Question about Pegasus Technologies Two-Piece Round Toilet by Pegasus - 15 3/4 Inch Bowl Rim Height
Plastic under flush handle stripped.
Handle will not stay on. Just spins around. Toilet not even 3 months old.
  • jpf121960 May 04, 2009
    toilet handle broke off after month of use now just spins around and cannot flush
  • 4 Answers
Pegasus toilet handles dont have screws, nuts. It just slides on and barely stays. Mine just broke too, can't find replacement.
Posted on Oct 08, 2009
  • 35 Answers
If the threads are not stripped on the nut or handle it should be fine. IMPORTANT TO KNOW!!! These are left handed threads, Meaning they tighten up the opposite way of a normal nut and bolt. If the threads are bad or damaged, you will have to purchase a new flush handle. They are not expensive at all. $2 - $10 Dollars. But first try screwing the nut on by turning it to the left instead of the right.
Posted on Dec 31, 2008
I am at work the low flo toilet is 6 months old and it usually doesn't have to much water under lid ......the level is all the way up to the handle and it's leaking around the handle
You could have a first generation 1.6 gallon flush toilet that is destined to failure. Look inside the tank for a manufacture date stamped in the clay. If it was made during the time period from January 1, 1994 to mid-1997, this could be the problem. No matter what you do, it will not flush right.
If the toilet was made before 1994, hard water deposits in the syphon jet hole or the angled bowl rim swirl holes may be the source of your frustration.
You can try to clean them out with wood sticks and oversized toothpicks, but a muriatic acid wash will really do the job. Mix one part acid to 10 parts water. Using a funnel, carefully pour one half of this solution down the overflow tube in the toilet tank.
Nov 12, 2017 | Lid Home
Toilet handle sticks
It sounds like the nylon nut which holds the handle in place is too tight. Try loosening that nylon nut just a little to see if the handle moves easier. Sometimes if they are over-tightened, the handle will be stiff and hard to operate.
Apr 10, 2014 | Home
Flapper valve closes too quickly
Fill the breather hole (1/8" hole) inside the flapper.This is designed to let air out so the flapper will sink. Now it floats longer letting in more water. 25%percent more in my case.
Apr 22, 2012 | Home
I have a 6 month old Kohler toilet that has a very loose flush mechanism handle- how do I tighten it?
Toilet flush levers are always adjustable. For the most part, there are two types of chains that attach to the lever. Ball chain or linked chain. Either way, you'll see that there is a rod behind the toilet handle lever. That rod has many holes. Re attach the chain to the proper hole on the rod that makes the chain taut and not loose. Hope this helps!
Nov 21, 2010 | Kohler Home
Toilet flushing problem! I purchased an American Standard Cadet 3 High HET toilet (1.28 gallon). When I flush the toilet, the flap will not stay up to allow the water to drain from the tank. When handle is...
The siphon mechanism works on a vacuum principle. If there is the slightest damage to the siphon membrane you will experience the problem you describe. A new siphon is required.
Dec 31, 2009 | American Standard Cadet 3 Right Height...
Basement toilet won't flush. water fills the bowl and tank fills back up...but toilet doesn't flush
Check your flapper line to the flush handle. The flapper is in the tank on bottom. There shoiuld be a plastic line to handle or chain. :)
Sep 07, 2009 | Home
Pegasus Dual Flush Toilet - How to repair damaged handle
any good plumbing supply company will help you. " Furgoson " i think thats how you spell it.
Jul 18, 2009 | Pegasus Technologies Pegasus Toilet Paper...
Toilet flushing
you either have the wrong flapper or it is not adjusted right try moving the chain to shorter or longer lenght the other thing to check is that your handle is not loose if you have to tighten handle be careful it is a reversed thread also check water level in tank
Apr 07, 2009 | American Standard Cadet 3 Right Height...
Pegasus Technologies Two-Piece Round Toilet by Pegasus - 15 3/4 Inch Bowl Rim Height Logo
695 people viewed this question
Top Pegasus Technologies Home Experts
john h
Jim Goldsmith
Jim Goldsmith
Paul Carew
Are you a Pegasus Technologies Home Expert? Answer questions, earn points and help others
