Question about Hotpoint  16.6 Cu. Ft. Top-Freezer Refrigerator
Freezer comparment will freeze OK, but fridge does not get cold.
Hotpoint HUT161 built under refrigerator will not cool down. Compressor appears to be running and so does the thermostat, what else could possibly be wrong??
  • s_ohara Jan 04, 2009
    Many thanks for your prompt reply. We have found the fan cooling the coil on the back of the appliance and it is spinning quite freely. I can't find any other as the rest of the fridge is all completely sealed. This would be the one you mean, wouldn't it?? Do you have any other ideas?
If the freezer is working properly, and the fridge is not, it is usually the evaporator fan. It should be located behind the back panel in the freezer. Usually, a fan blade is stuck, or the motor is stuck on it's bearing. You may need to reposition the fan or apply some oil to the bearing. If you cannot get the fan to spin, you might need a new fan motor. Check the voltage first before buying a new motor. You should get around 110V AC .
Posted on Dec 31, 2008
I keep getting water at the bottom of the fridge, under salad boxes on my Hotpoint fridge
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Jul 03, 2012 | Hotpoint-Ariston HS3022VL Refrigerator
Diverter valve on Hotpoint FFA70 recieves no power, Fridge ok
Bonjour..Your system check (hot cold) is correct. Generally all new refrig/freezers cool only the freezer & bleed cold air off to cool the refrigerator. Most diverter/airflow dampers I have seen are mechanically operated for simplicity & to keep costs down. I would unload freezer and pull the panel off where you see the fan mounted. Go slow, don't drop any screws.You may not get them back. Look at the drain pan under the evap. coil. If it has ice that is built up in layers. Suspect the defrost termination thermostat. If the evap coil is clogged with heavy frost, suspect 1 the defrost timer and 2 the defrost heaters mounted on the evap. coil. Let me know how you make out.
Parts http://www.repairclinic.com/Refrigerator-Parts?s=t-Hotpoint+FFA70-%3d%3da4&z=50
Jul 02, 2012 | Hotpoint FFA70 Bottom Freezer Refrigerator
Ge tfx25jrbb-ww refridgerator not cooling
The first thing to check is if you can hear the fan running inside the freezer. This not only keeps the whole freezer cold it alspo circulates air down to the refrigerator keeping it cool as well.
May 28, 2012 | GE Refrigerators
FRIDGE OK FREEZER NOTWORKING RED WARNING LIGHT ON
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 03, 2010 | Hotpoint RFA60 Bottom Freezer Refrigerator
Freezer is cooling, but refrigator is not cooling
take a look at your evaporator fan motor in the freezer to make sure it is running and not built up with ice around it. this fan motor pushes the cold air from the freezer into the fridge to cool the fridge. you say the freezer is "cooling" , is it freezing??
Oct 14, 2009 | Hotpoint Refrigerators
Hotpoint hss25gfphww refrigerator is not cooling on either side. All of the sudden freezer not freezing, fridge not very cold. Any suggestions? Fridge only 5 years old.
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Sep 08, 2009 | Hotpoint HSS25GFP Side by Side...
Hotpoint CTF15ELD top freezer refrigerator - freezer O.K. refrig too warm
It's likely the door was inadvertently left open, and the cold air passages from the freezer have built up enough ice that the cold air from the freezer has no way to enter the refrigerator. Check the cealing of the refrigerator. If you can see or feel ice in the passages between the freezer and fridge, you can probably solve the problem by finding a safe temporary home for your food, and leaving the refrigerator unplugged overnight.
May 25, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Freezer not freezing, refrigerator side not cold enough
sounds like compressor might not be running. pull unit out and remove bottom panel to access compressor area. beware of electrical wiring!!!! touch compressor to see if it warm. make sure fan motor by compressor is running.
May 07, 2017 | GE Refrigerators
Hoypoint ffa9op.defrosted
hotpoint ffa90, I have fridge and freezer problem, non of them are keeping the required temperature though the fridge temperature is showing the right temperature but not cold and the freezer is not freezing as it is contstant between -2 to -5 but it should be
-22, the fast freeze bottom does not fridge either, it does not take instruction.
Feb 01, 2009 | Hotpoint FFA90 Bottom Freezer Refrigerator
FFA60 Hotpoint fridge/freezer Red warning light
if i read the english right, the compressor runs but the freezer fan only runs for a short time. no fan then no cooling. there is a fan stat so that the fan only runs when the evap is down to temp. this may be faulty. also on some hotpoint, the fan switches off when door opened. check door switch operating ok. this may also explain problem with fridge lamp
Mar 11, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Hotpoint  16.6 Cu. Ft. Top-Freezer Refrigerator Logo
188 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
