Question about GE DCSR483EA Electric Dryer
Holes in clothes
Ge dvl223gadww is cutting holes in clothes
  • Anonymous Apr 15, 2009
    Same issue??!!! Holes in a triangular shape in lots of my sons nice shirts, getting frustrated!! Just purchased within this year!
  • 95 Answers
Be carefull not to overload and inspect around door and heat entrance area for catch points or sharp areas.
Its usually Washers that tear clothes inspect closly to determin cut or tear. if tear try smaller loads with only similar materials
Posted on Jan 24, 2009
Ge dryer makes holes in clothes
That is worn glides and bearing like in this video I made:
Oct 11, 2012 | GE Dryers
My dryer is getting a hold of articles of clothing right inside of the door (near the light) and when it does it is burning a hole into the clothes. There was a sharp piece of plastic sticking out in this...
Your glides is worn out and probably the bearing too. Easy fix:
themobilian_2346.jpgyour model number is to the right of the screwdriver in the first photo, These GEs use different parts per production run.
If yours is bad as i think it is you gonna have to replace the glides and the bearing they mount to.
May 11, 2011 | GE DBSR453EBWW Electric Dryer
My washer damages clothes
You should inspect the inside of the drum for damage or something stuck in the drum perforations. I have had exactly this problem and it was caused by the wire from one of my wife's bras coming out in the wash and getting stuck in the drum perforations.
Mar 01, 2010 | GE WSXH208A Front Load Washer
The water level switch on our GE washer is intermittent.
The only other thing I would do is to be sure the tube is sealed good where it hooks and doesn't have a tiny hole and take it off and blow through it To make sure it's clear.
Dec 13, 2009 | Kitchen Ranges
Dryer puts holes in clothes why
very care fully run your fingers along the inside edges of the tumbler both front and back
obviously your searching for something that is cutting your cloths so be care full it will cut you too
with the ge, i would tend to believe that your tumbler might be off or have worn though your front slides, they are made of nylon and fall out of place
check behind the door twords the top
Oct 25, 2009 | Dryers
GE Profile Top Loading Washing Machine Makes Holes in My Clothes
i know this may sound crazy but are you sure there is nothing lodged in the drum like a bra bone as this does happen,just a thoght give it a try,rgds,paul.
Jul 07, 2009 | GE Profile WPRE6100G Top Load Washer
Holes in Clothes
You'll need a drill with a wire brush attachment and take that to the front of the heating element. The heating element gets a lot of crud built up on it and yes it'll put holes on clothes.
Apr 02, 2009 | GE DWSR405EBWW Electric Dryer
GE Profile Electric dryer - not heat, damp clothes but tumbler works
first checkyour breaker it may not look like it is tripped but cut it off and on or maybe the thermo fuse or you element is bad you have to check proper voltage to parts
Apr 20, 2008 | GE Profile DPSB619ED Electric Dryer
Washer Creates holes in clothes
We purchace a washer and dryer in Dec 08 Kenmore HE energy star. They started destroying cloth about 2 months after purchace.
under our warranty and many many calls they sent a new set. 2 months later same problem. HELP
Nov 12, 2007 | Kenmore 98702 Stacked Washer/Dryer
GE top load Washer ripping clothes
Solution!
GE has replaced the "boot" (the large rubber gasket at the opening of the washer) on my washer. This has fixed the problem!
Although the majority of people I spoke with at GE did not know about this, eventually I got a repair technician out here who spoke with one of the engineers. The engineer said that there was a problem with the boot causing clothing to rip. The new boot we have on our washer covers a ring of plastic just on the outside of the metal drum (the plastic rim remains stationary while the metal drum spins - this is the cause of the ripped clothing) - the old boot left this plastic ring exposed. Our washer was only 8 months old - so even if your washer is new, if your clothing is being ripped, insist that the boot be replaced for an updated version.
May 03, 2007 | GE Energy Star WCVH6260F Front Load Washer
GE DCSR483EA Electric Dryer Logo
300 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
