Question about SanDisk Sansa e200 MP3 Player
Sansa E200 screen stuck scribbly black vertical lines
Screen is stuck on moving scribbly vertical lines going down. I cannot turn if off or change it. It is brand new. I just uploaded a few songs and was listening to it...I switched back to hear another song, and the scribbly lines showed up. Please help!
  • melly09 Jan 05, 2009
    Almost the same thing just happened to me. I was listening to a song and suddenly it just stopped playing. The vertical black lines appeared on the screen and then the background with the song title and everything just kind of faded away. I can't turn it of or do anything so I think i'm just going to wait until the battery dies, charge it, and then see what happens. Hopefully it'll work again :(
  • 31 Answers
When it is on, holding the power button in for 5 or more seconds hard resets the device. Give that a try. If not. it's possible it's been bounced one too many times and needs the LCD cable re-connected or the controller is bad for the LCD.
Posted on Jan 08, 2009
My sansa e250 gets frozen
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + (REC button for Sansa e200 series) button, and reconnect the player to the computer while holding the volume + (REC button for Sansa e200 series) button in. Keep holding the volume + (REC button for Sansa e200 series) button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Dec 24, 2008 | SanDisk Sansa e250 MP3 Player
SANSA E200 NOT SHOWING THE MENU SCREEN
Try to format the SANSA E200.
You can do this by simply holding down the Power/Menu button for about 15 seconds. After the reset, any changes you have made to the e200 during its last use will be lost.
PLEASE RESET USING THE RESET PIN PRESENT IN THE SIDE.
AND FORMAT THE PLAYER . if this dosen't work your player is faulty
Nov 21, 2008 | Computers & Internet
Cant switch to MSC on sansa e260
Try this instead:
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
-Tha Mp3 Doctor
May 21, 2008 | SanDisk Sansa e260 MP3 Player
Unrecognized devise and black screen
Change the USB cable Max problem is there in Cable Only
Tanx
Take Care
Bye
Apr 17, 2008 | SanDisk Sansa e200 MP3 Player
My sansa e200 can't load the title screen. What should I do?
i had the same problem and so does my cousin he said all you have to do is throw it
Mar 24, 2008 | SanDisk Sansa e200 MP3 Player
Sansa e 200
my sansa e200 is having some problems the ring is lite up but the screen is black i tryed alot of things nothing is really working can you please HELPPPPPP me pleaseeee
Feb 21, 2008 | SanDisk Sansa e200 MP3 Player
Not turning on
Mine is almost the same except I don't get the dots. The screen only works when it's plugged up to the computer.
Jan 28, 2008 | SanDisk Sansa e200 MP3 Player
No Drive on Connection
Hi, When i connect my sansa e200 mp3 player with my computer..it showing CONNECTED on the mp3 player screen, but does not show any disk drive in my computer. No problem with computer, my pen drive is working fine with it. can someone help?
Dec 08, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
