Question about Samsung TX-R3265 TV
I have 23" Model #LNS2341WX/XAA TV and I am getting fine
Vertical lines. Is there someway I can correct this?
  • jj64227 Dec 31, 2008
    My TV will only be 2 years old in January.
    Genius:
  • 1,011 Answers
Sir,
if it is a single line top to bottom?? sounds like a bad panel. the reason is if it where a buffer module it would run half way
Posted on Dec 31, 2008
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, pls confirm that your TV is a Samsung LNS2341WX/XAA 23" Wide HDTV Monitor LCD TV with PC/DVD/ TV Inputs. Offhand:
  • try a power cycle/reset, unplug from the mains for an extended period of time;
  • verify that the connectors at the back are tight. Wiggle them while TV is operational and have somebody observe if there are any changes;
  • confirm if the vertical lines are present on TV, Video (DVD), computer use, or other inputs;
  • try a different outlet or use a voltage regulator similarly used by desktop PCs but confirm that the power/wattage would match the requirement of the TV;
  • unplug all other cables and connect one at a time to check if any of the sources are causing the vertical lines;
  • physically relocate some electrical devices away from the Samsung in the possibility of electrical interference;
  • some other known devices that can cause interference are lamp dimmers, wireless phones, lamps with electronic ballasts;
  • worst case scenario, component/board problem.
Pls post back updates/results of above tests.
Good luck and Thank you for using FixYa.
    Genius:
  • 1,142 Answers
The vertical lines represents the power supply faliure
  • Maanita Chadha
    Maanita Chadha Dec 31, 2008
    The cause is one or more shorted transistors either on CRT board or on
    main or both. The colors are red,blue and green, you have a transistor
    for each and a bias trans. check each there are 6 in all
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
Why come white vertical line on my t.v screen in center?
You said "I checked vertical output line from main ic pin 23 found correct"
But the problem is "Horizontal Output Line" Try that.
Jan 29, 2015 | LG Televison & Video
LNS4695DX/XAA Samsung tv vertical and horizontal lines on picture - all components
Thats usually caused by the Tconn board and or its connection also samsungs have been plauged with tab bond issues with the LCD panel itself. Send a pic of the issue to customerservice@tvrepairworld.com and they will be able to tell you whats happening with it be sure to include the model number with the pic
Mar 13, 2012 | Samsung Televison & Video
DEAWOO TV Model no DTC 2975 vertical line i want to know that vertical ic number b,cos of that ic is burn & blast,i can't fine out.
If you have a bright vertical line down the screen you have an "S" correction fault. Usually there is a small choke that gets a dry joint under it.
Check for dry joints.
Jan 04, 2011 | Televison & Video
I have a black line on the tv samsung
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this help......
Jun 22, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Bad picture on a Samsung DPL TV
Failing DMD board or it is also possible it has bad ribbon cables
Jan 31, 2010 | Televison & Video
Dark vertical lines on tv screen
If under warranty then of course use that.
This is a display problem. One solution someone knowledgeable in electronics can try.
This problem can be caused by a bad connection fitting of the flat cables on LCD controller board. Dis-connect the flat cables from the LCD controller(T-CON) and carefully reconnect them. Try the unit before reassembling the back cover. You may have to disconnect/reconnect several times to show improvements if this is the problem.
Sep 25, 2007 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Samsung TX-R3265 TV Logo
65 people viewed this question
Jerry Greenberg
Jerry Greenberg
