Question about Kenmore 63942 Dryer
Opened dryer door mid-cycle left open 1 hr. Dryer won't restart
Kenmore electric front load. 41/2 years old no previous problems. No excess lint build up.
  • 55beater Dec 31, 2008
    It is clicking and the light goes off. However, it still will not start.
    Problem Solver:
  • 13 Answers
There is a door switch on left upper corner of drier opening, make sure the little prong is clicking when you push it in. this turns the drier back on when the door is closed and the start button is pushed.
Posted on Dec 31, 2008
  • michael oden Dec 31, 2008
    if you have tried different cycles, then it probably is a start button, might be a loose connection or the button could have gone out,
Dryer won't start
First, with the door opened, push and release the door switch. Does the light go on and off?
Dec 07, 2012 | GE GTDL200EMWW 27" Front-Load Electric...
Dryer heats up, but does not dry clothes. Vent is clean
As you can see, your heating element has 5 heating coils. If one or more of these coils have opened you dryer will still work and heat but not at well as it would if all coils worked together. You can check each coil with an ohm meter to verify if one or more is open.
Jan 01, 2012 | Kenmore 64742 Electric Dryer
Kenmore 70 dryer smells burnt
There could be dust settled on the motor inside from the few years in storage. Unplug and remove back, with a hoover brush **** off all dust but do this lightly as to not disturb any connections.
Jan 04, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
My Kenmore dryer keeps cutting off
Vacuum all of the air passages including the hose to the outside vent. Remove the lint filter and wash it in hot water and detergent; rinse and replace after drying. Restricted air flow may be tripping an over-temp switch.
Oct 12, 2009 | Dryers
My dryer has been difficult to start lately especially if stopped mid cycle. The lights are all on but it won't start up. Today I only used it 2 times and it was very difficult to start after pressing many...
You may be experiencing "Heat Retention" by stopping your dryer mid-cycle, which you should NOT ever have to do! If you have a minor vent restriction or if you open the dryer mid-cycle when the heat is on, this will cause a disruption in the airflow and rising temperatures can keep the dryer from restarting until it has been cooled long enough.
Check your vent all the way to the outside for restrictions/obstructions every 6 months. Clean your lint filter after each load and DO NOT stop the dryer mid-cycle!
Note: Stopping the dryer mid-cycle can also cause severe burns and even melt polyester fibers.
Jul 05, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer will not restart
Sadly, the thermostats in your dryer control the heating circuit only. There is a thermal fuse that will not allow the dryer to start, but it's one time only and cooling down will have no effect.
The scenario you describe is the motor cutting out on it's internal overload. When it gets to the point where it cuts out on the overload mid cycle, it's unlikely cleaning lint will solve the problem. You might want a tech to come out and verify that the motor needs to be replaced.
Another possibility is o loose connection in the power source. This could be at the dryer terminal block, in the dryer cord receptacle, or at the circuit breaker.
May 04, 2009 | Dryers
Kenmore 63942 Dryer Logo
133 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De GO PATS
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
