Televison & Video Logo
Posted on Dec 31, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can't seem to get my dvd player to play on screen
I'm trying to hook up my sony bravia theater system that I bought from you. I can't seem to get the dvd to play on screen. The remote turns off and on, but my screen says no signal, what's wrong?
  • masterpm51 Dec 31, 2008
    Thanks, but still no working dvd signal.
Anonymous
Level 3:
President:
  • Master 948 Answers
  • Posted on Dec 31, 2008
Anonymous
Master
Level 3:
President:
Answers
948
Questions
Helped
418195
Points
3155
Set the TV to look for a signal on the same input your are hooking your dvd player to. Example, if your dvd is hooked to video 1, set the TV to show video 1 on the screen.
Sony flat-screen bravia tv picture goes black but keeps playing audio when playing Netflix or DVDs.
your dvd player needs its own connection as does netflix and cable,get a new hdmi cable for each
How do I install an AMW model V101 DVD PLAYER TO A Magnavox MFX 450 SURROUND SOUND System RECEIVER AND Sony Bravia TV?
if the tv is already setup , then just plug the dvd player into an input of your choice , preferably , DVD , and then select DVD under your input settings.. keep in mind the tv must be hooked up properly in order for this to work ...
I purchased a 46" Sony Bravia flat screen TV. I
Try going into menu input set up on tv and switch to av input. Just a thought I have the same model and had exact problem. All I had to do was change input style to av cable.
Unable to control audio after playing a DVD using HDMI
you may have a damaged remote circit or reciver on the dvd player or tv, look for a phone number on the instructions book to call and see if you can send it in to have it checked out
1helpful
2answers
DVD Does not work when using HDMI from Philips TV to Bravia
You could see if they will exchange just the unit and save both of you the hastle of checking and repackingit all. It does sound like the unit is faulty.
Or if your Bravia has more than one HDMI input then try on another, or a friends tv if you know some one with a HDMI tv in working order.
No sound from TV thru sony bravia hdx576wf; DVD & CD audio ok.
Could be a sync calibration issue. Try to divert the TV sound to another input source on the Hometheatre system if possible, if it is a go then maybe the TV audio needs to be recalibrated. Make sure TV audio setup menu option has not changed also.
1helpful
Dvd player won't play, sony bravia theater system, says no signal
Are you talking about the DVD player built into the HT? Make sure it's selected as the output device using the "function" buttons. The HT should say "DVD".
1helpful
Volume Problem with my TV and Home Theater system
I had the same problem with mine.The solution I found was to use an optical audio cable rather than the red and white RCA audio jacks. Hope this helped.
Top Dell Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
Paul Bade
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
