Question about Rainbow 75th Anniversary Canister Vacuum
Rainbow Vacuum smells like something is burning.
When I sweep, the Rainbow smells really bad like something is burning inside of it but I don't know how to dismantle it to see what is going on.  Any help would be appreciated.  Thank you.
  • David Cleary May 11, 2010
    Is the smell coming from the P/N or the canister? What does it smell like? elctrical/ burnt rubber
    New Friend:
  • 27 Answers
When it is running look on top of unit to see if there is any flashing from the brushes, if your unit has been getting pretty hot on top, it would probably be motor brushes. These are not very expenseive to replace and by doing so you will have your unit for so many more years.
Posted on Jul 30, 2009
How do I replace the fuse on a rainbow vaccum?
The D4 model Rainbow has a Thermal Cut Off
This has to be manually replaced. It is attached to the Field 120v D4
If this has blown, then most likely something is causing. The Armature Tall 120v D4 could be going bad.
You can also speak with our technical support team Contact Us
RainVac
Jan 27, 2016 | Rainbow D4se Classic Canister Vacuum...
Why does my rainbow e series smells like it's burning?
Belt for Power Nozzle EXCEPT the PN 12
or...
Motor Rainbow 120v
is most likely going bad. You can also call out technical support team if needed... Contact Us
RainVac
Jul 20, 2014 | Rainbow E series Canister Wet/Dry Vacuum
Burning smell
The response by Lynnette is in reference to the power nozzle....if you are having this issue with the main unit, then it could be the armature is starting to go bad. Have your Rainbow in front of you and give us a call. We can walk you through some steps to narrow it down.
www.rainvac.com
800-523-0510
Apr 09, 2014 | Rainbow E series Canister Wet/Dry Vacuum
Bristles quit rotating and smelled like something was burning. It isn't the belt that turns the bristles. Can't afford a repairman, can you help me fix it?
Belt can reamin intact but still jam and burn. It won't necessarily break. I suggest you remove the bottom of the vacuum where the bristles spins and where the belt is located. You may have something jammed in there. You may need to remove the bristle to get the belt out. Inspect the belt and replace after clearing the obstruiction.
Sep 21, 2012 | Bissell 6594 PowerForce Bagless Upright...
My e-2 vacuum runs very loud and smell like it's burning.
You may have damaged a bearing or bearing housing and that could be causing the motor armature and field to rub together which in turn causes the motor to draw a significantly increased current to overcome the friction. It could be a simple fix if it is a bearing but if it is the housing then it is likely toast. I used to repair motors years ago and the cost then was not bad. However if the motor is heat damaged, as happened to my power rack last year, it was cheaper to buy a new one than replace the motor. A burned out motor is not worth repairing these days.
Dec 19, 2017 | Rainbow E series Canister Wet/Dry Vacuum
I bought my rainbow se vacum 4 years ago and I was using it and suddendly stoped working, I try to on no power I on and off not working at all. what shall i do is there posibility to work again.pls.help...
Hi, there is no reset button on a Rainbow vacuum.
All SE series vacuums have a built in thermal and load fuse on the motor, and if it blew, it has to be replaced, or wired directly, with out it on there.
Motor brushes are usually the source of a non working Rainbow D4 and SE and all model Rainbow vacuums and when they burn out, they usually take the motor armature with them, from excessive heat and flare electrical arking to the armature. It is probably the thermal and load fuse, that is your problem, if you did not smell any electric burning type of smell, before it quit. It could be the power switch, but not as likely as the fuse. If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
Feb 13, 2010 | Rainbow 75th Anniversary Canister Vacuum
When I turned on the vacuum it started to smell
the vacuum is either shorting or the motor or brush assembly is rubbing something.
Jul 31, 2009 | Rainbow Vacuums
Your belt is worn and that is why there is a burnt rubber smell. You need to change your belt. You can find a replacement belt and instructions here:
Rainbow Replacement Belts
Apr 02, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Loud rainbow and water leaking
If pieces are missing or broken I would try and replace the piece. You can usually get these items cheap on Ebay.
Apr 08, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Burning Smell
Check the carbon motor brushes, there might be arcing on the armature. New brushes may help if the armature is ok.
Mar 29, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow 75th Anniversary Canister Vacuum Logo
1,062 people viewed this question
Top Rainbow Vacuums Experts
Chris Nomland
Chris Nomland
JoeVacs
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
