Question about Dell UltraSharp 1504FP Monitor
Dell UltraSharp 1504FP Monitor - Blank Screen
Hi, My monitor screen has completely gone blank. I can see it is receiving power as the switch button is still glowing and i connected another monitor to my pc to find it prefectly working. So there's a problem with the monitor. I think it might be the fuse. How can i solve this problem I have seen a similar question posted on this forum before but no satisfactory answer was given. The so called experts were rambling about warranties!
  • Anonymous Sep 07, 2008
    Monitor going blank after 5 minutes of use (Was working for longer periods of time, but now down to about 5 minutes). I have tried turning the monitor power off then on, the screen comes up for a few seconds and then goes blank again.
    Same problem occurs when plugging it to a different computer.
    Noticed the Mfg date is November 2003... Is it time for a new monitor or is there still hope for this one?
    Thanks,Michelle
  • Anonymous Apr 09, 2009
    Screen has gone blank but the power light is still working. I did find that if i held it to a light just right i can see an image and even read whats on it, it's just not lit-up.
    Scholar:
  • 168 Answers
Well friend if the fuse is the problem, you will not see any power light indicator. probably theres a problem in power supply circuits or most probably the horizontal deflection circuits. which includes the horizontal oscillator, horizontal drive, horizontal output and maybe the flyback itself. but if you dont know anything about this, better bring it to a qualified tv technician. good luck!
Posted on May 05, 2007
The capacitors are leaky in the power supply(usually bulging). Change the 3 in the heatsink area(little caged area in the corner(You'll see them). And the four small ones over by the transformers and you will be right as rain I think. Fixed mine.
Posted on Oct 19, 2008
Dell 1504FP hdmi
It doesnt matter how many different ways you connct the monitor it will only support one input at a time
May 12, 2014 | Dell UltraSharp 1504FP 15" Flat Panel LCD...
Monitor went black and now stays black after
pdshapiro, Learn flashlight test in my fixya profile to determine current state of shutdown of units "switch-mode-power-supply"... Then do more reading and visit some of the web links mentioned in my many responses to other owners of Black or Blank n Black screen monitors. You will find out all you need to know and all options if you read my older (late 09 posts) responses to other owners of same or similar sympton ccfl back-lit lcd monitors. JUST DO SOME READING FIRST. Then come back to this post and give it a rating if it steered you in the right direction. Bye for now. 12fixlouie
Mar 27, 2010 | Dell UltraSharp 1504FP Monitor
Powers up, screen visible for about 3 seconds then goes blank.
There are two versions of the power supply/inverter PCB assembly, you need to look inside to see if it has any bad caps with bulging tops first, then post back so we can guide you further.
http://lcdrepair.us/1504fp-inverter-power.html
http://lcdrepair.us/1504fp-power.html
Feb 18, 2010 | Dell UltraSharp 1504FP Monitor
I can not find the correct drivers to configure my dell ultrasharp 1504fp. Only showing low resolution 4 bit and does not allow any other monitors other than default.
Are you sure that your problem is with the monitor drivers? Usually when graphics card drivers are correctly installed, the monitor is recognized as "Plug and Play monitor" and this is completely sufficient, as the monitor is able to communicate it's supported resolutions and refresh frequencies to the video card.
Look for an updated graphics driver for your system - first you have to establish what type of graphics card you have, then find drivers for it.
Nov 05, 2009 | Dell UltraSharp 1504FP Monitor
My monitor(1504FP) only work for 4 seconds after you turn it on, Then it goes blank.so just to use it I have to constanly turn it on and off every 4 seconds. Ive used the blue cord on another comuter and...
you monitor needs capacitors or a capacitor and maybe a bulb that is not to hard for a tech ,but depending on the size and scope of the monitor i would just buy a new one
Oct 20, 2009 | Dell UltraSharp 1504FP 15" Flat Panel LCD...
Dell 1702FP 17" Blank Screen Problem
Try it on another computer, if it works the video card moght be dead.
Jul 11, 2009 | Dell UltraSharp 1702FP 17" Flat Panel LCD...
Dell FP1504 Displaying very dark " Ithink this is backlight issue
If you are not a technician you can´t solve this problem because are to desasembly your device and check the Q7 and Q8 and C5 that components are on bad conditions and need to be replaced,I told you because i repaired one of these monitors for the same problem
May 08, 2009 | Dell UltraSharp 1504FP Monitor
Monitor has no power
check connections. then unplug and plug back in to reset the monitor.
other than that it could be the power cable or worse a faulty screen.
Apr 05, 2009 | Dell UltraSharp 1504FP 15" Flat Panel LCD...
Dell 24'' Ultrasharp went blank
I suspect the invertor supplying power to the Xenon backlight tubes has failed.
This can be reapired but may not be cost effective.
Ask for a quote from your local computer specialist but keep in mind the cost of a new monitor.
Mar 18, 2009 | Dell Computers & Internet
Blank screen
Disconnect the monitor , from the computer, switch the monitor on , if you have some kind of Dell self test box running on the screen. The monitor is OK . The problem can be with the video card or resolution settings.
Also, try connectin the old monitor you had hooked up with the system to check ,if you see anything
Thanks
proton
Mar 14, 2009 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
Computers & Internet Logo
793 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
