Question about Panasonic PT-61LCX65 61" Rear Projection HDTV
Green spot The other day I turned on my TV and noticed a green spot about 4 to 5 inches in diameter on the screen. It doesn't move and is not visable when either black or white is occupying that space but can be seen when pretty much any other color is in that area.
  • 1 more comment
  • Anonymous Mar 13, 2008
    I just started having the same problem. Called Panasonic today and they are sending someone to fix it no charge.
  • Charrin349 Mar 29, 2008
    I have green spots on various areas of the tv screen for the PT-61LCX65.
  • Anonymous Oct 08, 2008
    I had the same problem. It got a 4 inch spot two weeks after warranty ran out so I didn't call it in. At 3 years it finally got really bad enough with two more spots and background started going pink snow. Looking around I found this thread and called a local shop who quoted me $225 +70 for a house call to do the repair if it was the eeprom coding. He suggested I call Panasonic to see if they would cover it via warranty. I called Panasonic and they agreed to cover the diagnostic fee and dispatched a local service provider. (the same I had talked to)
    The sp came out and I told him what I had found and that it just needed the eeprom fix with a $75 tool that I couldn't buy. The repairman basically blew me off and said they had never done that repair and that it was a damaged light engine so they had to take it back to the shop to replace the '$1000 guts' of the set.
    A day later the TV was back but I wasn't home to ask about the repair. When I called in, I talked with the owner again (not the guy who came onsite) and he said it was what we had talked about originally and a quick fix.
    So even if your set is 3 years old and you have this problem, call Panasonic and they still may fix it for you. If for nothing else, I'll keep them in mind for future purchases because of their customer service. I just wish I can called earlier.
    Thanks to everyone who posted with this solution!!!!
  • 4 Answers
Easy fix. I had the same green spot problem with PT-52LCX65 and I removed the front panel (no screws). In the center is a panel that has two screws. Remove them and pull the cover off. There you will find the projection bulb. Do not clean the bulb but instead the base. Use a damp cloth to wipe the dust off the black disk (the base of the projection bulb housing). Apparently the dust through static electricity may cause enough magnetism to distort your picture. Hope this helps.
JK
Posted on Dec 02, 2007
    Problem Solver:
  • 10 Answers
Check with Panasonic. I have the same issue and was originally told that the optic board needed to be replaced ($1700). I waivered on getting it fixed and spending more than the tv is worth. So I now learned that there is a new fix for the bad optic board and Panasonic is repairing it free of charge. Repair is schedueled for next Friday (Feb 1, 08). I'll report back if it was successful. This repair involes an eprom on the optic board. Hope the sheds new light........
Posted on Jan 25, 2008
  • 1 more comment
  • Jim Feb 01, 2008
    "eprom upgrade" is the fix. Panasonic has issued this new fix and it solves the problem... hope this helps.
  • Jim Feb 01, 2008
    The "eprom upgrade" did fix the problem. Panasonic covered the cost of the repair. They made me very happy....
  • Jim Feb 01, 2008
    The "eprom upgrade" solved the problem (2/1/08).
    A 15 minute fix for the Panasonic repairman.
  • 203 Answers
Sounds to me like you have a damaged green LED in the light engine. Replacement of the light engine is likely your only fix.
Posted on Jun 08, 2007
Hi guys, I have got a spot on my Sony 40" LCD TV which i got when one of my cat urinated on the TV. its about 4 inch in diameter and is on the bottom right corner of the screen. Now my quest
moisture and electrics dont agree with one another. Could try
isolating from the mains and spraying lightly with car windscreen
de-icer (isopropanol) wipe off any excess and leave in a warm spot for
a few days....Might work if you are lucky
Oct 27, 2014 | Sony "BRAVIA EX 400 Series 40-Inch LCD TV,...
Why does my led screen have a white spot
may be the panel, in which case it should be under warranty. This unit has a 1 yr mfr warranty , if less than 1 yr old it would be covered. contact servicer for service immediately before warranty expires
Sep 09, 2014 | TCL 48FS4610 48 LED HDTV 1080p 120Hz Slim
Over past couple of months the tv has gotten 2 red spots in the lower right hand corner of screen about an inch in diameter, and recently a green spot in center top third of screen that is about 2 inches...
Unfortunately your light engine(also know as optic block) may need to be replaced. If your tv is out of warranty, it will probably cost around $1000 to fix. There is a slim possibility that the optics lens could have dust on it and a tech could clean it for much less than that. This is a very common problem in any dlp tv and they are all expensive to fix. I've replaced several of them at our shop, but about half of the customers won't have the tv fixed and will get a new one. Good luck!
Jul 30, 2010 | Panasonic PT-44LCX65 Television
Panasonic pt-61lcx65 green spot
This may be a main board issue if the green spot moves. This is repairable. This may be a panel issue if it does not move and it is present on the panasonic splash screen and if it affects the osd menu.
Jul 29, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
Blue spot on screen center. Peoples faces and show blue tint
if you have a Sony LCD projection ..Theres good chance optical block needs replacing .This spot will get bigger and will eventually cover most of screen the longer you use it .needs repair.If there is no warranty on this unit..I would estimate repair around 6- 8 hundred dollars ..
Aug 06, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Blue spot on my hitachi 50"rear projection tv model 2006 50vs69a
Do you have a center speaker near it? maybe move it, that is what I have done and it seems to have gotten better.
Jun 09, 2009 | Hitachi 50VS69 50" Projection HDTV
Light green and pink spots on my hd tv!!!
For the spots....
I had the same problem, first a blue spot then a green spot showed up. I contacted Panasonic Customer Support. They sent someone out and they fixed the TV for free. They reprogrammed the EEPROM chip in the TV. It is a defect. My TV was 4 years old and out of warranty. They came out last week.
So long as it is not happening by something you have done. It will be fixed free of charge. Call them, it solves the problem.
May 27, 2009 | Panasonic PT-44LCX65 Television
Hitachi ultravision 50 inch lcd 50v500a
A BIG RED SPOT APPEARS ON THE SCREEN WHEN U TURN IT ON WHEN IT IS STILL BLACK. THEN ARED HAZE IS VISABLE IN ABOUT I 6 INCH AREA WHEN VIEWING THE TV.
Nov 25, 2007 | Televison & Video
Panasonic PT-61LCX65 61" Rear Projection HDTV Logo
483 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
