CMOS battery from motherboard.*****severe virus attack. Dont try to backup****
Feb 23, 2007 | Syntax SV266AD Motherboard
Foxconn P9657AA-8KS2H Motherboard Logo
440 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
