Question about HP Pavilion dv9000z Notebook
My HP NV900 doesn´t start
I was working on my HP NV9000, when suddenly it turned off and never turned on again. At the beginning I though there was a problem with de power supply, but after test it using a tester I realize that it`s ok.
Someone told me it could be a main mother problem, but the computer didn´t received any hit, and there wasn´t any voltage variation. It simply turned off like any other machine would do it when it´s energy charge fell down.
Pls help me with this problem.
  • mmdavila Jan 02, 2009
    I tried with the procedure proposed by rai55, but it did´t functioned!.
    Master:
  • 413 Answers
What i'm really interested in is the power supply. What you need to do is check and see if the power supply is sending anything out.
Posted on Dec 31, 2008
  • 120 Answers
Hi
First check the battery..
If u have warranty means u can claim it..
    Sergeant:
    Champion:
  • 258 Answers
Have you tried charging the battery?so we can pinpoint the problem
Phone frozen up wont do anything not even coming on
You could try a reset.
Hold both the Home and Power buttons until the iphone begins to start.
It should take about 10 seconds.
It this does not work, your battery may be low.
Connect charger and try reset again.
Additional help from Apple support page.
If your iPhone iPad or iPod touch doesn respond or doesn turn on
Feb 21, 2015 | Apple iPhone Cell Phones
INDESIT WIB101 WONT SPIN
Have you checked the lid safety switch? Even if it doesn't spin, the cycle timer will continue.
Nov 16, 2013 | Washing Machines
Sinotec LCD TV doesn't store channels anymore? It
The main system control memory IC to your TV is faulty. It should be replaced. It is a very small IC, having only 8 solder terminals, and can be located very near to the main system control IC. It will look some what like this, and will begin with a numner 24c**
May 26, 2013 | Televison & Video
HP dv6704nr power button doesn't work but quickplay/dvd start laptop, completely turns off if screen is beyond the cut off point no matter if it is in POST or in windows, and speaker doesn't w
i would take the button bar of and check to see if the cable is off to one side its a flat ribbon cable sounds like it is a little sideways that will make that happen there is a little clip be gentle undo it a little bit and straighten it out
Feb 25, 2013 | HP Pavilion dv6704nr Notebook
Mk4 gti vr6 has power but doesn't start, runs with pop start
Could be a number of things but may want to begin by checking wiring to starter, battery, or even the ignition switch. These components may not turn your engine light on.
Jun 17, 2017 | 2003 Volkswagen GTI
My Chamberlain 1/2 HP will occasionally only open the door half way, forcing me to manually open and close the door. But then it will suddenly begin working again all on it's own. What can I do abou
most likely there is a safety overload switch that will stop if the rollers on the track ( the steel that the door rolls in) is dry and needs to be greased so it can roll in the tracks freely also check the chain for the same, the chain drive should be free of any junk stuck on it ,the chain should not be to tight or twisted in any way, if it seems to be leaning one way or the other twist it straight with a pair of pliers also be sure its power source is not share with any other appliance. let me know of your progress.
Oct 21, 2011 | Chamberlain Powerdrive PD422D 1/2 HP...
Hello! I have a problem with the back of mamiya 645 AF....since few days, it doesnt work well....sometimes I have no problem, but otherwise sometimes the lcd screen of the back doesnt turn on....or if it...
Sounds like either a battery issue, or an issue with electronics. I'd first try checking/cleaning any electronic contacts between the body and the back. If that doesn't help, if you have access to another back try that to see if the issue is in the back or in the body (or both?). If that doesn't narrow it down, send the whole kit in to a service center or take it in to a local tech if you have one.
Jul 05, 2011 | Mamiya 645AF Medium Format Camera
Today, while watching tv on the Dish, tv suddenly started powercycling. I unplugged it, waited, and then tried a DVD -- worked fine. Tried Dish again, power cycled again -- on off on off, 1/2 second of...
If you are using a powerstrip may not be supplying enough power to run the LG HDTV and your HD receiver. If you are using a powerstrip make sure the receiver is plugged directly into the wall. Otherwise this may be a grounding issue please reply if this doesn't work and we can look into some other possibilities.
Daniel Busa
DISH Network
Customer Service
May 16, 2011 | LG 47LD520 47 in. HD-Ready LCD TV
Unknown problem
I would say your battery is fine. What happened is the computer was running off the battery even though it recognized it was plugged in. There is a piece in the power jack that tells the laptop that you are plugged in, but it doesn't necessarily mean the adapter is working. I would have the adapter checked to be sure it's working before I suspected the battery.
Jan 08, 2010 | HP Televison & Video
Where do i switch on the wireless on my laptop, COMPAQ NV9000
I was unable to find your model notebook, but most are turned via 3 ways:
1: Wireless Switch on the side or front of your pc.
2. You can do so from the control panel under wireless settings. (XP/Vista)
3. HP/Compaq Assistance software installed on your pc. This can be found by clicking on the start menu, and scrolling until you see something like "Compaq Utilities". Use this to configure and start your wireless network.
Goodluck,
C2Solutions
Aug 17, 2009 | Compaq Presario 2100 and 2500 ,NX 9000...
HP Pavilion dv9000z Notebook Logo
156 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
