Question about Nintendo DS Console
Son's DS Lite will not charge or run with power supply connected. Tried another power supply, no different. When you plug in the charger the orange light comes on once and goes out.  Any suggestions?
  • Bancroft Dec 31, 2008
    My daughter's DS lite has the identical problem. ANyone out there know how to fix this? She got a DS lite kit for christmas with a charging docking station. Wonder if the problem could be related to this?
    Scholar:
  • 168 Answers
If the system is new enough than I would suggest taking it back to the store. If its too late I can fix it for you.
You have a faulty circuit or fuse in a circuit.
I can test and repair, standard work.
If you have any questions please contact me at
ninja_freak318@hotmail.com
Posted on Jan 05, 2009
I just got my touchscreen replaced and now my ds wont charge, when I plug it in there is no light or anything and it used to charge before they fixed it
If that DS has been opened by any tech, they are supposed to give warranty.
Bring back that DS to the one that repaired it and tell them that it was charging before you brought it to them, otherwise you could complain that some part have been( hopefully not ) replace mistakenly from another DS.
Hope that helps!
Nov 25, 2011 | Nintendo DS Lite Console
US Nintendo DS-Lite with converter problems in South Africa
It should work straight out with a step down transformer. That is of course if the mains supply in South Africa is 240 240 and the unit being American is 110.
This is of course not unless it was initially tried without a transformer or stepdown converter which would mean that the charger/adapter has been fried and therefore damaged.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 28, 2008 | Nintendo DS Console
Orange light flashes and wont charge
This usually means you either might have a faulty charger cable. Or it is connected to the wi-fi. I am guessing it is off. Try letting the ds run completely out of battery to the point where you cannot even turn it on. Then plug the cable into the ds first. Then plug the charger into a different outlet. Hopefully this solves your problem. Good luck :)
May 06, 2011 | Nintendo DS Lite Console
My son has a DS lite. It was working fine and now
possibly fuses have blown on the logic board, but it sounds like it needs a new one board.
Jan 07, 2010 | Nintendo DS Lite
Charge a DS lite without DS charger
turn your ds lite on, then realy quickly close the lid
Jul 20, 2009 | Nintendo DS Lite Console
Wont power on.
to/ Japiering
all you have to do is re-charger them with the plug.
p.s.the re-charger comes with a set.
from hannah .l
Aug 02, 2008 | Nintendo DS Lite Console
Nintendo DS Lite will not charge
GET A NEW CHARGER HAPPENED TO ME BEFORE my bad caps lol
Jul 18, 2008 | Nintendo DS Lite Console
Ds lite charging lite comes on but when i press power button nothing happens
Are you leaving the DS charge until the light comes off? Remember that there are two likes too, one for charging and one for power. If you're just charging for some random period of time (lets say... One hour) then your Battery isn't going to be fully charged. The best way to ensure that your DS Lite is charged is to leave it charge until the charge light turns off. You can play your DS Lite while you are charging (I do it all the time), but it just means that you're just running off of the outlet.
A good test is to charge it fully (until the charge light comes off), unplug the charger cord (Make sure it's secured tightly to your DS while charging), then play for a little bit, your light should be a normal color (green).
If you cannot even play by using the outlet, then you need to
find a charger cord that actually works (You may need to send in the charger for replacement). If the same thing happens with 2 different batteries (assuming that you have two official Nintendo batteries).
TIP: Also run your fingers across the Charger cord. You're going to get a slight friction burn from the rubber, but you're going to get all of the kinks out of the wire in the cord. My charger cord had a similar problem (did not charge all the way, only charged until I moved the DS) but when I ran my fingers across it (pinching) it worked again.
Also check the pins in both charger cords, charging will not work if one pin is missing, nor if any are bent.
May 12, 2008 | Nintendo DS Lite Console
Power problems with DS Lite
Really sounds like a dead battery. The DS will not work if the battery is bad even when it's plugged in. You get the quick flash of the power light and that's it.
Mar 29, 2008 | Nintendo DS Console
Nintendo DS Console Logo
124 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
