Question about HP Deskjet 6940 InkJet Printer
Banner problem xp home
Have interfaced with hp fo a week now and also received new unit but have same problem. printer works on all phases except when printing a banner. if i make more than a 2 page banner just prior to end of 2nd sheet it skips and continues on 3rd sheet then skip near end of 3rd sheet and continues at statr of 4th sheet. if you fold over on it self nothing has been missed it all lines up ok. when setting up it calls for banner paper i do everything called for but it skips. have uninstalled drivers, reinstalled with same results. tried using 2nd computer same problem. i am interfacing with ethernet because if i go usb it shuts my system down. i also have an epson all in one on same pc am using xp home
  • Dick Phelps Jun 24, 2007
    More Details:
    When I print a banner of longer than 2 pages it does take paper in and print as a banner should but any text or pictures I place across page do not come out properly when it is printed.
    Everything is ok across page 1 & 2 but text or pictures on end of page 2 stop short and continue at start of page 3 and do the same at end of page 3 and continue at start of page 4.
    If I fold paper over at end of page 2 it will align up with start of page 3, nothing missing just a gap and same thing for page 3 & 4.
    Have talked with Hp support done everything they suggested to no avail.
    This problem is the same on 2 different PC'S and they sent me a new printer.
    Here is what they suggested and what I have done.
    1. Make sure paper is in right and select banner paper from paper type.
    2. remove all drivers and reinstall
    3. purchase good USB cable, I got Geek Squad $34 at best buy.
    4. Take all other printers off system reinstall drivers for HP6940 with security turned off (only did this on the PC I wish to use).
    5. followed all suggestions they requested on selecting banner paper type and procedure for printing.
    As I said before I have an old HP 712 that I can still use and this program still works perfect on that printer but that printed call for checking banner box and putting a switch in banner position before printing when I go to printmaster help is tells me to go to continous print which Hp6940 does not give me this option, I think when I select banner paper this is suppose to do this using software.
    I am using Printmaster Platinum 17 and have been using their program for 6 or seven years from version 8 up to version 17 with no problems.
    I also tried o use Ethernet instead of USB input with same results.
    Printer works perfect for all other functions that I have tried.
    Hope this helps
  • 944 Answers
Did you reinstall the drivers from the original cd? If so, then uninstall the drivers completely, download the latest updated version of the full driver from here; http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=467980&lang=en Install the printer and see if the problem is the same. uninstall and reinstall the printmaster software manually - go to this link for detailed instructions; http://support.broderbund.com/fix.asp?isid=43427&prog=1294820935&printer=1 Try the procedure on this link next; http://support.broderbund.com/fix.asp?isid=43440&prog=1294820935&printer=1 Then try this link - see if you can get the hp printer to work by emulating a different model; http://support.broderbund.com/techtips_detail.asp?id=88 There are no relevant updates for the printmaster software, but it could be worth checking this link occasionally, and download the available updates to see if they make any difference (unlikely, but worth a try); http://support.broderbund.com/faq_list.asp?id=1294820935#downloads If this doesn't help, then there is a currently unfixed compatibility issue with the printmaster software. Contact Broderbund directly on this link; http://support.broderbund.com/contact_cs.asp See if they have anything to say - it may be that they will address the issue if they haven't so far. Hope this helps :)
Posted on Jul 20, 2007
  • Nigel Ridehalgh
    Nigel Ridehalgh Jul 20, 2007
    PS - try emulating the older hp 712 model if it lets you :)
We have a receiving problem with our HP Color LaserJet CM2320nf . The exact issue is that, sometimes the machine is unable to receive a fax with any number of pages from different senders Also, the...
Error Code 223 (ECM error)
The receiving product has been unable to receive an entire page even after multiple attempts to rereceive the parts of the page that contain errors. This is usually due to extremely poor line conditions.
1. Reattempt the fax reception at a different time when telephone line conditions have improved.
2. If the error persists, disable ECM. Errors may still occur, and may result in degraded image quality on the received page. However, the ability to receive the entire document will be improved.
Error Code 420
V.34 negotiations have failed from the originating product during phase four, which occurs after V.8 and before the first T.30 frames are exchanged. Compatibility problems have been observed in this area when sending to non-HP units.
Reattempt the fax transmission at a different time when telephone line conditions have improved.
Error Code 421
V.34 negotiations have failed from the originating product during phase three, which occurs after V.8, before phase four, and before the first T.30 frames are exchanged. Compatibility problems have been observed in this area when sending to non-HP units.
Jul 20, 2011 | HP Laserjet CM2320nf All-In-One Color...
I have a brand new IR compressor model 2475N7.5 with a 7.5 hp 460v 3 ph motor. is it possible to convert it to a single phase power supply? or should i just exchange it? ... I ordered it thru Northern Tool...
When you google home made 3 phase converters, you will find many ways to make use of 220v single phase instead, however you are limited as to the hp that the motor will produce. If you spin the motor first then apply 220v, the motor will continue to turn at much reduced hp. You need full power to turn a type 30 pump depending on pulley combination/ setup. Best to return the unit and get one that will run on 220v single phase. It will most likely consume more power to do the same work however it would cost a great deal to install 3 phase. Most likely not even available at all. Many years ago, I worked at Sears and happened to see an electrician coming down from roof access of building. He told me that sears had a 3 phase generator being turned by a 220v single phase motor to run an air conditioning unit. He said that it worked quite well. Does not sound cost effective.
Jan 08, 2011 | Ingersoll Rand - Rand Type - 30...
Black lines on scans and prints HP 2727nf
File name: s.gif HPPDU.exe [1/1, 1.54M] System requirements: s.gif No additional prerequisites Released: s.gif 2010-08-13 Version: s.gif 3.0.0.013 Compatibility: s.gif Microsoft Windows Vista, Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Business (32-bit), Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows 7 (32-bit), Microsoft Windows 7 Home Basic (32-bit), Microsoft Windows 7 Home Premium (32-bit), Microsoft Windows 7 Professional (32-bit), Microsoft Windows 7 Enterprise (32-bit), Microsoft Windows 7 Ultimate (32-bit), Microsoft Windows 7 Home Basic (64-bit), Microsoft Windows 7 Home Premium (64-bit), Microsoft Windows 7 Professional (64-bit), Microsoft Windows 7 Enterprise (64-bit), Microsoft Windows 7 Ultimate (64-bit), Microsoft Windows 7 (64-bit), Microsoft Windows Vista (64-bit), Microsoft Windows Vista Home Basic (64-bit), Microsoft Windows Vista Home Premium (64-bit), Microsoft Windows Vista Business (64-bit), Microsoft Windows Vista Enterprise (64-bit), Microsoft Windows Vista Enterprise (32-bit), Microsoft Windows XP Fix/Enhancement: s.gif This version of the HP Print Diagnostic Utility provides an improved user interface in multiple languages, improved diagnostic and problem resolution capability, and support for usb and network connected devices.
Oct 27, 2010 | HP Laserjet M2727nf Multifunction Printer
Is there any hope for a Vista 64 bit HP Laptop with the HP LJ 2840 Printer? I have tried it all, had Invisus Support work on it for two hours today, 10-25-10, and still no printer functionality. I am...
s.gif upd-5_1_1_8232-pcl5_winxp-vista-x64.exe [1/1, 15.21M] System requirements: s.gif Client and server operated systems supported for the most current release of the UPD:
Client operating systems supported:
  • Microsoft Windows 7 Starter, Home Premium, Professional, Enterprise, and Ultimate; x86 and x64
  • Microsoft Windows Vista Business, Enterprise, Home Basic, Home Premium, and Ultimate; x86 and x64
  • Microsoft Windows XP (SP2 and later) Home Edition, and Professional; x86 and x64
    *Note: Microsoft retired mainstream support for Windows XP in April 2009. HP will continue to provide best effort support for the current UPD and tools for the discontinued Windows XP operating system until 2011
Oct 26, 2010 | HP LaserJet 2840 Printer
Scanner : could not find required user interface
I just turned off my firewall protection with CA security center (virus software) and my scanner came back to life. I've had nothing but problems with CA so it's back to Norton for me!
Mar 22, 2009 | HP Photosmart C5180 All-In-One InkJet...
Missing Toner Cartridge
Try first removing all paper from paper trays and then reinserting cartridge, etc.
Sep 23, 2008 | HP LaserJet 3050 All-In-One Printer
Banner printing on HP DeskJet 722c InkJet Printer
The problem with your printer is probably if you are using Windows XP it will not print banners from there. I downloaded drivers too and found if I went to a printer with Windows 98 and put in my software program the banner will print out. Hope this works for you. I had to find it thru trial and error.
Verron
Mar 14, 2008 | HP DeskJet 722c InkJet Printer
ASA 5510 sec - bun k9
Basic Commands pixfirewall(config)#hostname PIX !--- Naming the PIX is optional. PIX(config)#nameif ethernet2 fo security20 !--- Naming the interface is optional. It is recommended that you !--- hardcode the speed/duplex. PIX(config)#interface ethernet2 100full !--- Bring up the interface. PIX(config)#ip address fo 192.168.1.1 255.255.255.0 !--- Assign an IP address. Failover Commands PIX(config)#failover ip address fo 192.168.1.2 !--- IP address for the failover link. PIX(config)#failover lan unit primary !--- This unit is primary . PIX(config)#failover lan interface fo !--- The 'fo' interface is used for LAN failover. PIX(config)#failover lan key cisco !--- The Pre-shared key. PIX(config)#failover lan enable !--- Enables failover. PIX(config)#failover !--- Start the failover process. This message appears on the console:
LAN-based Failover: trying to contact peer failover_01.gifLAN-based Failover: Send hello msg and start failover monitoring
Nov 27, 2007 | Cisco ASA 5510 Firewall
HP Deskjet 6940 InkJet Printer Logo
66 people viewed this question
Clive
Clive
