Question about Bosch Exxcel WFO 2465 Front Load Washer
Washing Machine fills and emptys but does nothing else.....
A few weeks ago my machine was smelly and not spinning, it was recommended to me to do a hot cycle with some bleach in. This has made it work ok for a little while and at least took the smell away. Now the machine fills and emptys but doesn't do anything else. The drum doesn't turn at all. Help is really needed I have 3 kids under 5 all getting dirty.
It could be because the motor brushes are worn?
Posted on Aug 11, 2008
Sounds like the drum belt has come off the pully or at worse broken.quite simple to mend.good luck.
Posted on May 05, 2007
I have an Electrolux EW Aqualux 1200. Two weeks ago a sock was stuck into filter. I removed it, switch off/on machine a few times, ran machine empty. However since then machine is spinning only if it is...
9 years a good life for Washing Machine, I can't see why you have this problen , since you cleared it by taking sock out of filter, but expensive to get repairer to look at it , as 9 years old , get a new one . Better than spending money on a repair,
Mar 14, 2015 | Electrolux Washing Machines
I have a Whirlpool Ultimate Care II washing machine, model number: LSQ9110PW3 that stopped working properly two days ago. At first it seemed to not be able to go into the spin cycle. However, I just...
You have one of the best washers ever made... It is called a "Direct Drive" by us technicians. You probably need this part, but NEVER get rid of this machine as NOTHING out there is this good- not for anyprice. https://www.repairclinic.com/PartDetail/Whirlpool-Washing-Machine-Motor-Coupling/285753A/1195967?modelNumber=LSQ9110PW3&ss=a11b5d654521&mr=1
Apr 07, 2017 | Whirlpool Washing Machines
Smelly clothes after washing. We have one of the models that was recalled for the same problem. Maytag Neptune - MAH6500AWW
I have this problem with my Siemens machine, it is due to mainly running low temp washes and bateria building up in the hoses etc. (more prevalent if the machine is connected directly to the sink and not on a stand pipe). I run a 90 degree cycle every 4 weeks with the machine empty except for two capfuls of baby sterilisng fluid (approx half a mug) I buy stores own as it is cheaper than miltons. The first time I did mine I ran the cycle twice to be sure it was cleared out. My machine is six years old and the first smelly signs were when it was about a year old, I run the maintenance wash religiously ever 4 weeks and run a machine descaler such as oust thru every 4-6 months. Hope this helps. Roni. (ps don't be tempted to use bleach as it foams up and can cause more problems!!)
Jan 12, 2010 | Maytag Neptune MAH6500A Front Load Washer
Bad smell inside drum and when draining also makes laundry smell
Recommend running it through empty (and without soap) on a long, hot wash cycle a couple of times.
Modern cool cycles don't always wash away all the detergent, and the machine fills up with smelly grey sludge after a while.
A.
Aug 01, 2009 | LG Washing Machines
Smelly drain and wont spin properly
check filter may need pump then flush through on hot wash.
Jun 29, 2009 | Washing Machines
The washer will not drain or spin
more than likely the pump needs replacing, first of all remove the outlet drain hose from the the place it discharges and lower it into a bucket,this should allow it to syphon away,you may need to empyt the bucket a few times once the machine is empty you should be able to put it on its spin cycle once it has spun locate and remove the filter to remove any objects or lint, fill machine with warm water and try to drain and spin via the programme,if this do not work fit a new pump
May 29, 2009 | Kenmore Washing Machines
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Washing machine won't drain
replace the lid switch. that's what i have to do with mine. i researched it a few weeks ago. Simple cheap fix - i think it was about $20
Mar 17, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Bosch Exxcel WFO 2465 Front Load Washer Logo
209 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
