Question about Jwin JD-VD745
DVD WONT PLAY IT SAYING NO DISK OR OPEN.
Dvd player not reading any disk.
  • donz72205 Jan 01, 2009
    What position should the lense be in?
    President:
  • 2,110 Answers
Use a lens cleaner to clean the lens of ur cd rom..
Posted on Jan 01, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, if the discs that fails to be read by the DVD player in question are readable/playable in and with other machines and head cleaning would not address the issue, then the lens or its attendant circuitry are faulty and would need replacement. Sorry to be bringing you the bad news.
This of course would require opening the unit, perform voltage measurements, determine faulty component and subsequent part(s) replacement. Further, a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron would be required. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings.Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional. If the cost of repairs and downtime would be factored in, then you may have to re-evaluate your options and consider a replacement.
Good luck and Thank you for using FixYa. Happy New Year.
    Genius:
  • 1,550 Answers
Try to clean the lens .Use lens cleaner kit to clean the lens of your dvd player . If this doesnot work then it is a mechanically problem in your player .
You need to manually open to check the dvd player .
The rubber thread which should be connected to the motor inside the DVD player might have moved from its place.
You need to place the rubber thread to proper place.
Also if the belt is slipping, the mech never gets the "drawer closed" signal, and the disk will not spin.
    Novelist:
  • 163 Answers
Try to clean the player using cleaner disk.
  • ronny2051 Jan 01, 2009
    If cleaning is not works than better to purchase a new drive.
    here is the link to align dvd lense step by step:
    http://www.howstuffworks.com/cd5.htm
  • Jwin Master
  • 13,433 Answers
Try a dvd lens cleaner if the dvd player wont play the dvd. if the dvd drive doesn't work at all you will have to take it to your dealer or Jwin for repairs, how is your warranty?
Lg model dp450 wont play a disk when it's in
Buy a DVD cleaning kit and follow instructions, or get a Q-Tip and rubbing alcohol and gently clean the lens, allow several minutes to dry, if this fails! the laser pickup assembly must be replaced or buy new player, "far cheaper to buy than repair"
Apr 19, 2012 | LG DP450 Portable DVDDivX Player
When I put a dvd in it wont play and before it would
If it say not supported, It may mean the dvd disk is dirty. Sometime invisible hand oil evaporated on the disk. You rinse the disk off hot tap water and block off the water drops and try all the disks again.
Feb 09, 2012 | Disney Cars Ramone DVD Player
My DVD player wont play it keeps saying no valid disk
It may be that the lens is dirty so it can't read. Try inserting a CD or DVD cleaning disk (like a normal disk but has a little brush attached)
If you are trying to use home recorded disks check that they are in a suitable format - some players require only R- format whilst others will only R+
Feb 25, 2011 | Venturer PLV31220S1 22 in. LCD TV
Suddenly my DVD player is saying "no disc" after trying to load DVD. Why isn't it sensing the DVD has been loaded?
When a DVD goes into DVD player it has to spin it and read it. If your DVD player is not reading the disk. The disk could be dirty. The DVD player might need to be cleaned. You could be trying to play a PAL disk on a NTSC player or Visa Versa. or the region coding might be wrong. Try playing a clean disk that you have played in it before. That might tell you if you need to clean the DVD player.
Mar 03, 2010 | GoVideo DV2130 DVD Player/VCR
Dvd player wont play
Make sure that the DVD Disc is of the format that your DVD recorder can read. For example, if your recorder specifically requires a DVD -R type disk, it will puke on a DVD +R disk.
Apr 12, 2009 | Emerson EWR20V4 DVD Recorder/VCR
Panasonic dvd recorder wont record or play
It is also possible that you are trying to record using an already used -R or an unformatted RAM disk.
Mar 07, 2009 | Panasonic DMR-E55 DVD Recorder
DVV Player won't play disc
Check to make sure your player can play other disks. If so then use the disk doctor to remove the scratches on your favorite disk. The area that all DVD players scan before playing a disk is probably smudged or scratched.
Nov 21, 2008 | Philips DVP3345V/17 DVD Player/VCR
When trying to play dvd wont due to saying either unknown disc or defective disc
Hey,
As i don't know the model of your dvd player or the type of dvd you are using I can only give you a very basic response for possible issues.  1. you are using a "burned" dvd on an older dvd player. Some older dvd players can't read dvd's burned from a computer. 2. The lense is dirty, scratched or damaged.. if other disks work in the dvd player, than this option is out the window. 3. DVD is damaged or defective. Just like the previous solution, if the disk works in other dvd players, this option is out the window 4. The DVD is from a different Region. Here in Canada and the US we are region 1, if you get a disk from Europe or japan. they are region 2 dvd's and thus don't work in our north american machines. 5. Some older DVD players have difficulty reading dual layer discs - just a though
I hope those were helpful, if not message me back with the dvd player model number and the movie or type of disk you were using.
Oct 30, 2008 | Televison & Video
I can't play any DVD's. It keeps saying cannot read.
Basic DVD, CDrom Troubleshooting
wrong disk ,disk error,
First Clean the lens:
http://www.ehow.com/how_2036275_clean-lens-dvd.html
wont open, wont close, makes clicking/grinding noises etc.
http://www.llamma.com/xbox/Repairs/thompson_dvd_tray.htm
Jan 25, 2008 | Panasonic DMR-ES25 DVD Recorder
Wont play saying unknown disk
If the region setting is correct and won't even read a cleaning disc, there's not much you can do. Either the DVD drive or the Main board (aka MPEG board) is faulty and will have to get it repaired. I'm not sure about UK, but in Australia, Bush manufacturing warranty period for DVD players is 12 months.
Aug 29, 2006 | Bush DVD2038 DVD Player
Jwin JD-VD745 Logo
47 people viewed this question
Top Jwin Televison & Video Experts
Jaime Hernandez
William
romy sibug
romy sibug
Are you a Jwin Televison and Video Expert? Answer questions, earn points and help others
