Question about Frigidaire FEFB78DC Electric Kitchen Range
Takes too long to reheat
We were cleaning behind our Frigidaire electric range  the other day, and when we went to move it back, there were sparks and even a little smoke.  We left everything alone for a while to make sure nothing was going to catch on fire.  Nothing more happened, and there were no more sparks when we tried to slide it back again.  Now, all of the burner elements (glass top) and the oven take forever to preheat (over 1 hour to get the oven to 400 degrees).
    Sergeant:
  • 311 Answers
Elec stoves require 220 volts to heat properly.so because of long heat times on all parts your only getting half the voltage.turn off the power 2 your stove at the breakers before doing anything else.then pull out range and inspect all cord connections.I offten find aburnt cord at the block where cord attaches.If thats all good check your receptcal ,as long as you turned power off theres no danger.you can use a volt meter if unsure.repair or replace parts as needed.all new connections must be tight,you can do it yes we can
Posted on Dec 31, 2008
Frigidaire professional range boil convection and reheat doesnt work
Hello D Scott - Sounds like the range is either experiencing a wiring/communication error or a faulty EOC. Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. If it proves to be ineffective, contact a professional to move forward accurately.
Jan 10, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire crown series electric stove just delivered.
Hello - I would first suggest confirming that the range is plug to the proper voltage (120/240 Volts 40/50 Amp). Was there anything located behind the range before pushing it back? From what you have described it sounds like the control board will need diagnosing. Contact a professional to move forward accurately.
Oct 18, 2012 | Frigidaire FEF352 Electric Kitchen Range
Electrical panel went blank. Hence can't operate the oven. Stove works fine.
Hi. Interesting. My Figidaire Gallery Professional gas stainless went blank 2 days ago. Model FGF379WECS. So I'm googling...
Your Service Manual is located at (document #2 in link):
http://www.retrevo.com/support/Frigidaire-GLEFM397D-Ranges-manual/id/2367bh351/t/2/
Part Number
316418704
Description :
Clock/Timer, electronic, w/mini oven, ES510
Rick
May 15, 2010 | Frigidaire Gallery GLEFM397DS Electric...
I have a Frigidaire Electric Range with Self-Cleaning feature, however when I start the clean cycle and set for 3 hrs, the display says thtat the range needs to lock, however the lock does not move, any...
its probebly a bad latch motor. not easy to get at. you may call for service.its located behind the back pannel but depeding on the model its hard to fish it twards the front to replace it.
Jan 22, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
My Electric Frigidaire Convection Oven just locked it's own door! I heard a continual beep..then "Err" "F9" flashed, then beeping stopped and the illuminated "padlock" symbol lit up and the door locked...
I have a similar problem with my electric Frigidaire convection oven, which flashes ERR F9 and beeps after finishing a cleaning cycle; if you haven't had to have it repaired professionally by now you might try cutting the circuit breaker to the oven for a few seconds and then turning it back on. My oven takes a few minutes to reset, after the circuit is turned back on, but then will unlock the door and let me reset the clock and continue cooking as normal. . . until the next time I set the clean cycle.
FW
Seattle WA
Dec 15, 2008 | Frigidaire 30" Self-Cleaning Slide-In...
Fridgedaire Electric Kitchen Range
shut your oven off at the breaker and then pull it out and check the power cord where it connects to the ranges terminal block let me know what you find
Sep 11, 2008 | Frigidaire FEF352 Electric Kitchen Range
The clock started flashing as if the power went out. Then when we tried to
The plug receptacle may be bad. Check the plug for proper tension. If feels loose, have the receptacle replaced. Inspect the plug for discoloration. (a sign of a bad receptacle)
May 22, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Oven preheat
A few questions first.  How old is your oven?  What is the entire model # that is on the sticker on the oven.  Model # should be somewhere behind the bottom drawer.
Oct 11, 2007 | Frigidaire FEF366 Electric Kitchen Range
Oven inop
something has fused (broken) along the power line into the oven. Use an ohmmeter (power off) and check continuity along every possible power path (wire) until you find an OPEN ohms condition.
Jun 09, 2007 | Frigidaire PLEFZ398EC Electric Kitchen...
Frigidaire FEFB78DC Electric Kitchen Range Logo
127 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
