Question about Buffalo Technology DriveStation HD-HC500U2 500 GB USB 2.0 Hard Drive
My buffalo external hard drive(HDps300u2) is not recognised on my
Computer. i have checked the drive letters are ticked and they are. i have checked the usb ports with other devises ( including a pen drive that it allocates a drive letter to!).the drive seems to work ok on my laptop but not where its needed on my main computer. any ideas are most welcome
5 Suggested Answers
  • 10406 Answers
SOURCE: I can get into disc manager (to try and change my
Put some media into your MASS STORAGE DEVICE,
and DISC MANAGER will assign a drive-letter,
and will let you change it.
Posted on Apr 23, 2009
Crankstart
  • 696 Answers
SOURCE: allocation table problem. overlap of sectors and no drive letter assigned. cannot get my all data files inside!
Sounds like the drive may have been formated/reformated the wrong size.
This can be troublesome to repair but there are some consumate pros around who can help you.
Try, Armor-IT Data Recovery, you can search them in our database or on google and they will be happy to help get your files back.
Chris
Posted on May 17, 2009
  • 60 Answers
SOURCE: can't see my buffalo usb ministation under my computer
right click on my computer click manage, then in the new screen click on disk management, can you see the device there? if so right click on it and click delete partition, then after right click and make a partition and format it with a quick format, this should then show it in mycomputer ,this will delete all data on the hard drive!
Posted on Jul 02, 2009
  • 24 Answers
SOURCE: My buffalo external Hard disk is not working in
Some usb input ports on dvd players, projectors, etc. have a limit to what size it will read from. Right now it's usually 4 gb to 32 gb.
Posted on Apr 03, 2010
  • 10406 Answers
SOURCE: Everything worked fine until yesterday
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files.
For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge guarantee".
Posted on Nov 11, 2010
Testimonial: "THanks - I'll give it a go!"
Computer wont recognise external hdd
Follow these steps:
1. right click on My Computer
2.Click on manage
3.Click Disc Management
There you can see External hd (you can chose to activate or change drive letters and that will do the job)
Mar 29, 2013 | Buffalo Technology DriveStation HD-HC500U2...
Buffalo external hard drive not recognised on car sterio
i think you cars stereo firmware is not capable check whether other external hard drive it is recognising
Feb 05, 2013 | Buffalo Technology 1TB DriveStation...
Have recently had to add windows 7 to my PC (losing everything) but have laptop using XP. When I plug buffalo ministation into PC it wants to format but I'll lose everything on harddrive won't
click start control panel administrate tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start then after its finished return and tick the other box you should not
do anything while the chkdsk utility is in progress any input may damage this drive
i have found the best results ticking in one box the returning after it has finished then ticking the other box
it might take some time depending on the size of your disk but be patient
hope it helps
Oct 12, 2012 | Buffalo Technology Buffalo MiniStation...
My external buffalo hard drive is not being recognised by my laptop
Right click on My Computer (or Computer is Vista/7) and select Management from the menu. Click to expand Storage and then click on Disk Management underneath it. It may take a couple of seconds for the area on the right to populate.Scroll down in the lower pane and see if you can locate your external hard drive in the list. When you locate it, right click in the left area that says Disk # and see if there is an option to Initalize the disk. Click on Initalize.
Mar 20, 2011 | Buffalo Technology DriveStation HD-HC500U2...
Hi..my external hard drive not responding.1TB buffalo.please help me. Thanks
1. Right click on My Computer and choose Manage.
2. Navigate to Disk Management and check to see if the drive is appearing as a drive.
3. If it is showing as unallocated, right-click on it and Partition the drive.
4. If it is showing as formatted and healthy, right-click on it, choose 'change Drive Letter and Path' to assign a drive letter.
Jan 04, 2011 | Buffalo Technology 1TB DriveStation...
Everything worked fine until yesterday when my PC did not recognise my Buffalo JustStore Desktop 500 GB External hard drive when I plugged it in. There is also a ticking 'searching' sound from the HD
* the USB cable
* the power-adapter
Nov 11, 2010 | Buffalo Technology Computers & Internet
My computer is failing to recognise it, therefore I cannot access all my files. My computer started by warning me that the external hard drive has malfunctioned, then it would say it cannot recognise it....
Too Bad.
do this
take apart the hard drive enclosure. and try to connect the hard drive direct to the computer, if you can't do this, try with another adapter, if this fails your HD is Die. sorry
Feb 22, 2010 | Buffalo Technology DriveStation HD-HC500U2...
MY NOTEBOOK CAN NOT RECOGNISE MY 500GB BUFFALO HARD DRIVE AND THE HARD DRIVE IS MAKING A FUNNYCLICKING NOISE
audible clicking sound? doesnt sound good. clicking sounds are usually signs of failing HDD....
Feb 14, 2010 | Buffalo Technology (USA), INC. - 500GB...
My external buffalo hard drive is recognised in device manager, but can't access through explorer... any ideas please? I am running Vista and the last time I accessed the hard drive was doing a backup...
Your drive could have errors due to the aborted task. You need to format your drive. Go to Computer Management, if your drive is recognized in device manager t will show up in the Computer Management, there you can format it. Good luck.
Jan 11, 2010 | Buffalo Technology Computers & Internet
Can't see my buffalo usb ministation under my computer
Jul 02, 2009 | Buffalo Technology 320GB MINISTATION TURBO...
Buffalo Technology DriveStation HD-HC500U2 500 GB USB 2.0 Hard Drive Logo
275 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant M
Prashant M
hellics
Level 1 Expert
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
