Question about Niko OTP-3211W 32 in. LCD Television
NIKO 32 in
TV goes to power saving mode whem input VGA is selected.
I have ordered the owners manual for the Niko OTP3211W.
I'll let you know what happens when it arrives.
Posted on Jan 01, 2009
I have a lg flatron LCD w1934s-bn when I switch on the computer display coming and with in seconds monitor going in power saving mode. I change the VGA cable, change the system also same problem.
If your monitor goes into Power Saving Mode with different computers, it is most likely the signal input board in the monitor. I'm sorry to tell you your monitor is shot. It is probably repairable if you can find the correct board. Monitors are relatively inexpensive at the moment, and going by the "VGA only" input, it is time to upgrade, You will also get better resolution and picture quality.
Apr 20, 2012 | Computers & Internet
I have a Niko 1906w that wont run on it's DVI interface, only VGA. I believe I need a driver to install. I am having trouble finding any tech support for Niko I am running W7-64
Perhaps in the menu of the screen (buttons somewhere on the front or the side) you can select the DVI input.
If this does not work you have to check if the DVI interface of your graphics card works with another monitor. There are no drivers to install.
Mar 06, 2011 | Niko 1906W LCD Monitor
How do i connect my pc to my tv
Used the VGA cable came with ur computer monitor,used that VGA cable plug in VGA input it the tv and plug it other end to the computer video card.Used ur tv remote look for a input button pushes look for the mode computer signal in the tv like input 1,2,3..so on.
Feb 12, 2011 | Insignia 32" 720p Flat-Panel LCD HDTV
Trying to connect my inspiron 15 to my toshiba 32af44 and i can't get a picture on my tv. I have bought a pig tail that goes from VGA(the lap top side) to s-video/audio-video cables(tv side) but still...
A simple pigtail won't convert VGA to S-video. The VGA output consists of separate RGB lines and horizontal and vertical synchronization lines.
If you have an adapter that really converts VGA (this output has no audio path) to S-Video and audio lines, then you probably just need to re-select the input through the TV's menu system.
Nov 21, 2010 | Toshiba 32AF44 32" TV
I have a flatron w2253tq and have "analoge power saving "on. I cannot see the desktop
Is the monitor connected to the computer using a VGA plug (a smaller one, with 15 pins in 3 rows), or a DVI plug (wider one, with flat pins in 2 rows)?
From what you write, your monitor is switched to the analog input (VGA). It doesn't sense any signal on that input and hence goes to power down mode.
You need to go to your monitor's on-screen menu and select the digital input - you should see the picture then.
Jul 02, 2010 | LG 22" FLATRON LCD Monitor
Will not work at all
check for the power supply is locater at the back of the tv..you need to open the cover.the output power of the the power supply is 5vdc for the cpu and 12v-24dc for the backlights..visually inspect the components of the power supply.replace any burned capacitors and resistors..replace the secondary fuse with the same ratings..
May 17, 2010 | Niko SV3206 32 in. LCD Television
My tv turns off after I turn it on.
This is most likely because the TV is going into "Power Save" mode. It is not detecting any signal on the input it is set for. When you first power it on, make sure there is a signal to the input that you have selected. This normally takes about 30 seconds, but if the TV is set for the VGA input it can happen quite quickly.
Apr 09, 2009 | JVC AV-65WP94 65" Rear Projection...
I think my NIKO 26 inch LCD TV has the tuner gone bad. TV hangs everytime i turn it on, but when i take it out it works with other VGA input. where can i get a replacement tuner card for this TV?
I have pretty much the same problem. When I turnm on the set (Niko OPT-2613W) it is hit or miss whether it will work or no. Some times I get audio with no picture, sometimes the other way around. Sometimes I get sound and picture but no controls work (either the ones directly on the TV or the remote). When I turn the TV ON/OFF multiple times (switch next to the power cord) it generally reverts to working correctly until I turn it off when I'm done watching and then the process starts all over.
I consulted a TV repair shop and was advised that since it was an "off" brand they werent sure they could find the repair manual or parts. I don't want to toss it but it really isn't good the way it is. I haven't tried it as a computer monitor yet but I think it would be fine with VGA input. Unfortunately that's not what I bought it for.
Apr 03, 2009 | Niko OTP-2613W 26 in. LCD Television
How do you connect a...
If you use RCA cables from the dvd player set your tv to (line) or if your useing coaux cable try ch.3 or ch.4 your dvd might have a switch for 3or4
Dec 24, 2008 | Niko OTP-3211W 32 in. LCD Television
Stuck in power save mode
Have you have selected the input you are using? You can switch between analog and digital input. The monitor would stay in power save if the input other than the one you are using is selected.
I believe the default input is DVI. Are you using VGA?
In the menu, under advanced, you can select the input.
May 04, 2008 | Princeton Digital VL1916 19" LCD Monitor
Niko OTP-3211W 32 in. LCD Television Logo
191 people viewed this question
Top Niko Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Andrew Taylor
Andrew Taylor
Are you a Niko Televison and Video Expert? Answer questions, earn points and help others
