Question about Philips Magnavox 42MF521D/37 Television
Remote i just boat a 42inch lcd tv and i hooked it all up but the remote wont work the tv well blink but nothing well happen is there a way to fix it with out buying a new remote
  • 120 Answers
Replace the new battery and then check it...
If its not work means u want to replace the remote..
Posted on Dec 31, 2008
I have a 42inch sharp aquos LCD tv and there is no power. The power button keeps blinking. There is no picture and sound. What is the fix to this problem.
Power problem are cause by many reasons, i.e Power supply circuit, Lamp driver circuit and most often the TV detects an error cause by power surges. To protect TV from further damage most LCD TV have protection circuit built internally. If this is the reason of your LCD TV not powering On, an error data must be reset back to zero.
To change data you will need to access the service mode and change the value of lamp error code to zero (0). Entering service mode requires a trained TV technician. Changing data can cause more problem to your television. If you are not qualified to service your television, please do not go to service menu codes. Moreover below are the process, pls do so at your own risk.
* Unplug the TV * Press and hold the {VOL -} + {CH+} buttons located on LCD TV unit (not in remote control) Note: If above didn't work, alternately use (VOL -) + (TV/AV input) buttons located on LCD TV unit (not in remote control) * While holding the above buttons, plug in the TV. * The TV will turn on with the "K" or "K123" appears om screen. * Use {CH+} {CH -} buttons to go and display the service menu. Note: If above didn't work, alternately use (VOL -) + (CH -) buttons. * Search for "LAMP ERROR menu" from the displayed service menu by using "up or Down cursor" from remote control, or alternatively use "CH - or CH+ to select "LAMP ERROR" * change it to zero (0) value, using {VOL+} or (VOL -) on remote control. * Turn the set off to exit the Service Menu.
Jul 03, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
IHAVE REMOTE PX-RC1 ILOSE THE CODE BOOK & TV NAME PRIMA
Press SET BUTTON and at the same time, the appliance you want to set( TV, VCR,Aux...etc). The LED should stay on.. then press on the SET BUTTON again ... the led will blink fast... then press ( in front of TV, of else).. the POWER BUTTON to see what happens, if nothing happens, then press the +CHANNEL BUTTON once, and press power again. Repeat this until it turn off. Then press the appliance button (VCR,TV,AUX, etc...), this will stop the LED to blink and your appliance will be set.
Dec 24, 2010 | Universal Remote Control MX-500 LCD Remote...
How do you get the code search to work. All that happens is that the red light blinks.
i just bought a rca 40inch lcd flat panel tv and no remote is working with it.my sat remote wont work or the rca rcr312w remote wont work either help
Aug 08, 2009 | Innovage Jumbo Remote Control
Remote code Directv
try vizio under tv tv brand in the direct tv remote control codes.
Aug 02, 2009 | Honeywell CE2Y-PPT Remote Control
Vizio GV42L 42inch LCD/HDTV
there are several possibilities. first if the unit comes on and the "VIZIO" light turns white, but no picture or sound, then the main control board is most likely the issue. could be the LCD control board(s) depending on model one or two. and ultimately could be the power supply on the upper side....if the "VIZIO" light does NOT turn white, the whole power supply unit is out. after that, would have to scope the circuits to find out. Seems that the control board is the most common and tends to happen on many different sizes. new board will be around $350.00. Might get lucky and find a used one, but it MUST be EXACT part or it wont work right. if you dont find one or want to sell yours for parts, id be interested in the screen. can reach me at kmarlin@grandvalleygolfclub.com. thanks, keith
Jun 27, 2009 | Vizio GV42L 42 in. LCD Television
Invalid format
my xbox 360 when hooked up to my 42inch Lc7d get sound but displays invalid format error,  how can this be fixed?
Jul 07, 2008 | LG 42LC2D 42 in. LCD HDTV
No picture
Open the back of the TV,and look at the can shaped items on the board that the power cord is hooked to.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.So far I have fixed four of the same make,and model TV as this,and they all had either one,or two bad capacitors.I hope this helps.If you have any other questions,please let me know.Thank You very much!
Tyler
Feb 12, 2008 | TruTech PLV1615T 15 in. LCD Television
Philips Magnavox 42MF521D/37 Television Logo
48 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
