Question about Sakar Kidz Cam Digital Camera
Whener I press Get Photos it says Digital Camera not Found
I can do all the stuff on threre like story maker,frame maker and everything, but i can't import my photos in my folder
  • mysteriofan Jan 07, 2009
    nevermind i found out how to do it thanks for trying though
  • 716 Answers
Did You Restart Your Computer After Install?
Posted on Jan 05, 2009
How do i download pictures to tablet
Pandigital photo frames are an ideal way to display your collection of digital photos. You can view photos with or without a computer using just a memory card, but it's always a good idea to transfer the photos you'll want to view frequently to the internal memory of your frame. This is also a handy way to back up your favorite images.
  1. Transferring Photos from a Memory Card
    • Your digital photo frame's built-in software will recognize six types of memory card: CF I/II, SD, MS Pro, MMC and XD. Locate the slot on the back of the frame (to the left of the stand) that corresponds with your type of memory card. These are labeled as follows: SD/MMC/MSPro/XD, CF I/II, USB and mini USB. Insert your memory card into the appropriate slot, power on your digital frame, and it will automatically begin a slideshow using every available image on your memory card. Note that only JPEG formats under 16 megapixels are compatible.
    Transferring Photos from a PC
    • Use the USB cable that came with your frame. Connect the mini USB end to the mini USB port on the back of your frame; connect the large USB end to your computer's USB port. Double-click the "My Computer" icon on your desktop or in your Windows "Start" menu. You'll see that your computer has automatically assigned a drive to your digital frame---look for a device called "Removable Disk" followed by a letter (Removable Disk E:, for example). This is the folder that represents the internal memory of your digital photo frame; you will be dragging your photos into this folder.
      Next, open the folder in which you store your photos ("My Pictures," for example). Select the photos you want to transfer to your frame. Drag them to the drive associated with your digital photo frame---this is the "Removable Disk" drive you located within the "My Computer" folder. Every photo you selected will then be copied onto your digital frame.
      After the files are copied, disconnect your digital frame properly. If you don't, your frame's internal memory could be damaged. Look for the system tray in your desktop's lower right-hand corner. Left-click the icon that shows a gray box with a green arrow on top of it. Select "Safely Disconnect Hardware." A dialog box will appear, asking you to select the device to disconnect. Select the digital frame and click "OK." When the dialog box appears, click "Close." You'll see a message in the lower right hand portion of your desktop telling you it's safe to disconnect your frame.
    Copying Photos to Your Frame's Internal Memory
    • You can use your frame's remote control to copy photos from your memory card or computer to the photo frame's internal memory. Connect your photo source (computer or memory card) and have your frame's remote control handy. Access the "Home" screen on your frame using the "Home" button on your remote control or by pressing the "Home" button on top of the frame. Next, choose "Photos" and press "Enter." You'll see all your photos in thumbnail form. Scroll through them with the up and down arrows. Press the "+" key to mark photos you want to copy (use "-" to de-select a photo). When you've selected all the photos you want to copy, press "Set Up," then "Copy Photo," "Enter," "Selected" and "Enter." A dialog box will ask you to confirm your selection; with the cursor on "Yes," press "Enter." The photos you selected will be copied to the frame's internal memory.
Dec 04, 2011 | PANDIGITAL 7270FW Tablet
My camera is saying 'Frame No Full' and wont let me take photos?
Do the following procedure to fix this problem.Save all pictures to your computer turn camera on, press the menu/ok button, select Setup, press ok. Select frame number and change frame No. to renew, press ok.
  • Leave Setup.
  • Press the menu/ok button, select Setup, press ok again.
  • Select Format, press ok / ok until the card is formatted.
  • Now the counter should start over with 100.0001 again.
  • Set frame no. back to Cont. to avoid to many images with the same filename.
Thank you !!
May 30, 2010 | Fuji Finepix Z20fd Digital Camera
How can I remove
Switch on the camera. Press the button to open the frames for viewing. Select the frame you want to delete by moving frames using left/right direction keys on the control. Press the function key. In the display on the screen you will get option to delete a frame and delete all the frames. Select delete this frame. Similarly you can delete the other frames.
May 19, 2010 | Kodak EasyShare C330 Digital Camera
My memory card is completely empty, all photos
You need to reset the file-numbering.
Turn mode-dial to Set and turn on the camera. Select Frame No. from the setup menu. Switch Frame No. to Renew. Press OK. Format the card (also from the Setup Menu) After formatting, select Frame No. againg and switch to Cont. File numbers will now start from 100.0001 again
May 10, 2010 | Fuji FinePix S7000 Digital Camera
!FRAME NO. FULL
Save all pictures to your computer.
Turn camera on, press the menu/ok button, select Setup, press ok.
select Frame No., change Frame No. to Renew, press ok.
Leave Setup.
Set Frame No. back to Cont. to avoid to many images with the same filename.
Feb 22, 2010 | Fuji FinePix S5700 Digital Camera
New xD M+ card won't work in the digital photo frame.
Alot of the digital photo frames will only display images up to a certain resolution. There is a good chance your camera resolution is too high for the photo frame. try change the settings on your camera to 3mp or so and take a few photos and see if they will display.
Jun 16, 2009 | PANDIGITAL 7-Inch Digital Photo Frame with...
I can't erase
Follow these instructions, but before you do, please be sure you have saved your images off the disk prior to starting these steps.
  1. Press Menu/OK to display the playback menu.
  2. Press Up/Down to select FRAME or ALL FRAMES. Choose ALL FRAMES.
  3. Press the Menu/OK button again while ALL FRAMES is selected to confirm deleting all photos.
Please select FIXYA, thanks.
Jan 16, 2009 | Fuji FinePix A500 Digital Camera
My fujifilm a800 will not let me take any pictures, saying 'frame no full' on the screen. please help
I've just had the same problem. You need to reformat your memory card (make sure you download your photos first as it will erase everything on the card). Then go into the set-up part of the menu on the camera. In there you should find the option -FRAME NO. This will be set on continuous. Select the option that says RENEW. This will reset the frame number counter. Once you have done this go back into the FRAME NO menu and set it back to continous. You can now start taking photos again as the counter has been reset.
Sep 02, 2008 | Fuji FinePix F11 Digital Camera
When the camera is switched on there is a message saying "FRAME NO. FULL". The memory card is empty - what is wrong with the camera?
Hi. I hope you have solved this by now. I've just had the same problem. You need to reformat your memory card (make sure you download your photos first as it will erase everything on the card). Then go into the set-up part of the menu on the camera. In there you should find the option -FRAME NO. This will be set on continuous. Select the option that says RENEW. This will reset the frame number counter. Once you have done this go back into the FRAME NO menu and set it back to continous. You can now start taking photos again as the counter has been reset.
Jul 19, 2008 | Fuji FinePix Z5fd Digital Camera
Convert a video to still life photos
Yes, you would need to use video editing software, IE windows movie maker, nero etc. and capture the frame you want as a still photo, then save it.
Feb 19, 2008 | Konica Minolta DiMAGE Z1 Digital Camera
Sakar Kidz Cam Digital Camera Logo
223 people viewed this question
Top Sakar Cameras Experts
Robert
Tony
Are you a Sakar Camera Expert? Answer questions, earn points and help others
