i have a Alba 3406 TVD and is taken from U.K. and for that th sound is not working. I need a service mode cod that could allow me to modify the settings. How could I get that cod. Thanks!
Connect pin 1 & 5 together (momentarily with a small switch), on the remote control handset. with the tv already switched on, This will put the set into the engineering set up mode. You can step between the various options by using the -/-- button. the Mute button invites you to save your changes which I believe is saved when you next press the -/-- button. there are 18 different service pages in all, be very careful not to change things which should be left alone, as this menu controls the way this set operates. The menu button exits the service menu. I believe menu 13 should be the AV-SND options menu, you can select either DK-I-BG or M sound systems. only set one system to "on"at any one time. You may also need to check 14, the C- SYSTEM options Menu. Good Luck, A D.
hi i have a urc22b universal remote, and i need a code for an alba dvd recorder. can you help me...
(More)
hi i have a urc22b universal remote, and i need a code for an alba dvd recorder. can you help me please?
