Question about GE WBVH6240F Front Load Washer
Sour odor the machine gets a sour smell, like leaving wet clothes in it but it is empty leaving the door open helps some
    Problem Solver:
  • 12 Answers
I fixed the bad odor problem once and for all!
This problem is caused by mold and mildew growing in a large ventilation hose that runs from the top of the wash drum to a large vent hole in back of the machine.
To correct this problem you can buy a kit from http://washerfan.com/ or do the cheap fix like I did.
Step One: Find the vent grille on the upper left corner of the machine. Remove the machine top, only a couple small screws hold it on.
Step two: Remove the hose clamps that hold the hose to the drum and grille then snap out the plastic grille.
Step three: The grille is convex so I used a belt sander to make it flat then I took a computer case fan that was the same size as the grill and hot glued it to the plastic grille. I wired it to an old 12 Volt phone charger (12V 500 Ma) and made it blow air INTO the vent.
Step Four: Put everything back together and enjoy a stink free washer because the mold can no longer grow in that hose.
Note! You must bleach, clean and scrub that crud out of that large vent hose and it is some kind of gross! If you're allergic to mold please wear respiratory protection. My fan has been blowing air into the washer 24/7 for six months and I have seen those case fans run non stop for years. It it dies just snap the hot glue beads and put another fan on it. Total cost for the entire fix, about $10.00
Posted on May 08, 2014
  • 370 Answers
Buy affresh washer cleaner. its around 10 bucks and it cleans the inside of the washer and all the internal hoses. It works great! I am service tech in grants pass oregon and i use it on all the washers in the shop with no complaints.
Posted on Jan 28, 2009
Clothes are sour after wash
The odor is being transferred from your washing machine. The washer must be cleaned first or the clothing will be reinfected upon washing.
The problem area is always just above the normal waterline where suds and soiled water splash up and don't get rinsed out.
To clean your washer add 1 cap of smelly washer cleaner to a full load of laundry in a hot cycle. The added bulk of the laundry will raise the water level to include the "splash area". Intermittent pausing to soak is a good tip for more extreme problems.
Jul 06, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
My front loading washing machine has a musty odor. what can I do?
The odor that you are experiencing may be from the growth of mold. Inside the washer, some small pools of water may be left standing and is harboring mold spores. Even though you may operate the washer regularly, the mold spores are not being washed away.I have a couple of tips that might help to eliminate odor issues in your washing machine. First, and the most effective in my research is to, leave the lid, or door to the unit open. By leaving the door open, it promotes air circulation and evaporation of standing water. The reduction in odor, will occur quickly and dramatically.
My second tip is to run the washer empty for a quick rinse cycle(on hot water cycle). Add an entire cup of bleach at the start of the cycle. The bleach is effective at destroying organisms, such as mold and bacteria. However, running it once will not be completely effective. I suggest pouring another cup of bleach into the wash tub, after the cycle has completed. This will leave bleach as the standing pool and should prevent the growth of mold or bacteria. However, if you do this, before doing a load of laundry you should run an empty rinse cycle again, to avoid damage to the clothes from the bleach left standing in the wash tub.
  • Additionally, inspect the door gasket for gunk or mold. Clean the gasket well. This is another gathering spot of bacteria and mold growth.
Jun 28, 2010 | Kenmore Washing Machines
Bad smell when starting a new load the next day
These are some good tips. However, leaving the door open between loads decreases odor by drying out the residue which can make the residue difficult to remove. Also, the residue will affect the next wash load.
The only way to have a truly clean washer is to remove the odor-causing residue. The "splash area" just 3-5 inches above the normal waterline is where the worst buildup is. To clean the whole tub use a washer cleaner that is able to be used with clothing in the washer. The added laundry will raise the water level to include the splash area.
There are many washer cleaners on the market. Some are all natural and can be used with laundry to safely clean inside the washing machine. After you get rid of odor you'll need to change your washing habits so it doesn't come back.
Apr 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine smells like stagnant water...making clothes smell bad as well. No visible water laying anywhere
My second tip is to run the washer empty for a quick rinse cycle. Add an entire cup of bleach at the start of the cycle. The bleach is effective at destroying organisms, such as mold and bacteria. However, running it once will not be completely effective. I suggest pouring another cup of bleach into the wash tub, after the cycle has completed. This will leave bleach as the standing pool and should prevent the growth of mold or bacteria. However, if you do this, before doing a load of laundry you should run an empty rinse cycle again, to avoid damage to the clothes from the bleach left standing in the wash tub.
Oct 31, 2009 | Electrolux EIFLW55HIW Front Load Washer...
There is a moldy smell....I have ran a load with no clothes and just bleach and it smelled ok for a week and now smells again
My second tip is to run the washer empty for a quick rinse cycle. Add an entire cup of bleach at the start of the cycle. The bleach is effective at destroying organisms, such as mold and bacteria. However, running it once will not be completely effective. I suggest pouring another cup of bleach into the wash tub/basket, after the cycle has completed. This will leave bleach as the standing pool and should prevent the growth of mold or bacteria. However, if you do this, before doing a load of laundry you should run an empty rinse cycle again, to avoid damage to the clothes from the bleach left standing in the wash tub.
Oct 24, 2009 | GE WSXH208A Front Load Washer
Can't get rid of odor on clothes and washer I have run the bleach through as suggested in manual,have used very hot water and I leave the door open when not in use.PLEASE HELP!
in order to get the odor out of the clothes, you first have to fix the washer. it is likely a build up of soap scum which is smelling. are you using the correct soap for you front loader? HE soap. there is a product on the market called Afresh, a package of 3 tablets. buy some and use all 3 in the machine and run it empty. then follow the directions on the pack for monthly maintenance.
Oct 16, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Sour odor. Even though I take my clothes out right away.
The problem is that water sets in a filter area below the tub and sours, or smells like raw sewage. This is common on most front loaders, Whirlpool makes special tablets used in washer to take out the odor.
Jul 21, 2009 | Maytag Neptune MAH5500B Front Load Washer
Odor in clothes
run an empty load in the washer but add 3 cups of vinager and set the washer to hat wash, this will help kill the smell, After you get done running it leave the door open this will stop it from happening again
Jul 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Clothes come our smelling bad
Run a load empty on the hottest setting with a cup of bleach.
Then, after finished using the machine each day, leave the door open for a few hours to allow the rubber seal to dry.
Jun 30, 2009 | Zanussi FLA1001W Front Load Washer
Water Remaining in Gasket Around Door
normal problem all front loads all brands.. leave door open as much as possible.. to clean fill tub with hot water pour in 2 cups chlorine bleach use rag in solution wipe gasket out as good as possible allow washer to run normal cycle ..do as routine when ever odor is first noticed leaving door open will allow most of water to evaporate
Nov 19, 2008 | Kenmore Elite 45986 Front Load Washer
GE WBVH6240F Front Load Washer Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
