Question about Lentek WC02 Wine Cooler
Lentek WC02-G-7A wine cooler not working.
I'm looking for a schematic.
Can you help?
Julien
Can I get an electrical schematic
Google (Avanti)(EWC-12)(schematic) without parens, of course.
May 24, 2016 | Avanti EWC-12 Wine Cooler
Magic chef wine cooler not gettng cold
at sears .com the schematic lists a "protector" part 265RFBYY
is this the overload?
also somewhere else I saw the temp stat was a problem, how would I rule this out? (Its expensive)
thanks
Jun 23, 2014 | Magic Chef MCWC45A Wine Cooler
Power supply failing on Cuisinart CWC 1600 cooler
The hayni made in china internal power supply has faulty transformers on it that fail within anywhere from 6 months to 2 years. Solution. Remove the back panel, take out the internal power supply and replace it with another compatible AC 120v to 12v DC 5amp power supply. Often laptop power adapters will work. I used this one: 60w-12v-5A-AC-DC-Power-Adapter from the website mini-box and it only cost 15 dollars. The peltier pad draws upwards of 5amps, but the rest of the system is super lower power. Now my wine cooler is more energy efficient and and will run for at least 5-10 years. This power supply replacement takes about 20 minutes. You need: philips screw driver, wire cutter and stripper, two 16 guage wire nuts. That's it.
Oct 12, 2012 | Cuisinart CWC1600 Wine Cooler
Need Haier thermal electric wine cooler manual:Model #HVTS18DBVS serial #o90800187 Would appreciate info.
You could try
operatingguides.com
if you need a user manual
or
servicemanuals.co.uk
if you want the schematics etc
We've used them in the past and found them very good.
Also if it is not listed then ask via the link and they
will probably be able to get it for you.
Jul 13, 2011 | Haier BC112G Wine Cooler
I am looking for the cooling fan for a Danby Silhouette DWC512BL-1 wine cooler. A google link took me to your site but I don't see any links to Danby parts.
As I have worked on a few ELECTROLUX wine coolers and they do not have a cooling fan for the inside of the unit are you speaking of the one under and in back of your cooler if so then it is a condenser fan motor it will be 110v and your local appliance store should be able to order one close enough to work in design and rotation of it. Hope this helps.
Apr 09, 2011 | Danby DWC513BLS Wine Cooler
I am looking for schematic diagram for emerson fr24sl wine cooler
Down load turn to page 7
http://dl.owneriq.net/c/c8e23cf9-fddd-4b8c-9c13-e974bf7597e1.pdf
Nov 25, 2010 | Refrigerators
I have a wco2-g-7a 12-bottle wine cooler. I plugged it in to a working plug and it does not get cooler at all. I don't find a on/off switch. It has a dial for red and white wine temperatures, but...
Mary,
my friend gave me the exact same model that you have, (though they had used it and decided they didnt want it.
i have the EXACT same problem. i think i will junk it now, since it was free.
of course, the prior owner claims to not know if it actually worked or not.
best,
robert
Sep 22, 2010 | Lentek WC02 Wine Cooler
Kenmore wine cooler 13485 spill wine in the top not cooling
if suction line is warm and pressure line hot . sounds like comp is trying to do its job / ck the fans and they may be slow or not going . spilling of the wine did not cause problem . .. but now is the time to correct the problem .. mm / ps if unit is running like you state the you might look at the ref charge . as it may be low . mm . hope this hs helped . feed back pls .. mm
Jul 22, 2010 | Kenmore 13485 Wine Cooler
I have an Haier 8 bottle counter top wine cellar. No electricity to digital display, rear fan is not on and does not cool. Looking for schematic for possible fuse location.
look down of the wine celllar and take off the plastic cap and clean the electrics contact. After that use use the 4 screwed support to give it the right inclination._400.jpg
Apr 10, 2010 | Haier HVUE08A Wine Cooler
Waring Portable Ice Machine Schematics
I doubt you will find any schematics for this unit. It should be pretty straight forward anyway. I suspect that uses a solid state plate cooler, and basic schematics for them, and their control board, can probably be found n the internet.
Jan 23, 2009 | Waring Wine Chiller - Black
Lentek WC02 Wine Cooler Logo
99 people viewed this question
Top Lentek Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Lentek Refrigerator Expert? Answer questions, earn points and help others
