Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
Blue Horizontal arching lines, Blue hue at power on
Blue Horizontal arching lines have been present fo a long time maybe a year or more, just recently tho at power on there is blue hue that goes away after set warms up 4-7 minutes maybe more.
the set is a Sony KP-46WT500 purchased Dec 2002
  • 133 Answers
If you take the front cover off the tv, you will see 6 little nobe, the top 3 are focus, bottom 3 are brightness, should be RED-BLUE-GREEN in order from left to right, find the one that is blue, turn it down a quarter turn, should fix the problem
Posted on Jan 08, 2009
Red screen, horizontal lines, 2'' black vertical bars both sides
it looks to me that you are not a technician becouse you are measuring at the wrong places risking a hazard shock if you have a little experience get the service manual and check your power supply and the h v capacitors near the horizontal output if not please take it to your service center
Dec 16, 2009 | Televison & Video
Kp-51ws500 all my channels have a blue hue to them Color adjustments on menu do not help TV is 5 years old, just started recently
if blue has retrace lines,turn down blue g2 control located through the front of tv after front lower bezel and cover boare removed
Jun 13, 2009 | Sony KP-51WS500 51" Rear Projection...
Sony goes blue
you need a new Blue CRT you can get them at the following link.
http://servicemanuals.vstore.ca/
Jan 15, 2009 | Sony KP-57WV600 57" Rear Projection...
Faint red lines in a curved arch like pattern
Is there a cheaper solution? $600 sounds like you just throw it away to me...
Aug 02, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Red Bowed Lines / Red Hue
I tried the solution that was posted for this problem and it worked!
Just remove the Low front panel by removing the two bottom screws that are covered by two screw covers, then remove the second panel (black) by removing the 4 screws then you'll notice a module with 6 adjustment knobs, get a small screw driver, and with the t.v. on, being carefull , and with somebody accross the room looking at the screen begin with the lower left knob and turn left very slowly and ask the person across the room to let you know if the screen is better or not, after this I had to adjust the green as well so, I adjusted the next knob over to the left. Do this adjustment carefully and try to remenber the original position of the knobs in case you have to go back.f
Good Luck,
Californian.
Jun 03, 2008 | Sony KP-57HW40 57" Rear Projection...
Picture on 42HDX82 vertically stretchs after about 10 mins
Sounds like a bad cap, spray some freeze around till you can duplicate the problem.
Oct 22, 2007 | Toshiba 42HDX82 42" Rear Projection...
Sony KP-57WV600 rear projection
sounds like bad CRT, some of these sonys have had defective CRT issues, usually all will come and go sooner or later (all 3 bad), you can pull the speaker grill off(either 2 1/4" screws on bottom or 6 1/4" on back sides) and pull off the Crt box cover (2'X3' piece) and lightly tap the CRT's with tv on, if they flare or get colored streaks in pix they are bad, CALL SONY 800 # and complain, also could adjust G2 (Screen control for color) for short patch. Will need new crts.
Jul 31, 2007 | Sony KP-57WV600 57" Rear Projection...
Guys I did this myself real easy. Just don't turn the corresponding screw too far. Only need to adjust it until the lines go away. Do it on a darker screen so the lines are more visible. I did the red 2 years ago and the green 6months before that. The blue lines are coming on my screen now and I've fixed it in 10 minutes. The TV is amazing.
Apr 10, 2007 | Sony KP-51WS500 51" Rear Projection...
Red Horizontal Lines
they gona get worse to dead circuit, a small capacitor (problably in the neck board) is bothering you, get a tech now that he can see the problem, gonna be cheaper now....good luck ps some times the picture say to the tech was going on
Aug 05, 2006 | Sony KP-51HW40 51" Rear Projection...
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
330 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
