Question about Singer 3116 Simple
Backward stitching when i begin sewing , the machine sews my material backwards, so material feeds forward instead of backwards
  • Christel Hendrickson
    Christel Hendrickson Sep 27, 2017
    Thank you so much. I figured it out. The bobbin refill setting was on.
  • 202 Answers
Knowing which kind of machine you have helps alot. Just guessing but maybe the reverse mechanism is stuck and needs some oil in it to free it up. Or the buttonhole mechanism is stuck in reverse part of it.
Probably you should have it looked at.
Posted on Jan 11, 2009
My machine will not sew in the forward position...It keeps sewing backwards like it is in reverse.....Need help ASAP
All sewing machines have a gear lever. This is so you can sew a seam forwards and backwards. Consult your manual.
May 03, 2016 | Sewing Machines
Bernina 440
The jagged teeth on sewing plate are not moving to move the material forward. U will have to look under the machine to check out the mechanism that is supposed to move them and find the part that is the cause of no transmission of power to the teeth assembly.
Feb 15, 2016 | Bernina Sewing Machines
Why does upper thread snap when backstitching?
May be an issue with the feed dogs, or possibly a burr on the hook. Lay a peice of scrap material under the foot as if you were going to sew, remove needle, then run machine in reverse to see if it feeds material backwards as it should
Nov 07, 2015 | Singer Advance 7422 Electronic Sewing...
While stitching the cloth goes backwards instead of moving forwards.the backwards stitching switch is constantly on. What should I do
check to see if your machine is in buttonhole mode, one of the legs of the buttonholer will always be a reverse zigzag.
Sep 19, 2014 | Sewing Machines
The Feeder Dogs are not moving forward or backwards on my sewing machine.
Are the Feed Dogs dropped? Check your manual for the location of the switch. .... otherwise your mechanism has been compromised. Take it in for repair.
Mar 19, 2013 | Kenmore Sewing Machines
White model 445 material won't feed?????
Hi Jason. I wonder if you have your feed dogs lowered. It's near the bobbin area.
Here's a pdf of your manual. It talks about "drop feed" on book page 19
Good luck
Nov 16, 2012 | White Sewing Sewing Machines
My husqvarna classica 90 sews backward instead of forward. Can you help with an answer why?
Make sure the stitch selector is not set on buttonhole. If the machine has set up for a long time not being used it may be that the stitch length is stuck in reverse.
Apr 19, 2010 | Sewing Machines
Pfaff 1222's 3 stretch stitches sew wrong and backwards only.
It sounds like the feed mechanism needs oil.
Feb 24, 2010 | Sewing Machines
Started sewing backwards now not moving material at all
Sounds like the machine's age is causing the lubrication to get sticky.
Try changing the pattern by moving the pattern selector around.
Take out the bobbin and remove the thread and presser foot, raise the presser lever, set the pattern to zig zag, set the stitch length to maximum and run the machine at full speed. While it's running, repeatedly press the reverse lever all the way down. Run it for at least a few minutes.
Nov 14, 2009 | New Home MX-3123 Computerized Sewing...
Sewing machine only sews backwards
Make sure that the machine is in straight stitch forward and the stitch length is the highest level that it can go. If that doesn't make it go forward, you will have to use the old hair dryer trick. Take the top lid of the machine off and heat the inside with a heated hairdryer. Work the stitch length and the reverse until it frees up.
Dec 14, 2008 | Husqvarna Sewing Machines
Singer 3116 Simple Logo
638 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
