Question about Hitachi 53SBX59B 53" Rear Projection Television
How do I Remove Front Cover Screen of Hitachi 53SBX59B53 Projection TV???
How do I Remove Front Cover Screen of Hitachi 53SBX59B53 Projection TV to replace convergence ICs? Problem: My TV picture bows down from the top and up from the bottom. I also ran a magic focus which stopped half way through, then a green 3 popped up! The picture is also out of focus. Next Steps: I plan to replace the following. . . [convergence ICs stk392-150], but can't gain access to front of TV? I am able to easily remove the speaker cover on front of TV as well as the lower rear TV panel, but the convergence board is located somewhere in front assembly. Also, I could not find the replacement part [stk392-150] at web site www.digikey.com Any help would be greatly appreciated. Thanks in advance.
  • Calevalley Oct 20, 2008
    I own the Hitachi 51F500A, and I need assistance in removing the Ultrashield protective cover. My daughter cracked the screen and unable to get a replacement part, so just want to remove it. Can someone please please help...Or if you may know where I can find the replacement part, part #KR03691
    Thanks!!
  • jmckay Jan 10, 2009
    I have water under the front cover screen and want to remove from the TV and clean it. I can not figure out how to remove it. Anyone know
Did you ever find the solution to removing the front screen? I have the same problem. Please write at superduper200554@yahoo.com
Posted on Jan 21, 2008
Removing screen from Hitachi Ultrasound TV
you take off the back cover all the screws down to the bottom and remove the speaker cover then remove the screws that hold the screen in on either side of the speakers and you should be able to remove it. I am not 100% certain that is how Hitachi does it but that is how my Sony is and my Panasonic was
Jan 10, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 50 inch how to remove screen cover'
Pull off Front speaker cover you will then see bolts holding face plate remove all screws then slide screen upward and Off.
HAPPY NEW YEAR!
Jan 01, 2009 | Hitachi 50UX26B/27K 50" Rear Projection...
Hitachi ultra vision, removing the front screen
Remove front bottom cover then remove all screws holding screen on Now slide screen up and out.
Dec 25, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Wasp inside Hitachi 50" rear proj. tv
Pull bottom cover off front you will see screws holding screen on remove all of them then slide screen upwards and OFF.
Nov 27, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
Replacement lamp
Remove the front cover from the TV set. This is held by a snap on. Pull the front cover outwards until the quick snap on disengages.
Remove the screw securing the lamp cover with a Phillips head screw driver
Remove the two screws that hold the lamp in place. Remove the lamp unit by holding the lamp handle, then pulling outwards.
Exercise caution when removing the lamp unit to avoid injury to your fingers
Replace with the new lamp.
Place the removed lamp into the empty box of the replacement lamp. Do not touch the front glass of the new lamp or its
receptacle. This may shorten the life of the lamp and reduce the picture quality.
• Push the lamp unit back to its original position.
• Tighten the screws firmly on the lamp unit. If they are loose, the TV may not operate correctly. Install the front cover. There is also a video on youtube just do a search on how to install a projection lamp. Hope this is helpful
Aug 22, 2008 | Hitachi 50V715 50" Rear Projection...
How to disassemble an old Hitachi projection TV (model 53sbx59b)
To remove the protection screen and lens from my Hitachi model 53SDX89BA:
1) Remove the speaker cover from the bottom. It is attached by velcro.
2) Remove the 4 screws on 4 plastic tabs on the bottom of the screen frame.
3) Remove the 4 screws on the 4 metal tabs on the bottom beneath the screen frame.
4) Pry the bottom corners loose with a wide blade screw driver and work both sides of the screen frame away from the case from the bottom up. CAUTION: The top does not snap away as the sides do. When the sides are loose let the screen frame hang down vertical and lift the screen frame straight up.
5) The protection screen and the lens will come off together.
When reinstalling the screen frame perform the steps in reverse. Be careful when resnapping the frame back onto the case - there are two small wooden support blocks on the bottom. Don't try to force the frame back on until you are sure the bottom of the frame clears these block. You may find it easier just to remove them temporarily until the frame is reattached.
Apr 13, 2008 | Televison & Video
Hitachi rear projection tv. screen looks green
Green CRT bad = take off lower front cover, remove access panel
locate screen / focus block.....turn green screen control slightly
CCW............................re-assemble...........T.
Dec 21, 2007 | Televison & Video
57S715 Hitachi HD RPTV protective screen removal & cleaning help.
Research at www.HitachiServiceUSA.com ...........
Generally, front speaker grill cover comes off , then
screen frame assy. off , then take apart, remove protect
glare screen. Reassemble ( keep same order - position )....T.
Please rate solution to problem........
Aug 21, 2007 | Hitachi 57S715 57" Rear Projection HDTV
Projection tv
Yes you can safely clean tv, just remove front speaker panel and you should see screws holding up front prot. screen. Becareful not to snap screws. You can take screen out and there is a mirror that you can clean and 3 lenses.
Apr 01, 2007 | Hitachi 50UX57B 50" Rear Projection...
Hitachi 53SBX59B 53" Rear Projection Television Logo
955 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
