Question about Kenmore Elite 45986 Front Load Washer
Kenmore elite lock problen
My washer will not start and I get FDL washer some time work
I had the same problem. Turned out, electronic panel behind the door had spring action malfunctioned because of misplaced spring, which in turn caused panel to not generate a signal which, stopped the whole cycle.
Here is what I did to fix the problem- 1. Open the door 2. Remove the ring behind rubber-cover on the door. 3. Reach out to the inside-right of the door. 4. Remove the panel after removing electric connections. 5. Fix the spring action. 6. Put everything back and start the machine over.
Posted on Jan 02, 2009
What is code FDL
FDL code is a door lock code on these washers, but be advised, the older models had an issue with the main control boards loosing connection at the soldered joints for the door switch. They would loose solder, and the board would think the fault was the door lock and it was actually the board.
Nov 11, 2013 | Kenmore Elite 45986 Front Load Washer
GIVING CODE FDL?
If the door fails to lock after six (6) attempts "Fdl" will display. The "Fdl" error code indicates the door failed to lock or the control does not detect the door being locked. The likely failure is the door lock mechanism. There is always a chance there could be a loose wire connection between the door lock mechanism and the Central Control Unit (CCU) causing the error too.
Jan 22, 2011 | Kenmore Elite 45986 Front Load Washer
What does code FDL mean? kenmore elite wash maching
You are getting and error code F-DL which means the main control board is sensing that the door is not locking. Most likely a problem with the door lock/latch assembly.
Feb 02, 2010 | Kenmore 45981 Washer
FDL fault code on kenmore elite washer
F DL
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
Nov 08, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 front loader F-11 and FDL codes
yes!! the F/11 is triggered under high voltage conditions like high speed spinning. The part is called the MCU motor control unit. if it goes into failure while using your machine and locks the door, just wait 3 minutes and the door will unlock after the MCU resets. Try using you machine with a low speed spin for awhile.
Oct 29, 2009 | Kenmore Elite 45986 Front Load Washer
My kenmore elite smartwash flashes f and dl when i try and run the wash cycle
Hi
Thanks for using FixYa. Error fdl means a Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
It has occurred due to
1. Door lock mechanism is broken or removed from door.
2. Door switch/lock unit failure. To unlock it follow the steps—
a. Unplug washer or disconnect power.
b. Check door switch/lock unit.
c. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Please revert for further assistance.
Thanks
Rylee
Jul 21, 2009 | Kenmore Elite 45986 Front Load Washer
F dL code message
Hi, this is a failed door lock alert. the FdL code represents this malfunction in the door lock mechanism. the unit will not operate if the door lock cant engage the latch. replace the door lock mechanism asap. this will fix the issue.
Jun 05, 2009 | Kenmore Elite 45986 Front Load Washer
DL F signal
Hi, this is a failed door lock alert. the FdL code represents this malfunction in the door lock mechanism. the unit will not operate if the door lock cant engage the latch. replacing the door lock mech will fix this issue.
Kenmore elite he3 - door lock
If sound like a lid switch issue. Open the top of the washer to get an access to the lid switch(located near the doorframe). Look for a loose wire or a broken switch. In case there is no loose wire or broken switch, you should replace the switch. Good luck!
Sep 05, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
245 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
