Question about RCA D52W19 52" Rear Projection Television
Tv will not start up
Watchin tv one night the screen went blank now the set will not turn on at all. I let the set unplugged for a few days and it still wont do anything
    Genius:
  • 1,030 Answers
Does the front led flash. if it doesnt then you may have a primary power problem.. the fuse may have blowed,., this ussally means other componets have shorted IF the led flashes then you have a processor shutdown
Posted on Jan 01, 2009
It started 3 days ago the picture started getting darker and darker everyday then last night after turning the tv off which was off for several hours I turned it back on and a few min later there was a...
REPLACE THE LAMP IT IS LOCATED IN THE BACK OF THE TV THERE ARE INSTRUCTIONS IN THE OWNERS MANUAL FOR REPLACEMENT IT IS CONSIDERED CUSTOMER REPLACEABLE ITEM.
PART NUMBER 915B403001 Lamp (180W)
Dec 16, 2010 | Mitsubishi WD-65736 Television
My sony bravia tv will not turn on, the light on the bottom comes on but the screen is completely blank. i was watching it two hours earlier and i turned it off myself. than it didnt work when i tried...
Do you have...a dvd player a ps3 a box?
Becouse if you have, you need to change the input and maybe you forget to put it right back.
Imagine you have a ps3, you have to change the input from tv to HDMI right..well if stop play or watcha movie and torn off the LCD...when you came again the next day the LCD starts as HDMI and not as TV.
You need to change the input...
Hope it helps, if the problem persists it´s a malfuncion...
bye
Cyber
Mar 27, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
TV set was on normally, just went blank screen and
I fix this problem with CRT computer monitors alots when it was popular.Ur high voltage is dead, FBT,The flyback transformer,and the horizontal Transistor it dead.The FBT,the big block of plastic with a red wire with cap hook to Ur CRT,"H" transistor to the left steal square side wall.The problem is easy to fix,if u
have some basic sodering skill."H" Transistor is easy
to find.But FBT,it hard to find these day.If u want to tries to fix.Here are some websites might have the FBT for the Sony Tv. Shopjimmy.com,Tv repair World.com,Ebay.com.
Feb 04, 2010 | Televison & Video
I WAS WATCHIN TV THE OTHER NIGHT AND ALL OF A SUDDEN THE TV TURNED ITSELF OFF AND THE LITTLE GREEN LIGHT IN FRONT STARTED FLASHING VERY FAST -SO I UNPLUGGED MY TV AND THEN PLUGGED IT BACK IN AND THE GREEN...
Some of these sets if you unplug them---The green power light will blink for about 70 seconds before it stops--this is normal as the receiver unit in this set is booting up. Wait for the light to stop blinking and then the set should turn on. Some of these sets develop a problem where the light never stops blinking--usually the receiver is now bad--very expensive to get fixed.
I do this here for free so if this helps you give me a vote here.
SD TECH (San Diego)
Aug 28, 2009 | Mitsubishi WS-48515 48" Rear Projection...
Sony KDF-46E2000 - Screen Goes Blank
You definitely have a bad lamp. Sony rates the lamp life at between 4000 and 8000 hours. There are 3 things that effect the lamp life, listed in order of importance:
1) number of times the lamp is turned on and off. Every time the lamp is first fired, it takes life off the lamp. Customers I see that turn the TV on in the morning, leave it on all day and then turn it off on the evening can get up to 12000 lamp hours
2) ventilation. Be sure you have at least 6 inches of open space all the way around the set and that the vents are clear of dust and debris.
3) power. If the power is interrupted when the set is on, there cannot be a proper cool down cycle. The fans will run after you turn the set off to properly cool it down, if the power is lost this cannot happen. If your power is unreliable, buy a small UPS to let the set finish a cool down cycle
Occasionally a lamp will faill before the average lamp time due to being defective. from your purchase date it sounds like you got about average lamp time. Be sure to purchase AN ORIGINAL SONY LAMP as a replacement, becuase the aftermarket lamps are bad news, Be sure to rate this solution. Thanks!
Oct 13, 2008 | Sony KDF46E2000 46" Projection HDTV
Tv went blank
Does the timer/stand-by light blink at all? If so, count how many times it does. It will usually be in intervals. If it isn't blinking, and you have nothing on the screen, you might have a problem with the "G" Board, part # A1316499A.
C-Dog
Dec 16, 2007 | Sony KP-61V90 61" Rear Projection...
Unlocking the parental control
my jensen ts2750j screen turned blue and a red lock is in the corner... how do i get it off
Nov 06, 2007 | Jensen TS2750J TV
Tv is lock
i picked up the remote control an it lock the tv so i unplug it to try to rest it an u can turn it on at all
Feb 25, 2007 | Jensen Q2749J 27" TV
Rz1715 continually reseting
Charge it overnight then do a hard reset... You will lose any data or files that you have added, but if a hard reset doesn't fix it, you should return it to HP...
Sep 07, 2005 | HP iPAQ RZ1715 Pocket PC
RCA D52W19 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
