Question about Zanussi ZDF490 Electric Double Oven
Zanuisi top oven making noise
When you turn the top oven on it makes a noise is their a fan for the top oven if so dose it need replacing ie cooling fan for top oven . i had my oven clean would this make it noisy in any way please can you help thank you
  • Anonymous Apr 01, 2014
    My fan turned on on top off oven not the back of oven for 5mins then turn off what does this mean
  • Zanussi Master
  • 3,463 Answers
Yes , there is a cooling fan located at the top of the oven
It could be the fan blades catching, or a noisy fan bearing.
You would have to access it by removing the top oven cover to check., and yes it could be as a result of having it cleaned.
Plz rate my solution.
Thanks.
Posted on Jan 02, 2009
Top oven (Grill) makes a noise when turned on
It will not be the grill that is noisy, but more than likely the top oven cooling fan located under the top cover of oven
Mar 27, 2015 | Ovens
Jenn-Air Maytag double wall oven makes loud buzzing noise
There is a cooling fan for upper and lower oven they run at the same time no matter which oven in use it is fed from the oven manager no way to trouble shoot without pulling oven out some models use same fan for both so you could have a blower on hand remove back panels to access fans take a lead off fan to determine which one noisey
Feb 03, 2015 | Jenn-Air Ovens
I have a belling double oven. The bottom is fan assisted. It all works okay but when it is turned off it is making a drumming noise after the fan has stopped. This lasts for at least 5 minutes. Any...
Sounds like the cooling fan bearings are worn, hence the noise after you turn the cooker off.This fan is in the top of the oven and helps to keep the inside cooker electrics cool and often keeps going for a while after you have turned the cooker off. Best to call an engineer to check this out for you!
Nov 30, 2014 | Ovens
Noise
It will be the external cooling fan that is causing the noise.
Probably worn beaqring or broken fan blade.
Normally, the only solution is to replace the fan motor.
It is located at the top of the oven, usually at the rear, but not in every case.
Please rate my solution.
Thankyou.
Jan 23, 2010 | Zanussi Ovens
Fan making loud noise
Hi
does the noise start as soon as you turn the fan oven on?
does the noise stop as you turn off?
just depending what make and model you have there is two fans
in it 1 is the fan motor inside oven at back and other
is the cooling fan which is at top of oven .you just need
to find out which one it is and just replace . then should be back to normal
regards dan
Mar 19, 2009 | Belling XOU174 Electric Single Oven
Noise from fan when electric oven is first turned on
The fans are not normally repairable, but there is no problem obtaining replacements.
On a double oven, there are usually 2 fans fitted.
There is an external cooling fan usually fitted on the top of the oven, you would have to remove the top cover of oven to access it, and possibly the rear panel as well.
Then there is the fan fitted in the main oven compartment.
If you open the oven door as it is working, you should be able to determine if it is the fan oven or the external cooling fan that is the cause of the problem.
If you determine it is the fan in the oven that is noisy, then to undo the fan blade assy, you have unscrew the nut clockwise to remove it. as opposed to the normal way of undoing a nut.
Please rate my fixya solution.
Thanks.
Feb 09, 2009 | Whirlpool RBD305PD Electric Double Oven
Oven makes a noise when I turn it on.
If it is a fan assisted oven , then it sounds like a noisy oven fan.
It could be a worn or dry bearing in the fan motor. if you open the oven door , you should be able to tell if it is the fan by listening to it carefully.
The other possibility is if it has a cooling fan in the back or on the top of the oven, it could also be that causing the prob, these are about the only things that could be making a noise, as there are no other moving parts that could make a noise.
PLz rate my solution.
Thanks.
Jan 08, 2009 | GE JKP30WMWW 27" Built-in Single Electric...
Cooling and/or convection fan
I had the same problem. The screen protecting the fan bends into the fan from the heat. Take off the top front control panel (3 screws), reach in to the back where the fan is and push the screen back away from the fan. As always, turn the power off first to avoid shock. This should solve your noise problem.
Apr 08, 2008 | GE Profile JTP18 Electric Single Oven
Zanussi ZDF490 Electric Double Oven Logo
1,023 people viewed this question
Top Zanussi Ovens Experts
ashburton
marley mcelhinney
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
