Question about ASUS A8N32-SLI Deluxe Motherboard
Sli switch card causing graphical corruption need a new 1
Hey guys, iv posted this link to a reply but wanted to put it here in unsolved issues for all to see. http://estore.asus.com/shop/item.asp?itemid=230&catid=135 That link shows the exact part i need however i cannot order it from that site as its for american/canadian users only. If anyone knows where i can get this part in the UK you are saving me buying a whole new motherboard. Thanks in advance humpfrey
  • ASUS Master
  • 12,061 Answers
Have you tried Ebay? Try contacting that site and ask for supplies in UK? OR contact ASUS UK and see if they can help.. Thats about all I can think of.
Posted on Jul 30, 2007
Which card is better for gta iv? i want to buy a low price graphics card i have to option 1) Inno3d 8500gt (512mb 128bit ddr2) and another one is 2)Asus 8600gt (256mb 128bit ddr2) can any one tell me which...
I recommend you to buy ATI 4670 instead since it is much more powerful than you listed above & now the price should be around $64+
It is much better for GTA IV than those you listed.
Mar 25, 2010 | ASUS GeForce 8600 GTS, Graphic Card
Beep Codes?
This board has been known to have some issues, the Asus' PEG optimizations aren't fully supported by some video cards like the Gigabyte GeForce 6600 GT. One example of a fully supporting video card is the Asus Extreme Radeon EAX1900XTX.
If possible, try using a different video card (one that supports
Asus' PEG optimizations - PEG Link Mode overclocking feature; PEG Link for single/dual graphics cards ). Or you may want to try and disable the PEG entirely.
Hope this be of some help/idea. Pls post back how things turn up or should you need further information.
Good luck and kind regards.
Oct 21, 2007 | ASUS P5ND2-SLI (890552603831) Motherboard
Need m2n sli drivers..help?
Your SLI drivers as you mentioned were installed when your chipset drivers were installed. (NVIDIA nForce CK804 Chipset Driver).
If you use 1 PCI-E graphics card the bios will need to be adjusted to [Auto].
Using 2 PCI-E graphics cards you must install the EZ selector card correctly. See page 4-20 section 4.4 Adjust; SLI Configuration. Than see section 4.4.6 in your manual
Open the Asus link below if you need drivers for your M2N-E SLI;
http://www.asus.com/Search.aspx?SearchKey=M2N-E%20SLI
This may seem a bit tricky but its not. First time around the bios settings using SLI graphics cards will appears tough but you'll get it.
Cheers!
Mike
Oct 16, 2009 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
1long 2 short beeps, No POST/Visual display
Hi there
One Long and Two Short Beeps = Video (Mono/CGA Display Circuitry) issue.
If you are using a PCI Express graphics card remove it and use the on-board VGA/DVI port
If it is the on-board graphics you are using clear the cmos
d015d7b.jpg<<<<< you will see in the picture a plastic jumper (in this case coloured green), move it to the other position and hit the on/off button, then put it back in its original position and power up the machine again. Hopefully the issue will have been sorted.
Good luck and thanks for using Fixya!!
Feb 18, 2009 | MSI K8N Neo4/SLI Motherboard
Have abit - kn8 put 2 gig memm in powered up no picture think I have wrong video card do you know proper one
Hey there,
As per ur question, this problem occures due to following reason:
1. When ur data cable of ur monitor is bad : Try another data cable this causes only to blink LED of ur monitor which not allows any graphics to display.
2. Your RAM can also be responsible for this problem: If your RAM goes Bad then it doesnot allow any graphics file to load and thus causing not to display anything on ur monitor screen as well as ur system keep restart at POST (Power On Self Test) Operation (When VRAM driver is not loaded.
and the last reason is:
3. Your system is not able to recognise your Graphics card due to Either IRQ inteferance or ur graphics card hardware problem (caused due to bad of VRAM installed on ur graphics card): Remove ur graphics card from expansion slot (PCI-E/AGP)and then plug monitor data cable to normal serial port available in the motherboard (Resides back side of ur system).
Thanx
Gimme ur acknowledge by rating me.
Romy Decostza
Dec 24, 2008 | Abit KN8 SLi Motherboard
Graphics card no display, not recognised
Hi DarkPredUK.
You need to check you're bios. (See below).
The PCI-E card (Single video card) must be placed into slot, PCIEX16_1 as shown on page 2-3 & 2-18 in you're user manual. The bios must be set correctly as seen on page 4-26 to PCI-E first. You must have two PCI-E cards installed to run SLI mode. (They must be exactly the same graphic cards).
Asus M2N-E SLI main web site/drivers, manual ect.
http://support.asus.com/download/download.aspx?modelname=M2N-E%20SLI&SLanguage=en-us
Good luck DarkPredUK.
Need more info? Post it here or click the Ask Me.
Mike
Jul 11, 2008 | Computers & Internet
System wouldn't Boot
If your CPU or memory were an issue your Asus board would sound off with BIOS beeps. Asus uses the Award BIOS & you can see what these beeps mean at the link below. Regaurding your PC not able to boot is an issue with your PCIE/PEG video card-in relationship with BIOS setting & the SLI switch card mode that came with your board. When running 1PEG video card you must set this in the BIOS to Auto & you need your SLI switch card connected in its slot. By default, the EZ Selector card is set for a single graphic card. When you install dual PCIE graphic cards on A8N-SLI series motherboards, please make sure EZ Selector card set to the Dual Video Card side and properly inserted. Link to Award Bios beep codes: http://www.bioscentral.com/beepcodes/awardbeep.htm
Will come in handy.
Reading the FAQ's at Asus site will help you better understand your A8N-SLI Deluxe. You'll need to fill in the, "Please Select the Product" first: http://support.asus.com/faq/faq.aspx?SLanguage=en-us
Dec 05, 2007 | ASUS A8N-SLI Deluxe Motherboard
ASUS P5N-E SLI AND A GF7600 ..BOOTING PROBLEMS ..CORRUPTS
Hi, trying to boot from your old drives is the problem.
The Boot sequence for your new board are different from the ol one. Your sequence to get your system going is to load the mobo drivers first, then run your XP disk again and at the second prompt select REPAIR this will run the same as a normal install but should save your existing data and settings.
One problem you may have is activating XP as Microsoft do not approve of multi installs and the new board will show as a different computer.
Regards mistyman
Nov 29, 2007 | Intel Motherboard
NX7800GTX-VT2D256E and MSI K8N Neo4/SLI
What's the specs on your power supply. For SLI you need a good quality 500W+ PSU with lots of current on the 12V rails. Remember that all the drives, memory, fans, cpu, etc will use a lot of power, if there is not enough capability in your PSU, the voltage may drop low enough to stop it starting up.
Nov 22, 2007 | MSI NX7800GTX-VT2D256E Lite GeForce...
ASUS A8N32-SLI Deluxe Motherboard Logo
100 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
