Question about Whirlpool Duet GHW9150P Front Load Washer
We get an error code of f 11
The machine starts up fine but then the code appears
  • Anonymous Jan 01, 2009
    THe washer starts up and runs but then will not finish cycle. It comes up with the letters H F . Can you help with the code?
  • mrab447872 Mar 20, 2009
    i have the same problem if anyone is interested i will sell them a new computer. It is new and i cant return it it sells for around $200 i will sell it for $125 e mail me at mrab447872@aol.com i also have a door lock.
  • 76 Answers
You have 2 boards on a duet, one is the main computer, and the other is the motor control board, your unit is having a communication problem between the two. you will have to try to see if a wiring harness between the two has jiggled loose. disconnect them, then reconnect and see if that helps. The main board is on top, directly behing the display( remove top panel to access), the motor control board is below(remove basedoor to access that one). if that doesn't help, get your checkbook ready
Posted on Jan 01, 2009
Machine is starting to show error codes, ie Dlr door lock and code #11
Do you mean F11 code? The Problem may be a communication error between the Central Control Unit (CCU) and the Motor Control Unit (MCU). You need to check the connections between them and verify that nothing is loose. I don't have a service manual for this type of front loader but if you have access to one it will give you a protocol to follow to verify which part is the most likely to be causing the failure.
Feb 10, 2015 | Kenmore Elite 45986 Front Load Washer
The washer stopped in the middle of a wash cycle. The error message was 11 F. I turned it off and turned it back on and washer stilled stopped and repeated the error message.
Hi
An "F-11" error code on a Whirlpool Duet could cause your washer to become inoperable and stop in the middle of a load. The cause of the problem could be a number of things and may require new parts.
F11 can mean anything from motor to motor control board to ccu board to wiring harness connecting ccu to mcu to motor.
Identification
The "F-11" code could appear with the dash or without the dash on the LCD screen. Be aware that there is also an "F-H" code that could look similar to the "F-11" code. Listen for 11 beeps to go along with the error code's first appearance.
Effects
The error means that there is no communication between the "Motor Control Unit" and the "Central Control Unit." This means that any operation selected like "Pre-wash" or "Large Load" cannot be sent to the motor for the washer to operate.
Prevention/Solution
Open up the washer panel to check the wire connections between the two units. If any plugs are loose or unplugged, reconnect them. Check to make sure none of the wires are stripped, rusty or broken off. After you reconnect the wires, rerun the washer to see if the error appears again.
Warning
If you do not know or understand the inside components of your Whirlpool washer, leave the job to a professional. Contact the store where you purchased the washer or Whirlpool customer service directly.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The machine starts then stops a few minutes into cycle and the code "F" flashes then "H" flashes? What is the problem? DW 7/31/11
Hello & Welcome to FixYa
FH error is displayed when the control detects no water entering the machine. To clear this error press and hold the PAUSE/CANCEL button twice. You can then check if the water inlet valve is fine and not clogged with foreign particles, try to clean it. If the water inlet valve appears to be fine then check if the pressure switch hose is properly connected to the pressure switch & tub. Please get back to me if you have any questions.
Kevin
Aug 01, 2011 | KitchenAid KHWS02R Front Load Washer
Why does my kenmore front loader washer get the f 11 code and stop what can I do?
Hi
Thanks for using FixYa. Error F11 is a communication error between the central control unit (CCU) and the motor control unit (MCU). To start with check the wire harness connections between CCU and MCU, and then check the motor. If both of them appear to be working fine then it seems that the MCU of your washer has gone bad as the control unit seems to be working fine. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 26, 2010 | Kenmore Elite 45986 Front Load Washer
Wash machine is beeping code "F 11"
Hi
Thanks for using FixYa. F11 is a communication error between the central control unit (CCU) and the motor control unit (MCU). To start with check the wire harness connections between CCU and MCU, and then check the motor. If both of them appear to be working fine then it seems that the MCU of your washer has gone bad as the control unit seems to be working fine. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 06, 2010 | Kenmore HE2 Plus Front Load Washer
GHW9100LW1 F-11 code right afer it starts
Hi
Thanks
Rylee
Jul 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code 11 on primus rs16
Error 11 is a water pressure or inlet problem. Check the 1st stage filters in the cold water hoses at the back of the machine.
Mar 03, 2010 | Washing Machines
F 11 code appears on my duet washing machine?
erial Communication Error Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
  • good luck
shaun
Aug 23, 2009 | Whirlpool Duet WFW9550 Washer
F 11 error code on whirlpool duet washer.
Serial Communication Error
  • Check MCU
  • Check CCU
  • Check Motor
this is for error code f 11
thanks.
May 02, 2009 | Whirlpool GHW9400 Front Load Washer
Kenmore he4t washer shows f-11 error
F-11 // WILL THEN APPEAR FDL CODE DOOR LOCK LOCK FAILURE, F-11 COMMUNICATION ERROR REPLACE MAIN CONTROL,, JUST REPL 3 TODAY ....
Nov 28, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
60 people viewed this question
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
